Advice / help / guidance needed to build / install on-device basic bandwidth monitoring tool (inside a container), with a bit more detail for the non-technical users.
Nothing as fancy as Grafana / Prometheus for instance required, but a bit more advanced than built-in graphs functionality.
Apologies in advance for a lengthy post.
I’m a self-proclaimed member of Tinkerers Anonymous (7 years and have not been able to kick the addicition) and I am super excited with the potential containers bring to ROS.
However, my skill level on Mikrotik is still relatively low, and I have only been looking at containers / dockers for a week now (Quite a bit of learning ahead for me).
I have been able to get Pihole and Uptime Kuma set up as containers as part of my journey this week.
I understand that the routerboards have grown a lot in power, but they are still limited in terms of both CPU, RAM and storage compared to for instance an External Pi, or x86 based homelab server.
I have read through numerous posts where members advise to keep the device to its core function (good router), and leave the monitoring etc. for other devices.
Here is my home setup, and I will follow it with what I would like to accomplish. (All running the latest 7.12 Router OS)
Main Core Router - 1 x RB5009. Connected to the internet via 1) Primary - Fibre link, and 2) Auto failover to LTE router (connected via eth). This is working and reporting as expected. Attached to this is a 512 Gb SSD, connected via USB. Working as expected and currently the home for PiHole (disk1) and Uptime Kuma (disk2). I have split this disk into 5 partitions.
Passive Backup - 1 x RB4011. This is providing both the main area of the house with WiFi, and is powerful enough to handle traffic / failover / Natting / Firewalling / VPNs should the Rb5009 fail (Murphy is always lurking in a corner)
1 x HAP AX3 - Installed in another section of the house. This is part of the project to get the whole property on WiFi 6, and also to test capabilities of the unit. (Bought after the RB5009 and RB4011)
1 x HAP AX2 - Installed in workshop area, also part of the WiFi 6 project, and also test-bench (more info later). (Bought after the RB5009 and RB4011)
3 x HAP AC2 units. Part of the legacy installation and will in the next 12 months be replaced with WiFi 6 capable units.
What I would like to accomplish in a docker/container on the Mikrotik:
- Basic SNMP Monitoring with a Web front-end to show 1) Overall usage (inbound / outbound / total traffic) 2) Traffic per additional router/ap in my home network.
In short, I should be able to see if my link is saturating, and how much each of the Mikrotik devices (SNMP monitored) is contributing to the total usage.
All Mikrotiks have SNMP enabled and can currently be monitored in theory by a Grafana + Prometheus setup running on a Pi or VM.
… However, the Grafana + Prometheus is an overkill for this, and way too resource intensive to host on the Mikrotik itself (this seems to be clear).
Smaller solutions (eg. Bitmeter OS, Netdata, [feel free to suggest alternatives]), can potentially give me the graphs and detail I would like.
The reason I would like this to be working from a container on the router is that I have some friends / family that come to me for advice on IT matters (one-eyed idiot leading the blind), and I have all of them on Mikrotik devices by now. Most of them would like to have a web-page they can access from the PC / phone browser, that gives them a bit of info (and history) on the internet connection. I have tried to get them to use the built-in graphs, but a number of them ask questions like: What was my total usage in Gb for the a) last hour or b) last day? or Who is using all the data? or similar.
A lot of this info can be gleamed from super-lightweight packages like Bitmeter OS or Netdata, but most of them do not have extra computers / Pi’s lying aound for this purpose.
So, after all of that, how would I go about (if actually possible / feasible) installing a lightweight SNMP monitoring app with a web front-end on a container on the Mikrotik.
Ideally, it should be lightweight enough to work on a HAP AX2 with a small USB drive for storage.
Data does not need to be retained for extended periods (for instance, 24-72 hours should be OK)
Wishlist (over and above the aforementioned tool), but not critical for the project:
- Alerting - sending an alert in case of certain events (eg. link saturation for longer than x time, or link failing over to backup [capped solution, so cost performance implications])
- Login capability - a bit of security is never a bad thing
Dreamlist (Flights of fancy that is likely unrealistic give the processing power / other limitations):
- Very (yes very) basic protocol breakdown - so they can see if it is YouTube or Facebook or e-mails consuming the bandwidth. No need for too much detail.
- Integration into the Mikrotik API, allowing be to block an IP / MAC / etc from a web frontend. Most of my friends / family find Winbox and the Mikrotik menus etc inundating when I try to teach them,
So, after all of the above, please give some thoughts, ideas, how-to’s etc. I am sure there might be quite a number of relatively basic users that can benefit from somehting like this.
