Hi
I’m not sure if these are expected, pecular to my setup, or bugs in v7 so I thought I would check here first.
I’m seeing this on a range of RB models running v7.1.
- NTP client
NTP client is working as expected (command below) but the list of servers in WebFig are blank (see screen shots).
/system/ntp/client/set enabled=yes mode=unicast servers=0.nz.pool.ntp.org,1.nz.pool.ntp.org;
- long-term channel
I used the upgrade channel to move from v6 to v7 and then configured the long-term channel. But the title is showing that its installed v7.1 from the testing channel, is this a typo? (screen shot attached).
MC
