DS-Lite only works properly when sniffer/torch are active?
Hi there,
I got a new home internet connection and it’s currently using DS-Lite for IPv4 connectivity. I have already contacted the ISP and should get switched to native Dual Stack by tomorrow, but I am still wondering why my DS-Lite setup is only working properly when I activate sniffer or torch.
The setup:
  • RouterOS 7.21.3
  • IPv6 connectivity is provided via pppoe-client (mtu 1492)
  • IPv6 /56 prefix is received via dhcpv6-client
  • a public IPv6 address from the recieved prefix is assigned to the pppoe-client interface
  • dhcpv6-client has a script based on GitHub - Pieshka/routeros-dslite-script: Script for DHCPv6 client emulating DS-Lite to extract the AFTR fqdn and set it as remote address on a prepared ipipv6 tunnel interface “dslite1”
  • dslite1 properly detects actual MTU as 1452
  • dslite1 interface has IPv4 address 192.0.0.2/29 assigned
  • default IPv4 route via 192.0.0.1
  • ip firewall has mangle rules for clamping tcpmss to 1412 for tcp syn packages with in- or out-interface “dslite1”
Now, as long as I have package sniffer or torch active, this setup is working fine: I have usable IPv4 connectivity.
But as soon as I disable them, things start to break: Small packages like pings are still fine, but a simple http download is incredibly slow and my firewall logs show that the router is sending out loads of ICMP type 3 code 4 (fragmentation needed) packages on the dslite1 interface to the public IP from where I am downloading.
Now, as sniffer/torch fixes the issue, the obvious culprit would be fasttrack. However, disabling IPv4- and IPv6-fasttrack does not fix the issue!
As mentioned, I should get rid of ds-lite soon. But I’d like to get some peace of mind and would really like to understand the issue I am facing with my current setup. Any ideas?
make sure to disable keepalive on the ipip6 tunnel.
And maybe post your config too.
This also disables fasttrack/fastpath, because all traffic goes through the CPU...
Disable fasttrack/fastpath for DS-Lite...
Unfortunately disabling fastpath in ip settings and ipv6 settings does not help either.
Uhm... :face_with_raised_eyebrow:
As far as i can tell keep alive is disabled by default. Also, how is this related to the changed behavior with torch/sniffer?
Unless I'm missing something, this looks like a bug in routeros!?
You should contact support and explain the problem... the user forum can't debug all :upside_down_face:
Did you reboot the router after doing that?
I did not reboot before, but I just tried that after disabling fast path and the behaviour remains the same.
Reporting this as a bug may not make much sense, as I will probably be unable to replicate it tomorrow when the new ISP config becomes active. But maybe someone with the same issue can find this post in the future and refer to it.¯\_(ツ)_/¯
