Hello, I just got my RB4011 yesterday and am trying to configure it so that ether1 is my WAN, and ether2-10 are my LAN, with ether9 being an access port to VLAN60 and ether2 being a hybrid port for VLAN60, seeing as it is an AP that has SSIDs with VLAN60 and native VLAN.
Here is my config:
[dspencer@MikroTik] > export
# jan/02/1970 15:14:35 by RouterOS 7.1rc1
# software id = AJNK-CMEV
# model = RB4011iGS+
# serial number = REDACTED
add admin-mac=2C:C8:1B:B3:11:F7 auto-mac=no comment=defconf ingress-filtering=no name=bridge vlan-filtering=yes
/interface vlan
add interface=bridge name=vlan60 vlan-id=60
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] ip-type=ipv4
add name=guest-dhcp ranges=192.168.60.100-192.168.60.200
add address-pool=default-dhcp interface=bridge name=defconf
add address-pool=guest-dhcp interface=vlan60 name=vlan60dhcp
/routing table
add fib name=""
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
add bridge=bridge comment=defconf ingress-filtering=no interface=ether6
add bridge=bridge comment=defconf ingress-filtering=no interface=ether7
add bridge=bridge comment=defconf ingress-filtering=no interface=ether8
add bridge=bridge comment=defconf ingress-filtering=no interface=ether10
add bridge=bridge comment=defconf ingress-filtering=no interface=sfp-sfpplus1
add bridge=bridge comment=defconf ingress-filtering=no interface=ether9 pvid=60
set discover-interface-list=none
/ipv6 settings
set disable-ipv6=yes
/interface bridge vlan
add bridge=bridge tagged=ether2 untagged=ether9 vlan-ids=60
/interface l2tp-server server
set l2tpv3-circuit-id="" l2tpv3-cookie-length=0 l2tpv3-digest-hash=md5
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=192.168.60.1 interface=vlan60 network=192.168.60.0
/ip dhcp-client
add comment=defconf interface=ether1 use-peer-dns=no
/ip dhcp-server lease
add address=192.168.1.15 comment="HDHomeRun Tuner" mac-address=redacted server=defconf
add address=192.168.1.90 comment="Wireguard" mac-address=redacted server=defconf
add address=192.168.60.0/24 gateway=192.168.60.1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new \
in-interface-list=WAN
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh port=2200
set api disabled=yes
set api-ssl disabled=yes
/ip ssh
set strong-crypto=yes
/system resource irq rps
set sfp-sfpplus1 disabled=no
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
I’ve tried this several different ways and have followed the bridge vlan guide on help.mikrotik.com but this just hasn’t worked. I can’t get DHCP to work when plugged into ether9. Can anyone offer some advice please?
