Chateau LTE12 LTE --- connect failed
Hi.
I’m new to MikroTik. I recently got a Chateau LTE12. I am unable to get the LTE modem to connect. I tried 3 different SIMs, 2 roaming, 1 local. They all work without any problems on my phone.
Some possible problems, which might be quick to rule out:
  • APN settings (I have tried duplicating what works on my phone, however I am not sure it’s 100%)
  • The modem firmware needs an upgrade (How to FOTA without a working internet connection?)
Here are the steps to reproduce (from factory settings):
  • Insert SIM + power on device
  • (only for the roaming SIMs) Change “Allow Roaming” setting to yes
  • get “–connect failed” error
  • configure default APN: apn=internet.digimobil.es (or as appropriate for the sim)
  • upgrade to RouterOS 7.0beta8
I saw this thread: http://forum.mikrotik.com/t/chateau-lte12-routerosv7-beta6-lte-wont-connect/139763/1 but I couldn’t get to anything conclusive / actionable for my case.
Here is some more info about my setup:
[admin@MikroTik] > export hide-sensitive
# jan/01/2002 06:52:04 by RouterOS 7.0beta8
# software id = ZFL1-1DVY
# model = RBD53G-5HacD2HnD
# serial number = C8CA0C0C0467
add admin-mac=48:8F:5A:0F:CF:BF auto-mac=no comment=defconf name=bridge
/interface lte
# connect failed
set [ find ] allow-roaming=yes name=lte1
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] apn=internet.digimobil.es ip-type=ipv4
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
/ip vrf
add list=all name=main
add bridge=bridge comment=defconf interface=wlan2
/interface detect-internet
set detect-interface-list=all
add comment=defconf interface=lte1 list=WAN
add address=192.168.88.1/24 comment=defconf interface=ether1 network=192.168.88.0
/ip dhcp-client
add disabled=no
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ipv6 firewall address-list
add address=::224.0.0.0/100 comment="defconf: other" list=bad_ipv6
add address=::127.0.0.0/104 comment="defconf: other" list=bad_ipv6
add address=::/104 comment="defconf: other" list=bad_ipv6
add address=::255.0.0.0/104 comment="defconf: other" list=bad_ipv6
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
#error exporting /routing/policy/selection
/system logging
add topics=lte
/tool mac-server
/tool mac-server mac-winbox
you work at 3g, not LTE now.
Enable only lte.
Not select any specific bands, means use all bands.
Allow roaming - you enable that possibility but you not use they, you not do a scan and select the “set operator=” what use roaming, means this still not work.
Thanks @SiB
I tried again, with only LTE and bands 3,7,20 turned on. Roaming turned off, and a local SIM (MEO Portugal). I still get the same “— connect failed” error.
This is using RouterOS 7.0beta8. Factory installed was beta6, do you think it’s worth trying a downgrade to beta6?
you can enable logs ?
/system logging add topics=lte
Try upgrade modem firmware to EG12EAPAR01A06M4G via other Internet from wlan or ethernet.
Hmm, maybe you can connect via winbox by MAC. Disable DHCP-Server. Add/Enable dhcp-client at ether1 and connect him to any other internet?
interface/lte/firmware-upgrade lte1
I have not had time to confirm this, but your issue may be result of EG12-EA not passing correct APN to provider, even though it is correctly setup in ROS7 beta8
Try setting APN directly on modem via AT command AT+CGDCONT.
JardinEspanol
I think this is solve in beta9, but Remember about:
[admin@MikroTik] > interface/lte apn/set use-network-apn=
no yes
PS. We should speak about your routing ? :wink:
I confirm the bug. Solved the issue thanks to this thread!
Thank you
