We don’t know jet. This device will be in Poland just in this week.
Try check about information at: https://wiki.mikrotik.com/wiki/Manual:Interface/LTE but the SoC Quactel EG12 have got all this feature but we don’t know if original at commands will be work or ROS use own commands.
I see that the EM12 has a cell lock AT command, but the EG12 does not report it on the datasheet. It could also be a datasheet from an old version of the firmware, so who knows.
I hope Mikrotik thought about it.
EP06, EM12, EG12, EG18 … have got the same at commands and Quactel speak about that “compability” in documentation. Check last post about EP06…at http://forum.mikrotik.com/t/quectel-ep06-e-and-wap-r-ac-rbwapgr-5hacd2hnd/131724/1 .
Remember that we don’t know what we receive at MikroTik version of EG12 and we down’t know if name will be R11e-lte12-G (like global) or what.
We wait
I can confirm that as of beta 8 (or maybe 7, but went straight to 8 here) passthrough is working on my Chateau LTE12 in response to the original question in this thread. You will need to upgrade devices that have been shipping with beta 6 to the latest version. In my case passthrough is over a VLAN.
Quectel EG12 not support frequency lock to select band at any tower.
Quectel EG12 support one and many Cell Lock’s, you can enter max 20 of CellLock’s and it select the one with the best signal and set it as primary-band.
Note: the CA are still automatic and we cannot force any of CA. We can only have enabled band’s what we want to use and check the incoming SiB message from eNB by AT+QENG=“neighbourcell”.
EARFCN give us center of frequency specific band of our ISP,
PHY-CELLID give us a specific antenna at tower
Example is base at signals like this one, Cell-Monitor show us:
Thank you very much.
Does this mean that we can set 2 CellLocks an the EG12 will use one as primary and one in CA? Does this mean that we can force the Cells also for the CA (this is not possible with the current modem from Mikrotik)?
NO
CA is different story and it’s always receving from eNB to you. Any lte module not give you option to force anything with CA.
LTE not works like that.
Any vendor of module cannot force bts to anything. We can connect and force main band, all other options are incomming in SiB messages (yes, my nickname is the same) to any LTE device and inform it what options he can use.
Check: AT+QENG=“neighbourcell”
Hi
Very good information, it seems that the lock didn’t stand/stay after a router reboot ?
Can anyone confirm ?
I did set :
interface/lte/at-chat lte1 input=“at+qnwlock="common/4g",1,3350,187”
When rebooting the router and done some couple on disable/enable LTE interface, it connect to different primary band like B3 or B28.
It’s not B31 as detected but B28 (700mhz), bug ?
Note here that B3 is not detected ?? when running the command.
Also, 2 others question
Can we get QAM Downstream live value ?
Can we enable some kind of diag option to analyse stream like some qualcomm chip and tool ?
I do that at shared to me from dad232 the chateau, and when I will have access again then I try check that.
No one say that eg12 save that option inside
That’s why you have got that:
interface lte set lte1 modem-init="“common/4g",1,3350,187” ← I not shure correct syntax but you know the idea.
One thing also :
Sorry, but this is ROS feature and cell-monitor will be better for sure in next beta’s.
You can only report that at support.
Check AT command from Quectel, they are works.
B3 is there but for how long and B31 (wrong one it’s B28)
earfcn is for 3 regions,
japan
nord america
word = other like emea ← MikroTik as vendor use that
this mean some bands can be wrong numbered in Japan&NA
Ok this is you and dad, I understand better now, this is great
I have to try the syntax then
I have just try a script on reboot/boot with a delay of 30 sec and seems to do the trick but better if we can try to set it from start in modem.
So to clean up the command this should work too (need testing) :
interface lte set lte1 modem-init=“common/4g",0”;
Good, I have just added this to ticket
I did try to look at the AT command but didn’t find it, I have surely not looked correctly.
Do you mean, there is one for QAM and another command for diag communication ?
japan
nord america
Ok so if it’s a wrong logic to display band name but behind all is working with correct band, it’s OK
But I have reported it too on support
Why, probably that device power up every time with NO CELL LOCK, this mean every usb-power-reset or disable-enable lte1 etc. disable this CellLock feature. I not test that all scenario jet.
The modem-init= is just like autostart, to send some at commands what you want to work with that device. If that is to early then you can create a system \ scheduler with startup feature and first command “/delay 30s; …”
QAM is not show, in general if he is then cainfo show it, not here :(, but
this is important, give you CQI status, Intra & Inter cells, page: 78 / 234
Probably when we receive r11e-lte6-us, r11e-lte12-us, r11e-lte16-us, r11e-lte20-us, r11e-5g-global then that modules created for NordAmerica can show you properly earfcn for region :). I hope that modules what I write they are be in future, of course I guess that names base at current ones.
ok It seems disable/enable/disable is ok, it stays on lock
QAM is not show, in general if he is then cainfo show it, not here > > , but
Thanks, have to look at this command, we can already get CQI from RouterOS
Probably when we receive r11e-lte6-us, r11e-lte12-us, r11e-lte16-us, r11e-lte20-us, r11e-5g-global then that modules created for NordAmerica can show you properly earfcn for region > > . I hope that modules what I write they are be in future, of course I guess that names base at current ones.
