does Mikrotik have any plans to relaunch the CRS112-8P-4S-IN with more power? Essentially as a CRS312-8P device?
KR
Oliver
KR
Oliver
Then we should aim for a CRS412-8P+4S+IN, with the CPU of the CRS418, 2.5G PoE and SFP+ ports.
Will Mikrotik even read this?
YES - more stable successor is expected. Because CRS112-8P-4S-IN sometimes is slowing down the network traffic… only reboot solves problem (for few days-few weeks). Number of ports (4xSFP+ and 8xPoE) are ideal, but we need a little more performance and much more stability!
MikroTik TEAM - we are still waiting for CRS112-8P-4S-IN successor! Do you plan to introduce it? CRS112-8P-4S-IN is very old and problematic switch, but MikroTik has no alternative solution fot it - with the same dimensions and ports numbers. So, your turn - MikroTik Team!!!
Don't talk nonsense.
I use dozens of them and have been using them since they first hit the market,
not once have they ever frozen up...
So either be more specific (eg. post config for revision) about what these problems actually are, or stop spouting bulls-t.
Asking for new hardware (in the wrong place!) is one thing,
making up crp to back up what you're saying, just like Artificial Deficence does, is something else entirely.
To be fair, the CRS112 8G is now discontinued
https://mikrotik.com/product/CRS112-8G-4S-IN
so, it is likely that soon also the 8P will be, and a replacement will be needed, the hypothetical CRS412-8P**+4S+**IN CGGXANNX suggested would surely be an useful device.
That would be useful for me too, but I’m speaking from the perspective of avoiding inaccuracies.
(And of making the person ask themselves, "Why isn't it working as well for me as it does for others?")
I have a problems with all of CRS112-8P, like other described (for instance) here:
So - it's not a nonsene, but true problem!
Well, that thread is (was) about a problem where an usually recommended to be disabled setting was instread set, Rule #5 is there for a reason:
The twelve Rules of Mikrotik Club
The rest of the whining was either about failed perceived role of the device and/or very likely rooted in mis-configuration or mis-use.
A CRS is a Switch, notwithstanding the R, that's it.
Ah, the problem is glaringly obvious.
It lies between the monitor and the chair.
Using a switch as a router...
Now I understand why mine always work without the slightest issue...
Because I use them for what they actually are... PoE switches.
Sorry, but You dont't understand...
I'm using hundrets of MikroTik equipment in my network, and I love it... But it's the only thing (that switches) that is not working propery - if I have to rebooting it once a week...
I am using it (this switches) as YOU - as PoE switches (only simple brigde - all LAN ports). THAT'S ALL!!
So, plase "Don't talk nonsense" !!!
Then avoid posting links to other topics where a multitude of varied cases are described.
Lay out your configuration, no idle chatter.
Well, what can I say?
Either I’m extremely lucky, or I’m spouting a load of bulls-t.
Take your pick:
what I write, or what you write
it could all just be lies or foolish vanity.
The fact remains that my job as (W)ISP puts food on my table (and that of the employees),
and allows me to sit here and write on the forum without too many worries...
However, that does not entitle you to deny actual cases or draw conclusions based solely on your own experiences. I am pointing out the undeniable fact that there is a problem with these devices—a fact that is real.
What version do you use at your CRS112-8P-4S devices? I am using 6.49.X (updating to latest).
Config:
add name=bridge1 priority=0x7000
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=ether7
add bridge=bridge1 interface=ether8
add bridge=bridge1 interface=sfp9
add bridge=bridge1 interface=sfp10
add bridge=bridge1 interface=sfp11
add bridge=bridge1 interface=sfp12
set enabled=no
Used 6.48.7 for years, until CVE, now all are on 6.49.22
example:
add admin-mac=DC:2C:DE:AD:BE:EF <NOTE: the MAC of ether1> auto-mac=no name=bri-dorsale priority=0x1000
add bridge=bri-dorsale interface=ether1 priority=0x50 <NOTE: from zone A>
add bridge=bri-dorsale interface=ether2 priority=0x60 <NOTE: to zone C, main>
add bridge=bri-dorsale interface=ether3 priority=0x70 <NOTE: to zone C, backup>
add bridge=bri-dorsale interface=ether4 <NOTE: local device 1>
add bridge=bri-dorsale interface=ether5 <NOTE: local device 2>
add bridge=bri-dorsale interface=ether6 <NOTE: local device 3>
(7, 8, etc. are unused)
For me /ip firewall connection tracking is set enabled=auto, the default.
You can't just write that off:
I also find it undeniable that they don't cause problems,
and I have dozens of them installed on various radio links scattered across provinces and regions...
And this brings us back to the question: am I lucky, or am I using them correctly?
Or am I lying and don't have a single one?
Do you see what I mean?
