First of all, I am desperate. I have been googling, chatting with GPT, Mikrotik AI chat and reading all possible forums, but I have had no luck.
I am trying to set up a home CAPsMAN on my RB2011UiAS-2HnD and a CAP on cAP ax (cAPGi-5HaxD2HaxD). Despite several attempts, the extent of my progress is that they can “ping” each other, but that’s all. The CAP does not see the CAPsMAN, and vice versa.
After a week, I understood that the problem could be in the wireless package on the RB2011 and the wifi-qcom on the cAP ax. Even though I tried to switch to wireless on the cAP ax, I had no luck. Suddenly wifi1/wifi2 are missing and when I accidently rebooted in a way it was there, again, CAP settings had no influence on the CAPsMAN.
Please, can you give me some hints on how to continue? I don’t want to sell my Mikrotik away and buy some hobby router, but this is way above my skills.
RB2011 is wireless (driver) only, while cAP AX is wifi-qcom (driver) only.
If you want to manage the cAP AX from the RB2011, you need to upgrade the latter to 7.13.x (or above, current stable is 7.16.2).
Then you need to run both the old CAPsMAN (for wireless) and the new CAPsMAN (for wifi-qcom, which can be found in the wifi menu) on the RB2011. This will give you both /interface/capsman and /interface/wifi/capsman
Thank you @erlinden for your reply.
I was obviously not searching deep enough as this is new to me. I am just wondering, as RB2011UiAS-2HnD-IN is based on MIPSBE and as wifi-qcom-ac package is for ARM, will this package really work on RB2011? For sure I will give it a try.
@holvoetn, well hope I am not lost, but I am trying to extend coverage of my home WiFi network, where RB2011UiAS-2HnD-IN is main router, while cAP ax should be used for extending signal outside of house (and improve signal in some part of house also). I already know I will need another unit to cover different area so CAPsMAN was a choice for me because of this
I am trying really hard, (you can imagine that family is crazy because of never-ending router resets during last couple of days ) but this topic related to Mikrotik settings is really complicated for me, despite some basic knowledge of coding in general etc.. So, sorry for asking simple questions and again, thanks for your advice!
If you want to have it manage the cAP AX, you have to upgrade to at least RouterOS version 7.13.x and up.
But, as @holvoetn mentioned, you won’t really benefit from it as you have to do the settings twice (wireless and wifi-qcom).
Though I would prefer running CAPsMAN if you tend to expand your wireless network in the future.
Please consider adding a second cAP AX to replace the current wireless from the RB2011.
Thank you very much.
Yes, I am on 7.16.2 on both devices but seems I am doomed to buy a new one.
Hope I got it right and I am not creating even more mess in it… So either I buy another cAP AX, to substitute wifi of my RB2011 (I would connect them by ether and make cAP AX main provider of wifi signal, as I still need Ethernet ports), make actually my main wifi “in-house” out of it and then connect existing cAP AX to extend coverage outside.
If RB2011 is currently in use without problems, L009 will definitely be more then sufficient (unless of course a huge ISP upgrade is also in the planning).
As for 5GHz, AX-2GHz can go to 400Mbps. Some 5GHz connections don’t even get there so again, why everyone is so obsessed about getting maximum speed, I don’t get it.
I prefer smaller channels with lower speeds and higher stability.
Same with roads. A secondary road where I can proceed with constant progress is much more preferred over a highway with several road construction sites and traffic jams with unexpected arrival times as a consequence.
But obviously that’s only my view. Everyone is allowed to think differently.
This approach sounds reasonable to me. Few more things to consider before final decision as I somehow plan to re-implement Pi-hole into the system and having a chance to use container directly on router is attractive to me. Even though this is not a priority as this can be substituted by standalone RPi or container on Home Assistant device or NAS.. again, not a prio anyway.
But, what matters to me is stability as ISP provider is giving a s****y connection (30/10Mb/s ), so, I would benefit from higher speed only for internal transfers of data I suppose.
At least I know where was the issue now. I my knowledge…
