Changelog RouterOS 6.7
Changelogs for upcoming RouterOS 6.7
  • What’s new in 6.7rc1 (2013-Nov-08 15:54):
    *) fixed hairpin nat on bridge with use-ip-firewall=yes;
What’s new in 6.7rc1 (2013-Nov-15 10:45):
*) userman - fix crash on tilera;
*) fixed vlan on bridge after reboot having 00:00:00:00:00:00 mac address;
*) address-list - allow manually adding timeoutable entries;
*) address-list - show dynamic entry timeout;
  • What’s new in 6.7rc1 (2013-Nov-15 15:23):
    *) ipsec - fix policy bypass on IPv6 gre, ipip, eoip tunnels;
6.7rc1 version up in November 19? It seems to use, but do you know What changes?
Best regards
What’s new in 6.7rc1 (2013-Nov-20 14:13):
*) dhcpv4 server - added REMOTE_ID option variable for relayed packets;
*) ipsec - fix policy bypass on IPv6 gre, ipip, eoip tunnels when policy uses protocol filter;
Thanks!
What’s new in 6.7rc2 (2013-Nov-22 15:45):
*) leds - inverted modem signal trigger, now it will trigger when the signal level rises above the treshold;
*) ipsec - added sha256 and sha512 support;
*) ipsec - proposal defaults changed to aes-128 and sha1 for both phase1 and phase2;
*) certificate - support ip, dns and email subject alternative names;
Where can I download 6.7rc2 ???
What’s new in 6.7 (2013-Nov-25 10:22):
Do we know when 6.7 will be release?
Thanks.
there is no release date set.
also 6.7rc2 has some special ppp patches, look more here regarding 6.7rc2
http://forum.mikrotik.com/t/improved-ppp-package-for-v6-x/71794/1
What’s new in 6.7 (2013-Nov-26 09:57):
*) poe - new poe controller firmware for RB750UP and OmniTIK UPA;
what changes?
it should be more precise and report proper values as there where issues observed that sometimes unrealistic reading was displayed.
Sorry for a possible many asked question, but generally available anywhere the development releases of routeros? My devices affected in a bug in 6.6 (vlan on bridge), and i will be try, but also useful for “advanced” users used with caution. If not accessible generally, please give me download link for 6.7rc1. Thanks.
write to support for acceess to prerelease page
could you please comment on the following questions:
which max. initial PoE current is possible with the current hardware/firmware?
which protection is built in and is it reversible/replaceable?
thank you very much!
as far as it should concern end-users - it is as before. Also, fw upgrade procedure is simplified.
There is a bug with PPPoE client in RouterOS 6:
http://forum.mikrotik.com/t/pppoe-client-issues/71528/1
Basically the <<AC-Name=‘’>> folder in the request must be sent even if it’s empty, like other routers do, but Mikrotik doesn’t.
It’s very important because some modems cannot be used. And it’s an extremely easy bug to correct.
Thank you.
Glad to get these features. They show up in CLI but not winbox/webfig.
*) ipsec - added aes-ctr encryption mode;
*) fixed l2mtu changing on CCRs - could cause port flapping;
*) disabling/enabling ethernet ports did not work properly on CCRs - could cause port flapping;
