Hello. I have searched the forum, applied what I found but I still find myself unable to finish my task, so I have turned to forums.
I went through mainly these existing threads and guides:
http://forum.mikrotik.com/t/rs305-1g-4s-map-4-devices-with-same-ip-to-different-ips/183026/4
http://forum.mikrotik.com/t/quick-guide-bidirectional-1-1-nat-snat-dnat-setup-w-working-example/183024/1
http://forum.mikrotik.com/t/multiple-ip-addresses-on-eth1-wan-nat-routing-help/158601/1
My difference from the existing threads (and yes, I am also in industrial automation world) is, that I am not trying to achieve same LAN device IPs to separate WAN IPs (as in “you have 4 PLCs with same IP, give them 4 different WAN addresses, so the other servers can address them as such”), but I am trying to make two specific IPs from LAN visible on two WAN IPs. They might be on ether2 both (another simple switch in my machine), or ether2 and ether3.
Seems similar enough, I also read that this should be doable with just a DST-NAT rule and nothing else, but I keep failing.
I set up a test network before i go poke into production as follows:
TPlink main router 10.0.80.1/24
LAN1->mikrotik hex WAN
Mikrotik hex:
WAN - 10.0.80.200, 10.0.80.201, 10.0.80.202
LAN - 192.168.250.51/24
Client device:
TPlink router with admin access from WAN enabled
WAN IP 192.168.250.1
WAN connected to LAN of mikrotik hex.
Second client device will have WAN IP 192.168.250.100, but at this moment I do not care, I first want to see the first one working.
After trying many things I have decided to reset the configuration and start with minimal changes, those being extra WAN addresses, just in case disabling the firewall rule of “drop all not coming from LAN” and adding one dst-nat rule.
If I connect to 10.0.80.0/24 network, i can ping:
I have RouterOS interface on 10.0.80.200 and 10.0.80.202
This does seem to make sense, since I applied dst-nat on 10.0.80.201, so everything should flow to my client device.
However, no tplink admin screen visible on 10.0.80.201
I made a test by placing an oscilloscope in the network as a client with 192.168.250.40. Adjust the dst-nat rule and could talk to it at 10.0.80.201:3000, so that seemed to be working, at least partially.
Tomorrow I want to make a test with actual production machine, where the clients will be PLC and HMI at 192.168.250.1 and 192.168.250.100. If I can talk to those, it is obviously the TPlink being special, but I might be missing something else.
Could you point me towards the light please? Thanks
add admin-mac=############ auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add disabled=no interface=bridge name=defconf
set enabled=yes
add address=192.168.250.51/24 comment=defconf interface=bridge network=192.168.250.0
add address=10.0.80.200/24 comment="wan primary ip" interface=ether1 network=10.0.80.0
add address=10.0.80.201/24 interface=ether1 network=10.0.80.0
add address=10.0.80.202/24 interface=ether1 network=10.0.80.0
set allow-remote-requests=yes
/ip dns static
add address=192.168.250.51 comment=defconf name=router.lan
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN" disabled=yes in-interface-list=!LAN
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=dst-nat chain=dstnat dst-address=10.0.80.201 log=yes protocol=tcp to-addresses=192.168.250.1
add action=src-nat chain=srcnat disabled=yes out-interface=ether1 src-address=192.168.250.1 to-addresses=10.0.80.201
add disabled=yes distance=1 gateway=10.0.80.1
/system clock
set time-zone-name=Europe/Belgrade
/system identity
set name=RouterOS
/tool mac-server
/tool mac-server mac-winbox
