I have read through the getting started documentation, and have watched the official mikrotik vlan videos, I am just not sure if what I have done is as efficient as it could be, or secure. Any suggestions or guidance would be greatly appreciated.
Thank you.
# 2026-01-10 14:07:43 by RouterOS 7.20.6
# software id = NIGV-JLUH
# model = RB5009UPr+S+
# serial number = XXXXXXXXXXX
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no comment=defconf name=\
switch_bridge
/interface vlan
add interface=switch_bridge name=default vlan-id=1
add interface=switch_bridge name=home63 vlan-id=63
add interface=switch_bridge name=management223 vlan-id=223
add interface=switch_bridge name=nowan191 vlan-id=191
add interface=switch_bridge name=servers127 vlan-id=127
add comment=defconf name=WAN
add comment=vlan name=PVID_home63
add comment=vlan name=PVID_servers127
add comment=vlan name=PVID_nowan191
add comment=vlan name=PVID_management223
add comment=defconf include=PVID_home63,PVID_servers127 name=LAN
/interface wifi channel
add band=5ghz-ax frequency=5180 name=5GHZ::CH36 width=20mhz
add band=5ghz-ax frequency=5200 name=5GHZ::CH40 width=20mhz
add band=5ghz-ax frequency=5220 name=5GHZ::CH44 width=20mhz
add band=5ghz-ax frequency=5240 name=5GHZ::CH48 width=20mhz
add band=5ghz-ax frequency=5745 name=5GHZ::CH149 width=20mhz
add band=5ghz-ax frequency=5765 name=5GHZ::CH153 width=20mhz
add band=5ghz-ax frequency=5785 name=5GHZ::CH157 width=20mhz
add band=5ghz-ax frequency=5805 name=5GHZ::CH161 width=20mhz
add band=5ghz-ax frequency=5825 name=5GHZ::CH165 width=20mhz
add band=2ghz-ax frequency=2412 name=2GHZ::CH1 width=20mhz
add band=2ghz-ax frequency=2437 name=2GHZ::CH6 width=20mhz
add band=2ghz-ax frequency=2462 name=2GHZ::CH11 width=20mhz
add band=5ghz-ax disabled=no frequency=5180,5200,5220,5240 name=5GHZ::UNII-1 \
width=20mhz
add band=5ghz-ax disabled=no frequency=5745,5765,5785,5805,5825 name=\
5GHZ::UNII-3 width=20mhz
add band=5ghz-ax disabled=no frequency=\
5180,5200,5220,5240,5745,5765,5785,5805,5825 name=5GHZ::NON-DFS width=\
20mhz
add band=2ghz-ax disabled=no frequency=2412,2437,2462 name=2GHZ::AUTO width=\
20mhz
/interface wifi datapath
add bridge=switch_bridge disabled=no name=datapath1
add disabled=no interface-list=PVID_home63 name=datapath63 vlan-id=63
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disabled=no encryption=ccmp name=\
sec1
/interface wifi configuration
add channel=2GHZ::AUTO channel.band=2ghz-ax .width=20mhz country=\
"United States" datapath=datapath63 disabled=no mode=ap name=cfg_2_4 \
security=sec1 ssid=WIFIname
add channel=5GHZ::NON-DFS channel.band=5ghz-ax .width=20/40/80mhz country=\
"United States" datapath=datapath63 disabled=no mode=ap name=cfg_5 \
/interface wifi
# operated by CAP AA:AA:AA:AA:AA:AA%switch_bridge, traffic processing on CAP
add channel=2GHZ::AUTO configuration=cfg_2_4 configuration.mode=ap disabled=\
no name=Hall_2_4 radio-mac=AA:AA:AA:AA:AA:A1
add channel.frequency=5180,5200,5220,5240,5745,5765,5785,5805,5825 \
configuration=cfg_5 configuration.mode=ap disabled=no name=Hall_5 \
radio-mac=AA:AA:AA:AA:AA:A0
# operated by CAP BB:BB:BB:BB:BB:BB%switch_bridge, traffic processing on CAP
configuration=cfg_5 configuration.mode=ap disabled=no name=LaundryRoom_5 \
radio-mac=BB:BB:BB:BB:BB:B0
add channel.frequency=2412,2437,2462 configuration=cfg_2_4 \
configuration.mode=ap disabled=no name=Laundry_2_4 radio-mac=\
BB:BB:BB:BB:BB:B1
# operated by CAP CC:CC:CC:CC:CC:CC%switch_bridge, traffic processing on CAP
configuration.mode=ap disabled=no name=Shed_2_4 radio-mac=\
CC:CC:CC:CC:CC:C1
configuration=cfg_5 configuration.mode=ap disabled=no name=Shed_5 \
radio-mac=CC:CC:CC:CC:CC:C2
add name=default-dhcp ranges=10.122.0.2-10.122.0.250
add name=home-dhcp ranges=10.122.63.2-10.122.63.250
add name=servers-dhcp ranges=10.122.127.2-10.122.127.250
add name=nowan-dhcp ranges=10.122.191.2-10.122.191.250
add name=management-dhcp ranges=10.122.223.2-10.122.223.250
add address-pool=default-dhcp interface=switch_bridge name=defconf
add address-pool=home-dhcp interface=home63 name=home
add address-pool=servers-dhcp interface=servers127 name=servers
add address-pool=nowan-dhcp interface=nowan191 name=nowan
add address-pool=management-dhcp interface=management223 name=management
/disk settings
set auto-media-interface=switch_bridge auto-media-sharing=yes \
auto-smb-sharing=yes
add bridge=switch_bridge comment=defconf interface=ether2
add bridge=switch_bridge comment=defconf interface=ether3
add bridge=switch_bridge comment=defconf interface=ether4
add bridge=switch_bridge comment=defconf interface=ether5
add bridge=switch_bridge comment=defconf interface=ether6
add bridge=switch_bridge comment=defconf interface=ether7
add bridge=switch_bridge comment=defconf interface=sfp-sfpplus1
/interface bridge vlan
add bridge=switch_bridge vlan-ids=1
add bridge=switch_bridge vlan-ids=63
add bridge=switch_bridge vlan-ids=127
add bridge=switch_bridge vlan-ids=191
add bridge=switch_bridge vlan-ids=223
/interface detect-internet
set detect-interface-list=WAN internet-interface-list=all lan-interface-list=\
LAN wan-interface-list=WAN
add comment=defconf interface=switch_bridge list=LAN
add interface=home63 list=PVID_home63
add interface=servers127 list=PVID_servers127
add interface=nowan191 list=PVID_nowan191
add interface=management223 list=PVID_management223
/interface wifi capsman
set enabled=yes interfaces=switch_bridge package-path="" \
require-peer-certificate=no upgrade-policy=none
add address=10.122.0.1/24 comment=defconf interface=switch_bridge network=\
10.122.0.0
add address=10.122.63.1/24 comment=home interface=home63 network=10.122.63.0
add address=10.122.127.1/24 comment=servers interface=servers127 network=\
10.122.127.0
add address=10.122.191.1/24 comment=nowan interface=nowan191 network=\
10.122.191.0
add address=10.122.223.1/24 comment=management interface=management223 \
network=10.122.223.0
/ip cloud
set update-time=no
/ip dhcp-client
add comment=defconf_client default-route-tables=main interface=ether1
add address=10.122.0.0/24 comment=defconf dns-server=10.122.0.1 gateway=\
10.122.0.1 netmask=24
add address=10.122.63.0/24 comment=home dns-server=10.122.63.1 gateway=\
10.122.63.1 netmask=24
add address=10.122.127.0/24 comment=servers dns-server=10.122.127.1 gateway=\
10.122.127.1 netmask=24
add address=10.122.191.0/24 comment=nowan dns-server=10.122.191.1 gateway=\
10.122.191.1 netmask=24
add address=10.122.223.0/24 comment=management dns-server=10.122.223.1 \
gateway=10.122.223.1 netmask=24
set allow-remote-requests=yes servers=\
1.1.1.1,1.0.0.1,8.8.8.8,8.8.4.4,9.9.9.9,9.9.9.10
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip service
set ftp disabled=yes
set telnet disabled=yes
set www disabled=yes
set ssh address=10.122.223.0/24 port=1220
set winbox address=10.122.0.0/24,10.122.223.0/24
set api disabled=yes
set api-ssl disabled=yes
/ip ssh
set host-key-type=ed25519 strong-crypto=yes
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" \
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=America/New_York
/system identity
set name=RB5009UPr+S+OUT
/system ntp client
set enabled=yes
/system ntp server
set broadcast=yes broadcast-addresses=\
10.122.0.255,10.122.63.255,10.122.127.255,10.122.191.255,10.122.223.255 \
enabled=yes
/system ntp client servers
add address=us.pool.ntp.org
add address=time.nist.gov
add address=time.cloudflare.com
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
