Good day,
I have configured my switches (CRS switches running routeros) for management through vlan 50. However, I usually* can’t access the switch (no route to host).
- if I connect to the switch via serial, I can ping the rest of the network. And after I used ping from the switch to my workstation, now my workstation can connect to the switch.
I feel like this might be a routing/arp problem, but I haven’t been able to figure out what’s wrong with my limited networking knowledge.
I’ve basically followed this guide https://help.mikrotik.com/docs/display/ROS/Bridge+VLAN+Table with only slight modifications.
And looked around on the internet and this forum, but didn’t find anything that helped me.
Any pointers would be appreciated.
/export:
# 1970-01-02 02:00:55 by RouterOS 7.12.1
# software id = 0000-0000
# model = CRS326-24G-2S+
# serial number = <removed>
add admin-mac=A0:A0:A0:A0:A0:A0 auto-mac=no frame-types=admit-only-vlan-tagged name=bridge pvid=50 vlan-filtering=yes
/interface vlan
add interface=bridge name=VLAN_MGMT_BR vlan-id=50
/ip hotspot profile
/port
set 0 name=serial0
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether1 pvid=50
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether2 pvid=50
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether3 pvid=50
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether4 pvid=50
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether5 pvid=50
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether6 pvid=50
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether7 pvid=50
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether8 pvid=50
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether9 pvid=100
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether10 pvid=100
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether11 pvid=100
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether12 pvid=100
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether13 pvid=100
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether14 pvid=100
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether15 pvid=100
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether16 pvid=100
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether17 pvid=10
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether18 pvid=10
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether19 pvid=10
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether20 pvid=10
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether21 pvid=90
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether22 pvid=91
add bridge=bridge frame-types=admit-only-vlan-tagged interface=ether23
add bridge=bridge frame-types=admit-only-vlan-tagged interface=ether24
add bridge=bridge frame-types=admit-only-vlan-tagged interface=sfp-sfpplus1
add bridge=bridge frame-types=admit-only-vlan-tagged interface=sfp-sfpplus2
/ipv6 settings
set disable-ipv6=yes
/interface bridge vlan
add bridge=bridge comment=VLAN_PUBLIC tagged=ether23,ether24,sfp-sfpplus1,sfp-sfpplus2 untagged=ether17,ether18,ether19,ether20 vlan-ids=10
add bridge=bridge comment=VLAN_IOT tagged=ether23,ether24,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=20
add bridge=bridge comment=VLAN_MGMT tagged=ether23,ether24,sfp-sfpplus1,sfp-sfpplus2 untagged=bridge,ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8 vlan-ids=50
add bridge=bridge comment=VLAN_PL tagged=ether23,ether24,sfp-sfpplus1,sfp-sfpplus2 untagged=ether21,ether22 vlan-ids=90
add bridge=bridge comment=VLAN_PRINT tagged=ether23,ether24,sfp-sfpplus1,sfp-sfpplus2 vlan-ids=91
add bridge=bridge comment=VLAN_SERVER tagged=ether23,ether24,sfp-sfpplus1,sfp-sfpplus2 untagged=ether9,ether10,ether11,ether12,ether13,ether14,ether15,ether16 vlan-ids=100
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=10.111.50.15/24 interface=VLAN_MGMT_BR network=10.111.50.0
/system clock
set time-zone-name=Europe/Vienna
/system identity
set name=switch5
/system routerboard settings
set boot-os=router-os
Edit: some more details:
- Tried to use a dhcp client instead of static IP - still no route to host from workstation, but via serial I see that the switch got an IP
- Tried setting different values for
/interface/bridge/set arp= - Tried connecting workstation directly to this switch (port with mgmt vlan untagged) and to a mgmt vlan port on a different switch
