CubeG-5ac60aypair ptp link over 30m
Hi
I'm looking at doing a ptp link between structures with the CubeG-5ac60aypair with clear LOS. It's a total distance of about 30m maximum and located in Cape Town. The only traffic we will be pushing over the link from the remote side wll come a Cisco Aironet 1560 outdoor AP. The expected traffic is not expected to be huge.
Has anyone got such link in place and what's your experience with it in the Cape Town weather, specifically in winter during rain?
Also, does anyone know if the 5Ghz failover would be any good and what the expected throughput should be on the 5Ghz on such a distance…
Tx
30 m is 1/10th to 1/20th of what a pair of cubes can do as distance, so you won’t have issues.
Surely when raining it will go down to the backup 5 GHz, but the automatic failover (and back to 60 GHz when conditions are better) is smooth, you will only experience a slower link at 5 GHz.
What you should be aware in rainy environments is that some batches of cubes have been poorly assembled/waterproofed, so you should make sure that (and in case redo yourself) the caulking is correctly made AND (IMHO) add a breather/vent valve (some new models may already have it).
AND protect the metal bracket or replace it with a good zinc coated one.
See:
Thank you for the feedback @jaclaz , points are noted..
My expectation of a ‘slower link on 5GHZ failover link’ is between 100Mb & 200Mb at a minimum. Theoretically should be more, but thats what I can live with. In your experience, that should be a reasonable expectation on the 5GHZ over such a distance correct?
Will be sure to double check the equipment with regards to the waterproofing..
Tx
At 30 m distance you need really heavy rain for the 60 GHz to fail, however (still at the little distance of around 30 m) the 5 GHz should have no issues in keeping the link at near the theoretical:
Wireless 5 GHz Max data rate 433 Mbit/s
which AFAICU should come out as 150-200 Mbit/s “real life” bandwidth, so you should be fine, but of course this greatly depends on possible interferences, which are rare or non-existing at 60 GHz, but fairly common (in cities/high density areas) at 5 Ghz.
Surely you can at installation time do a frequency scan and use the least used 5 GHz channel.
i have a similar link with a set of wap60, the link never broke even under heavy rain (~100mm) which is about maximum for our region. it didn’t even change the modulation rate, it stayed at 2.3gbps during heavy rain all the time.
Came here to say the same thing as @igorr29. At that distance, a pair of wAP60s would work fine, and a literal wall of water is required to impact the connection.
I don’t like buying the Kit, because although you don’t need the AP license for you use case, I’ve found that often there are new projects and/or the devices are repurposed. I’d buy with at least one being the AP version.
It’s roughly half the price compared to the Cube Pro.
I don’t understand.
The kit:
https://mikrotik.com/product/wireless_wire_cube_pro
has two cube pro for 298$.
The single cube:
https://mikrotik.com/product/cube_60pro_ac
is exactly half of that at 149$
The “other cube (that should be called “slice of a cube” or “very flat cube”) is this one (sa):
https://mikrotik.com/product/cubesa_60pro_ac
but it is 199$
And all of them have license level 4.
I was talking about the wAP series not the Cubes. The wireless wire kit for the wAPs has two devices, both with L3 licenses.
I think it’s better to leave the option of another connection with a wider beam.
The almost double price is of course rubbish. I don’t know what I was looking at.
Yep, but they also have no 5 Ghz backup.
If the requirement is “have normally a very fast 60 GHz link, but in case of issues failover to the slower 5 GHz” the Waps don’t seem to be suitable.
This said, I agree that at 30 m or so a 60 GHz link is very unlikely to fail even in very bad weather, so a couple Waps would allow to save a few bucks:
$228
or:
https://mikrotik.com/product/wap_60g
https://mikrotik.com/product/wap_60g_ap
114$+139$=253$<298$ for the cubes.
Thank you for all the insight and advice.
Prepared to pay a bit more to have the failover, this way I can install and walk away knowing I’m covered for worst case scenarios as well….
You don’t have Murphy’s Laws in South Africa? :wink: :rofl: .
on the contrary my good sir…its running rampant on this side of the world, however, I am confident I will have the best possible outcome with this solution…
Would maybe a couple of SxtSq ac (or ax) devices be usable.
Time for the usual automotive comparison.
Q: Can I drive a hybrid car for 400 km? I want a hybrid car because should I accidentally have the battery down I can still get home on gas.
A1 (jaclaz): yes.
A2 (lurker888): You can use an electric only car instead.
A3 (rplant): You can use a normal gasoline car instead.
To close the circle, what is missing is
A4: Why don't you instead build a railway across those 400 km?
The appropriate form would be:
A4: For only 30 m distance you will better be served by a Catx cable or better a fiber.
:roll_eyes:
