Tutorial: Home VLAN configuration (RB5009, cAP ACs, multiple SSIDs)
Hi all,
I recently decided to explore the idea of segmenting my home network into multiple VLANs. I am by no means a Mikrotik expert and my networking knowledge was mostly confined to cloud provider abstractions. Due to this lack of experience it was a frustrating and time-consuming experience.
Instead of just dumping my config here and asking the community if it's correct, I decided I'd rather write this up as a guide so that other people can also benefit from my learnings. I would of course appreciate any recommendations or corrections, and I'll update the guide to reflect these.
:warning: Disclaimer: I am not a networking or Mikrotik expert, and this guide is based on my personal experience and learning.
This guide is opinionated and does not claim to be error-free. Please consult the official Mikrotik documentation to verify any commands or configurations that you apply.
1. Motivation
There are many reasons why you might want to segment your network with VLANs, but my specific goals were:
  1. Control IoT device communication, including the ability to prevent IoT devices from initiating communication with security sensitive devices on my network (such as my laptop).
  2. Allow guest devices to access the internet and nothing else (no communication with other devices on the network, including other guest devices).
  3. Prepare for various other things I'd like to implement, such as secure access to my home network with a reverse tunnel.
  4. Learn more about networks and generally just play around with RouterOS for fun.
There are almost certainly other approaches to achieve these goals, but I wanted to do it with VLANs since this felt like the most flexible and future-proof solution.
2. Overview
2.1. VLANs
The end result of this guide is a network with the following VLANs:
  • VLAN 10: Owner Devices
    • This VLAN is for my personal devices, such as my laptop, TV and phone.
  • VLAN 20: IoT Devices
    • This VLAN is for my IoT devices, such as a Raspberry Pi (physically connected via ethernet) and Victron Cerbo GX (
      connected via Wi-Fi).
  • VLAN 30: Guest Devices
    • This VLAN is for guest devices, such as visitors' phones that connect to Wi-Fi.
  • VLAN 99: Management
    • This VLAN is for management of the router and access points.
Even though this is likely a common setup, you can adjust the VLANs to suit your needs. For example, you might want to create a separate VLAN TVs or place TVs in the IoT VLAN (I decided against this since I wanted to simplify casting from my phone to the TV).
2.2. Wi-Fi SSIDs
To assign devices to the correct VLANs, the following Wi-Fi SSIDs will be created:
  • OwnerWifi: This SSID will be used for my personal devices and will be assigned to VLAN 10.
  • IoTWifi: This SSID will be used for IoT devices and will be assigned to VLAN 20.
  • GuestWifi: This SSID will be used for guest devices and will be assigned to VLAN 30.
    • This SSID will have client isolation enabled, so guest devices will not be able to communicate with each other.
:light_bulb: Instinctively you might want to create a single SSID for all devices and use MAC address filtering to assign devices to the correct VLANs, but this is generally not recommended.
2.3. Hardware
Even though many of the concepts in this guide applies to RouterOS in general, there are some things that are specific to the hardware I am using.
  • Router: Mikrotik RB5009UPr+S+IN
    • The RB5009UG+S+IN should work exactly the same - I chose the UPr since I wanted multiple PoE outputs.
  • Wireless Access Points: Mikrotik RBcAPGi-5acD2nD (x2)
    • I already had two of these, so I made do with them.
    • These cAP ac APs unfortunately don't support CAPsMAN based VLAN provisioning at the time of writing, which caused a lot of frustration, but the guide explains how make VLANs work with them.
    • If you use cAP ax APs, you'll have less configuration to do on the APs themselves (more on this later).
  • Optical Network Terminal: Huawei EchoLife HG8240H
    • This is the ONT provided by my ISP, it facilitates the connection to the fiber network via GPON and PPPoE.
    • If you use something other than PPPoE to connect to the internet you will need to adjust the configuration accordingly.
    • Configuration changes on the ONT was not necessary in my case, and generally shouldn't be required.
  • Computer:
    • Any computer with internet access and an Ethernet port should work.
  • Cabling:
    • You will need an Ethernet cable to connect your computer to the router and access points.
2.4. Software
I used the latest stable version of RouterOS at the time of writing, but this guide should work with any 7.x version.
See the official Mikrotik download page for the latest versions: https://mikrotik.com/download
  • Router:
    • RouterOS: 7.19.2 (routeros-7.19.2-arm64.npk in my case)
    • RouterOS: 7.19.2 (routeros-7.19.2-arm.npk in my case)
    • Wifi QCom AC (wifi-qcom-ac-7.19.2-arm.npk in my case)
      • It's important to use this package instead of the older wireless package if you are using cAP ac APs.
  • Configuration software:
    • Windows
      • WinBox is required for this guide since we will use Layer 2 (MAC) based communication for configuration.
      • If you only have Linux available, you can consider using wine or virtualization (such as VirtualBox) to run Winbox.
    • WinBox: 3.42
      • The latest version at the time of writing, but any recent version should work.
3. Initial Setup
This guide assumes that you are starting with a fresh RouterOS installation without any defaults on both the router and access points.
First we will reset the router and access points.
:warning: This will erase all existing configurations on the router and access points. Make sure to back up any existing configurations you want to retain before proceeding.
  1. Connect the router to your computer using an Ethernet cable.
    1. Use ethernet port 8, since this port will be a dedicated port for configuration in this guide.
  2. Open WinBox and connect to the router using the MAC address.
  3. Reset the router to factory defaults
     /system reset-configuration no-defaults=yes skip-backup=yes
    Your router will reboot, and you will need to reconnect to it using WinBox.
  4. Configure your username and password
    1. It's best practice to use a non-default username and a strong password.
Repeat the same steps for each of your access points, but connect the access points to your computer using ethernet port 2, since this port will be a dedicated port for configuration of the access points.
The next step is to install the required packages on the router and access points.
Since the devices do not have any internet at this point, we will perform a manual upgrade using WinBox.
Please follow this guide to install the packages as specified in the "Software" section above.
:light_bulb: It's highly recommended to also update the RouterBoard firmware after upgrading RouterOS. See the link above.
:warning: If you are using cAP ac APs, make sure to uninstall the older wireless package if it's installed.
4. Router Configuration
Now that we have a clean RouterOS installation on the router and access points, we can start configuring the router.
We will use the terminal in WinBox to configure the router, but you can also use the GUI if you prefer.
4.1. Basic Configuration
/system
# Set the identity
identity set name=router
# Setup initial timezone and time
clock set time-zone-name=Africa/Johannesburg
clock set date="jun/28/2025"
clock set time="15:00:00"
# Use Cloudflare NTP servers for accurate timekeeping
ntp client set enabled=yes servers=time.cloudflare.com
:gear: Customization
  • Set the time-zone-name to your local timezone. You can find a list of timezones
    here.
  • Set the date and time to the current date and time (anything close is fine).
  • It's not necessary to use an NTP server, and you can use your ISP's NTP server if you prefer.
4.2. Ethernet interfaces
We will configure the Ethernet interfaces to have descriptive names and comments for easy identification. This is not strictly necessary, but it will make it easier to follow the configuration and understand what each port is used for.
set [ find default-name=ether1 ] name=ether1-wan        comment="ISP PPPoE WAN"
set [ find default-name=ether2 ] name=ether2-ap1        comment="Access Point 1"
set [ find default-name=ether3 ] name=ether3-ap2        comment="Access Point 2"
set [ find default-name=ether4 ] name=ether4-laptop     comment="Personal laptop"
set [ find default-name=ether5 ] name=ether5-rpi        comment="Raspberry PI"
set [ find default-name=ether8 ] name=ether8-management comment="Dedicated unbridged port for management access"
set [ find default-name=sfp-sfpplus1 ] disabled=yes
  • Adjust the names and comments to match your setup.
  • If you have more or fewer Ethernet ports, adjust the configuration accordingly.
  • If you have an SFP+ port, you can keep it enabled it if you plan to use it.
4.3. VLANs
Create a bridge and enable VLAN filtering on it.
/interface bridge add name=bridge-lan vlan-filtering=yes comment="LAN bridge"
Create a VLAN interface for each VLAN we want to use. This allows us to use IP (Layer 3) services such as on each VLAN.
/interface vlan
add interface=bridge-lan name=vlan10-owner      vlan-id=10 comment="Owner VLAN"
add interface=bridge-lan name=vlan20-iot        vlan-id=20 comment="IoT VLAN"
add interface=bridge-lan name=vlan30-guest      vlan-id=30 comment="Guest VLAN"
add interface=bridge-lan name=vlan99-management vlan-id=99 comment="Management VLAN"
Next add the required bridge ports to the bridge.
# The Wi-Fi access points ports are trunk ports which will carry traffic for mutliple VLANs.
port add bridge=bridge-lan frame-types=admit-only-vlan-tagged interface=ether2-ap1 comment="AP1 Trunk Port"
port add bridge=bridge-lan frame-types=admit-only-vlan-tagged interface=ether3-ap2 comment="AP2 Trunk Port"
# The Ethernet ports for personal devices and IoT devices are access ports which will carry traffic for a single VLAN.
port add bridge=bridge-lan frame-types=admit-only-untagged-and-priority-tagged interface=ether4-laptop pvid=10 comment="Laptop Access Port (VLAN 10)"
port add bridge=bridge-lan frame-types=admit-only-untagged-and-priority-tagged interface=ether5-rpi    pvid=20 comment="Raspberry PI Access Port (VLAN 30)"
:warning: Do not add the management port (ether8-management) to the bridge, this port is used for unbridged management access only.
Next we configure the bridge VLAN table to restrict which VLANs are allowed on each port.
vlan add bridge=bridge-lan tagged=bridge-lan,ether2-ap1,ether3-ap2 untagged=ether4-laptop vlan-ids=10 comment="Owner VLAN with access port for laptop"
vlan add bridge=bridge-lan tagged=bridge-lan,ether2-ap1,ether3-ap2 untagged=ether5-rpi    vlan-ids=20 comment="IoT VLAN with access port for Raspberry PI"
vlan add bridge=bridge-lan tagged=bridge-lan,ether2-ap1,ether3-ap2                        vlan-ids=30 comment="Guest VLAN with access only via Wi-FI AP trunks"
vlan add bridge=bridge-lan tagged=bridge-lan,ether2-ap1,ether3-ap2                        vlan-ids=99 comment="Management VLAN"
4.4. Basic IP Services
Next we will configure various IP services on the router, such as DHCP and DNS.
4.4.1. DNS
I decided to use Cloudflare and Google DNS servers for my home network.
/ip dns set allow-remote-requests=yes servers=1.1.1.1,8.8.8.8
  • You can use any DNS servers you prefer, such as your ISP's DNS servers or a local DNS server.
4.4.2. IP Addresses
Add IP addresses to the VLAN interfaces we created earlier.
:light_bulb: IP capacity planning is a complex topic which I will not provide guidance on here.
For my home network I decided to use a /24 subnet for each VLAN, which provides sufficient capacity for my needs. I also decided to use 10.<VLAN_ID>.0.0/24 as the network for each VLAN, which makes it easy to identify the VLAN based on the IP address.
add address=10.10.0.1/24 comment="Owner VLAN addresses"      interface=vlan10-owner      network=10.10.0.0
add address=10.20.0.1/24 comment="IoT VLAN addresses"        interface=vlan20-iot        network=10.20.0.0
add address=10.30.0.1/24 comment="Guest VLAN addresses"      interface=vlan30-guest      network=10.30.0.0
add address=10.99.0.1/24 comment="Management VLAN addresses" interface=vlan99-management network=10.99.0.0
  • Adjust the IP addresses and networks to suit your needs.
4.4.3. DHCP Server
Each VLAN will have its own DHCP server to assign IP addresses to devices on the network.
I decided to only use 10.<VLAN_ID>.0.100-10.10.0.199 as the DHCP range for each VLAN, which leaves room for static IP addresses in the 10.<VLAN_ID>.0.2-10.<VLAN_ID>.0.99 and 10.<VLAN_ID>.0.200 10.<VLAN_ID>.0.254 ranges, which suits my needs.
Create the IP pools for each DHCP server to use.
add name=pool-owner ranges=10.10.0.100-10.10.0.199
add name=pool-iot ranges=10.20.0.100-10.20.0.199
add name=pool-guest ranges=10.30.0.100-10.30.0.199
add name=pool-management ranges=10.99.0.100-10.99.0.199
  • Adjust the IP pools to suit your needs, but I recommend reserving a range for static IP addresses.
Create each DHCP server and add a DHCP network for each.
add address-pool=pool-owner      interface=vlan10-owner      lease-time=1d name=dhcp-owner
add address-pool=pool-iot        interface=vlan20-iot        lease-time=1d name=dhcp-iot
add address-pool=pool-guest      interface=vlan30-guest      lease-time=1h name=dhcp-guest
add address-pool=pool-management interface=vlan99-management lease-time=1d name=dhcp-management
network add address=10.10.0.0/24 dns-server=10.10.0.1 gateway=10.10.0.1 comment="Owner DHCP Network"
network add address=10.20.0.0/24 dns-server=10.20.0.1 gateway=10.20.0.1 comment="IoT DHCP Network"
network add address=10.30.0.0/24 dns-server=10.30.0.1 gateway=10.30.0.1 comment="Guest DHCP Network"
network add address=10.99.0.0/24 dns-server=10.99.0.1 gateway=10.99.0.1 comment="Management DHCP Network"
  • Adjust the lease times to suit your needs. Typically guest devices will have shorter lease times, while permanent devices will have longer lease times.
4.5 PPPoE Client
Now we will configure the PPPoE client to connect to the internet.
/interface pppoe-client
add add-default-route=yes allow=pap,chap comment="ISP PPPoE" interface=ether1-wan max-mru=1480 max-mtu=1480 mrru=1600 name=pppoe-out user=your_user@isp.com password=your_password
  • The allow, max-mru, max-mtu and mrru values are what my ISP requires, adjust these values to suit your ISP's requirements.
  • Specify your ISP's PPPoE username and password in the user and password fields.
  • If you do not use a PPPoE connection, you can skip this step and configure your internet connection accordingly.
4.6. Wi-Fi
Now we will configure the Wi-Fi, including the special configuration considerations for the cAP ac APs.
The cAP ac APs do not support dynamic VLAN assignment based on datapath when using thewifi-qcom-ac package.
:light_bulb: If you are using cAP ax APs, please see this official example configuration and adapt the steps below accordingly.
4.6.1. Datapath
Create a single generic datapath.
/interface wifi datapath add bridge=bridge-lan disabled=no name=dp-ac-generic comment="Generic datapath for cAP ac APs"
4.6.2. Band steering
I decided to enable band steering on the cAP ac APs to encourage dual-band capable devices to connect to the 5GHz band, which has less interference and higher speeds.
/interface wifi steering add disabled=no name=steering-main rrm=yes wnm=yes
  • Band steering is optional, do your own research to determine if it's suitable for your environment.
4.6.3. Security Profiles
Create security profiles for each SSID we will create. These profiles are provisioned to the access points using CAPsMAN.
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disabled=no ft=yes name=sec-owner comment="Owner WiFi security"
add authentication-types=wpa2-psk,wpa3-psk disabled=no ft=no  name=sec-iot   comment="IoT WiFi security"
add authentication-types=wpa2-psk,wpa3-psk disabled=no ft=yes name=sec-guest comment="Guest WiFi security"
  • I decided to use WPA2/WPA3 PSK for all SSIDs. You can use WPA3 only if you prefer, but this will prevent older devices from connecting.
  • Fast Transition (FT) is optional. I enabled FT for the owner and guest SSIDs, while I disabled it for the IoT SSID since these devices are not expected to roam between access points.
4.6.4. Configuration Profiles
Create configuration profiles for each SSID we want to create. These profiles are provisioned to the access points using CAPsMAN.
/interface wifi configuration
add country="South Africa" datapath=dp-ac-generic disabled=no name=config-owner-wifi security=sec-owner ssid=OwnerWifi steering=steering-main comment="Config for Owner WiFi SSID"
add country="South Africa" datapath=dp-ac-generic disabled=no name=config-iot-wifi   security=sec-iot   ssid=IoTWifi                          comment="Config for IoT WiFi SSID"
add country="South Africa" datapath=dp-ac-generic disabled=no name=config-guest-wifi security=sec-guest ssid=GuestWifi steering=steering-main comment="Config for Guest WiFi SSID"
  • Adjust the country field to your country name.
  • Adjust the ssid field to your desired SSID names.
  • The
    steering field is optional, I enabled it for the owner and guest SSIDs to encourage dual-band capable devices to connect to the 5GHz band.
4.6.5. CAPsMAN
Enable and configure CAPsMAN to manage the access points.
:light_bulb: The action is not set to create-dynamic-enabled (instead we use create-enabled) since we are somewhat manually managing the CAPs due to the "wifi-qcom-ac" package not supporting automatic VLAN provisioning.
/interface wifi
capsman set enabled=yes ca-certificate=auto certificate=auto interfaces=vlan99-management
provisioning add action=create-enabled disabled=no master-configuration=config-owner-wifi slave-configurations=config-iot-wifi,config-guest-wifi comment="Provision config to all APs"
4.7. Security
:warning: Security is a complex topic and this section will not cover all aspects of securing your home network. See the Securing your router and Firewall documentation for more information.
4.7.1. Interface lists
Create interface lists to group interfaces based on their purpose. This will make it easier to manage firewall rules and other configurations.
add name=management comment="Management interface list"
member add list=management interface=ether8-management comment="Dedicated management port"
member add list=management interface=vlan99-management comment="Management VLAN"
add name=vlan comment="All VLANs excluding management VLAN"
member add list=vlan interface=vlan10-owner    comment="Owner VLAN"
member add list=vlan interface=vlan20-iot      comment="IoT VLAN"
member add list=vlan interface=vlan30-guest    comment="Guest VLAN"
add name=wan comment="WAN interface list"
member add list=wan interface=pppoe-out comment="PPPoE WAN interface"
4.7.2. Address lists
I wanted my laptop and phone to be able to access the router via HTTP, and I assigned static IP addresses to these devices. I thus have an address list for them which is used in the firewall rules.
/ip firewall address-list
add address=10.10.0.2 list=owner-webfig comment="Owner laptop"
add address=10.10.0.3 list=owner-webfig comment="Owner phone"
4.7.3. Disable unused services and tools
Disable any unused services and tools to reduce the attack surface of the router.
/tool
# Disable the bandwidth test server
bandwidth-server set enabled=no
# Restrict Layer 2 (MAC) access to the management interface list
mac-server mac-winbox set allowed-interface-list=management
mac-server set allowed-interface-list=management
/ip
# Only allow neighbor discovery from the management interface list
neighbor discovery-settings set discover-interface-list=management
# Disable unused services
service disable telnet,ftp,api,api-ssl
# Disable DynDNS
cloud set ddns-enabled=auto update-time=no
# Use stronger encryption for SSH
ssh set strong-crypto=yes
  • The configuration above is opinionated and may not suit your needs, so please review it carefully.
  • I decided to only allow Layer 2 (MAC) access to the management interface list. If you want to allow Layer 2 access via WinBox to other interfaces, you can adjust the allowed-interface-list accordingly.
4.7.4. Firewall
The firewall configuration below is based on various sources and research, and is by no means comprehensive or a definitive reference for securing your home network. Again, please consult the official Mikrotik documentation.
/ip firewall
# Configure NAT for internet access
nat add chain=srcnat out-interface=pppoe-out action=masquerade comment="NAT for internet access"
# Traffic into the router
add chain=input   action=accept connection-state=established,related,untracked                                       comment="Allow established connections"
add chain=input   action=drop   connection-state=invalid                                                             comment="Drop invalid packets"
add chain=input   action=accept protocol=icmp        comment="Allow ICMP"
add chain=input   action=accept dst-address=127.0.0.1        comment="Allow local loopback for CAPsMAN"
add chain=input   action=accept in-interface-list=!wan dst-port=53 protocol=udp                                      comment="Allow LAN DNS queries"
add chain=input   action=accept in-interface-list=!wan dst-port=53 protocol=tcp                                      comment="Allow LAN DNS queries"
add chain=input   action=accept in-interface-list=management                                                         comment="Allow full access to the management interfaces"
add chain=input   action=accept in-interface=vlan10-owner src-address-list=owner-webfig dst-port=80,443 protocol=tcp comment="Allow restricted webfig access to the router"
add chain=input   action=drop        comment="Drop all other inputs"
# Traffic forwarded through the router
# Basics
add chain=forward action=fasttrack-connection connection-state=established,related hw-offload=yes comment="Fasttrack established connections"
add chain=forward action=accept               connection-state=established,related,untracked      comment="Allow established connections"
add chain=forward action=drop                 connection-state=invalid                            comment="Drop invalid packets"
# Inter-VLAN communication
add chain=forward action=accept connection-state=new in-interface=vlan10-owner out-interface=vlan20-iot        comment="Allow Owner -> IoT traffic"
add chain=forward action=accept connection-state=new in-interface=vlan10-owner out-interface=vlan99-management comment="Allow Owner -> Management traffic"
# Internet access
add chain=forward action=accept connection-state=new in-interface-list=management out-interface-list=wan comment="Allow internet access for management VLAN"
add chain=forward action=accept connection-state=new in-interface-list=vlan       out-interface-list=wan comment="Allow internet access for all other VLANs"
# Port forwarding
add chain=forward action=accept connection-nat-state=dstnat comment=“Allow port forwarding”
# Drop all other forwarded traffic
add chain=forward action=drop comment="Drop all other forwarded traffic"
  • The firewall configuration above is opinionated and may not suit your needs, so please review it carefully and adjust it to suit your needs.
  • You may for example not plan to use port forwarding, in which case you can remove the "Allow port forwarding" filter.
The next post will continue the guide at "5. Wi-Fi Access Point Configuration".
Continued from the previous post
Now that we have configured the router, we can configure the access points. Connect each access point to your computer using ethernet port 2 and open WinBox to connect to the access point using the MAC address.
:warning: This is a manual configuration guide for the access points, since the cAP ac APs do not fully support CAPsMAN dynamic VLAN provisioning when using the wifi-qcom-ac package. If you are using cAP ax APs please refer to the official documentation and adapt the steps below accordingly.
5.1. Basic Configuration
/system
# Set the identity
identity set name=ap1
  • Set the identity to a descriptive name for the access point (e.g. ap1, ap2).
  • See the "4.1. Basic Configuration" section for more details.
5.2. Wi-Fi interfaces
Configure the master Wi-Fi interfaces for each band (2GHz and 5GHz) to be managed by CAPsMAN, and add slave Wi-Fi interfaces for each band that will be used for the different VLANs.
/interface wifi
set [ find default-name=wifi1 ] configuration.manager=capsman .mode=ap disabled=no name=wifi-master-2ghz-vlan10
set [ find default-name=wifi2 ] configuration.manager=capsman .mode=ap disabled=no name=wifi-master-5ghz-vlan10
add disabled=no master-interface=wifi-master-2ghz-vlan10 name=wifi-slave-2ghz-vlan20
add disabled=no master-interface=wifi-master-5ghz-vlan10 name=wifi-slave-5ghz-vlan20
add disabled=no master-interface=wifi-master-2ghz-vlan10 name=wifi-slave-2ghz-vlan30
add disabled=no master-interface=wifi-master-5ghz-vlan10 name=wifi-slave-5ghz-vlan30
5.3. VLANs
Create a management VLAN interface.
/interface vlan add interface=ether1 name=vlan99-management vlan-id=99
/interface bridge add name=cap-bridge vlan-filtering=yes comment="CAP bridge"
Next we add the required bridge ports to the bridge.
# The ether1 port is a trunk port which will carry traffic for multiple VLANs.
add bridge=cap-bridge frame-types=admit-only-vlan-tagged ingress-filtering=yes interface=ether1 comment="Trunk port"
# Add all the WiFi interfaces as access ports with their respective VLAN IDs assigned via port VLAN ID
add bridge=cap-bridge interface=wifi-master-2ghz-vlan10 pvid=10 frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes comment="Access port VLAN 10 - 2Ghz"
add bridge=cap-bridge interface=wifi-master-5ghz-vlan10 pvid=10 frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes comment="Access port VLAN 10 - 5Ghz"
add bridge=cap-bridge interface=wifi-slave-2ghz-vlan20  pvid=20 frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes comment="Access port VLAN 20 - 2Ghz"
add bridge=cap-bridge interface=wifi-slave-5ghz-vlan20  pvid=20 frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes comment="Access port VLAN 20 - 5Ghz"
add bridge=cap-bridge interface=wifi-slave-2ghz-vlan30  pvid=30 frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes comment="Access port VLAN 30 - 2Ghz"
add bridge=cap-bridge interface=wifi-slave-5ghz-vlan30  pvid=30 frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes comment="Access port VLAN 30 - 5Ghz"
:warning: Do not add the management port (ether2) to the bridge, this port is used for unbridged management access only.
/interface bridge vlan
add bridge=cap-bridge tagged=cap-bridge,ether1 vlan-ids=99
add bridge=cap-bridge tagged=cap-bridge,ether1 untagged=wifi-master-2ghz-vlan10,wifi-master-5ghz-vlan10 vlan-ids=10
add bridge=cap-bridge tagged=cap-bridge,ether1 untagged=wifi-slave-2ghz-vlan20,wifi-slave-5ghz-vlan20 vlan-ids=20
add bridge=cap-bridge tagged=cap-bridge,ether1 untagged=wifi-slave-2ghz-vlan30,wifi-slave-5ghz-vlan30 vlan-ids=30
/ip
# The first access point is assigned the first available IP address in the management VLAN
address add interface=vlan99-management address=10.99.0.2/24
# Add a route to the router
route add gateway=10.99.0.1 distance=1
# Use the router for DNS
dns set servers=10.99.0.1
  • Adjust the IP address to suit your needs, but make sure it is in the management VLAN subnet.
  • For each additional access point, assign the next available IP address in the management VLAN subnet.
4.5. Security
As with the router, please consult the official Mikrotik documentation for more information on securing your access points.
4.5.1. Interface lists
member add interface=ether2            list=management comment="Dedicated management port"
member add interface=vlan99-management list=management comment="Management VLAN"
4.5.2. Disable unused services and tools
/tool
/ip
# Disable DynDNS
4.6. Enable CAP mode
Finally, we will enable CAP mode on the access points to allow them to be managed by the router's CAPsMAN.
/interface wifi
# Create the datapath
# Usually this would be done by CAPsMAN, but since we are using "wifi-qcom-ac" we have to do it manually
datapath add bridge=cap-bridge name=cap-datapath
# Enable CAP mode after everything is set up
# Set the slaves to be static to avoid CAPsMAN trying to manage them
cap set enabled=yes discovery-interfaces=vlan99-management certificate=request slaves-static=yes slaves-datapath=cap-datapath
6. Final Steps and conclusion
Both the router and access points are now configured and ready to use. Up until this point we have only used WinBox to configure the devices via the dedicated management ports, but we can now test the setup.
  1. Connect the ONT to the router's WAN port (ether1-wan).
  2. Connect the access points to the router's AP ports (ether2-ap1 and ether3-ap2).
  3. Connect your laptop or computer to the router's laptop port (ether4-laptop).
  4. Connect your Raspberry PI or other IoT devices to the router's IoT port (ether5-rpi).
  5. Connect your phone or other devices to the Wi-Fi networks.
You can now confirm that internet access is working on all devices, and that the VLANs and other configuration is working as expected.
If you experience any issues, you can always connect to the router or access points using WinBox via the dedicated management ports (ether8-management for the router and ether2 for the access points) to troubleshoot the configuration and logs.
Great step-by-step guide VLANs! I only have one minor suggestion - a firewall rule which allows port forwarding that can be disabled or removed if not used:
add action=accept chain=forward comment=“port forwarding” connection-nat-state=dstnat
Nice work indeed !!
Thank you, I’ve update the content accordingly.
I initially had a filter for port forwarding, but since then decided to make use a of reverse tunnel (cloudflared container running on the RB5009) so that I can have remote access without exposing any ports. Will likely write something up about this as well at some point.
That being said, port forwarding is very common so it makes complete sense to include it.
Great tutorial, but this should be moved to Useful user articles so it’s not lost here in the beginner section.
Thank you, that makes sense.
I’ve moved this topic and updated the title to be a bit more clear.
This is a great post. I have benn amazed at the detail put into this post. Thank you so very much for this instruction list in detail.
Would be nice to see the FULL CONFIG of both presented.
Hi, thanks for this great guide. I just ran through the steps and everything appeared to go brilliantly. The router is up and running and looks to be working as expected. The CAP, however, although up and running has a wifi issue; while both master wifi channels are transmitting the slaves are not. Looking at each slave interface the ‘General’ tab shows the interface to be enabled whilst the ‘Status’ tab has it marked disabled.
I have exported the config and compared it with my inputs with no result; all looks as expected.
I would be grateful if you could offer any ideas about what might be awry and/or what I might do to remediate the situation.
Thanks, in anticipation.
Please create new thread with your config included (remove personal info and please post between code quotes).
Put link here so we can find it back.
Thanks for the response. My new thread is here:
