Dual ISP Failover setup is load balancing instead
RB5009UG with latest software. Have followed setup in link below, but is not right. Instead of primary Starlink ISP with failover, it is allowing both Verizon and Starlink at same time. Links to 8.8.8.8 and 8.8.4.4 as well as secondary DNS pings are listed as unreachable. Both ISP are using dynamic IP assignment and are being automatically configured with distance of 0. I’ve tried manually creating this but the both get created again still with the distance set to 0. Any help would be appreciated thanks.
2026-03-13 16:50:35 by RouterOS 7.22
software id = LYM0-VBV6
model = RB5009UG+S+
serial number =
add admin-mac=########### auto-mac=no comment=defconf name=bridge
port-cost-mode=short vlan-filtering=yes
set [ find default-name=ether1 ] l2mtu=1514 name="1) Starlink ISP"
set [ find default-name=ether2 ] l2mtu=1514 name="2) Verizon ISP"
set [ find default-name=ether3 ] l2mtu=1514 name="3) Management"
set [ find default-name=ether4 ] l2mtu=1514 name="4) Gym"
set [ find default-name=ether5 ] l2mtu=1514 name=5
set [ find default-name=ether6 ] l2mtu=1514 name="6)"
set [ find default-name=ether7 ] l2mtu=1514 name="7) Main Livingroom"
set [ find default-name=ether8 ] l2mtu=1514 name="8) Front Livingroom"
set [ find default-name=sfp-sfpplus1 ] l2mtu=1514 name=sfp-DS1821+
/interface vlan
add interface=bridge name="AX2 2G Wifi " vlan-id=100
add interface=bridge name="AX3 2G Wifi" vlan-id=101
add interface=bridge name=Management vlan-id=10
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.101.2-192.168.101.254
add name=dhcp_pool1 ranges=10.0.10.2-10.0.10.254
add name=dhcp_pool2 ranges=10.0.0.2-10.0.0.254
add add-arp=yes address-pool=dhcp interface=bridge lease-time=10m name=
defconf
add add-arp=yes address-pool=dhcp_pool1 interface="AX3 2G Wifi" name=dhcp1
add add-arp=yes address-pool=dhcp_pool2 interface="AX2 2G Wifi " name=dhcp2
/caps-man manager
set ca-certificate=auto certificate=auto require-peer-certificate=yes
add bridge=bridge comment=defconf interface="6)" internal-path-cost=10
path-cost=10
add bridge=bridge comment=defconf interface="7) Main Livingroom"
internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface="8) Front Livingroom"
add bridge=bridge comment=defconf interface=sfp-DS1821+ internal-path-cost=10
path-cost=10
add bridge=bridge interface="3) Management" internal-path-cost=10 path-cost=
10
add bridge=bridge interface="4) Gym" internal-path-cost=10 path-cost=10
add bridge=bridge interface=5 internal-path-cost=10 path-cost=10
set udp-timeout=10s
/interface bridge vlan
add bridge=bridge tagged="8) Front Livingroom,bridge" vlan-ids=100
add bridge=bridge tagged="7) Main Livingroom,bridge" vlan-ids=101
add comment=defconf interface="1) Starlink ISP" list=WAN
add interface=Management list=LAN
add comment=defconf interface="2) Verizon ISP" list=WAN
/interface ovpn-server server
add auth=sha1,md5 mac-address=############## name=ovpn-server1
/interface wireless cap
set bridge=bridge certificate=request discovery-interfaces="2) Verizon ISP"
add address=192.168.101.1/24 comment=defconf interface=bridge network=
192.168.101.0
add address=192.168.90.1/24 interface=Management network=192.168.90.0
add address=10.0.0.1/24 interface="AX2 2G Wifi " network=10.0.0.0
add address=10.0.10.1/24 interface="AX3 2G Wifi" network=10.0.10.0
/ip arp
add address=192.168.101.2 interface=bridge mac-address=################
add address=192.168.101.240 interface=bridge mac-address=###############
add address=192.168.101.250 interface=bridge mac-address=###############
add address=192.168.101.145 interface=bridge mac-address=###############
add address=192.168.101.4 interface=bridge mac-address=###############
/ip dhcp-client
add comment=defconf interface="1) Starlink ISP" name=ether1
add comment=defconf interface="2) Verizon ISP" name=ether2
/ip dhcp-server lease
add address=192.168.101.71 client-id=############### mac-address=
############### server=defconf
add address=192.168.101.240 client-id==############### comment=Backend
mac-address=############### server=defconf
add address=192.168.101.7 client-id==############### comment="FireCube 3rd"
add address=10.0.10.5 mac-address=############### server=dhcp1
add address=10.0.10.6 client-id=############### mac-address=
add address=10.0.10.4 mac-address=############### server=dhcp1
add address=10.0.0.6 mac-address=############### server=dhcp2
add address=10.0.0.7 client-id=############### mac-address=
add address=10.0.0.9 mac-address=############### server=dhcp2
add address=192.168.101.46 client-id=############### mac-address=
add address=10.0.10.2 mac-address=############### server=dhcp1
add address=10.0.10.7 client-id=############## mac-address=
add address=192.168.101.23 client-id=############### mac-address=
add address=192.168.101.11 client-id=############### mac-address=
add address=192.168.101.18 client-id=############## mac-address=
add address=192.168.101.5 client-id=############## comment=
"FireCube 2nd" mac-address=############## server=defconf
add address=192.168.101.8 client-id=############## comment=
"FireStick 3rd" mac-address=############## server=defconf
add address=10.0.0.0/24 gateway=10.0.0.1
add address=10.0.10.0/24 gateway=10.0.10.1
add address=192.168.101.0/24 comment=defconf domain=WORKGROUP gateway=
192.168.101.1 netmask=24
set allow-remote-requests=yes
/ip firewall address-list
add address=192.168.90.0/24 list=Local-Networks
add address=10.0.0.0/24 list=Local-Networks
add address=10.0.10.0/24 list=Local-Networks
add address=192.168.101.0/24 list=Local-Networks
add action=accept chain=input comment=
"defconf: accept established,related,untracked" connection-state=
add action=drop chain=input comment="defconf: drop invalid" connection-state=
invalid
add action=drop chain=input comment="defconf: drop all not coming from LAN"
in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy"
ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy"
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
add action=accept chain=forward connection-state=new dst-address=
192.168.101.0/24 src-address=192.168.90.0/24
add action=drop chain=forward comment="defconf: drop invalid"
connection-state=invalid
"defconf: accept established,related, untracked" connection-state=
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
add action=drop chain=forward connection-state=new dst-address-list=
Local-Networks src-address-list=Local-Networks
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes
add action=dst-nat chain=dstnat comment=openvpn disabled=yes dst-port=1194
in-interface-list=WAN protocol=udp to-addresses=192.168.101.250 to-ports=
1194
add action=masquerade chain=srcnat comment=Starlink out-interface=
"1) Starlink ISP"
add action=masquerade chain=srcnat comment=Verizon out-interface=
"2) Verizon ISP"
/ip ipsec profile
add comment="Starlink tool" disabled=yes distance=1 dst-address=
192.168.100.1/32 gateway="1) Starlink ISP" pref-src="" routing-table=main
scope=30 target-scope=10
add disabled=no distance=1 dst-address=8.8.8.8/32 gateway="1) Starlink ISP"
routing-table=main scope=10
add disabled=no distance=2 dst-address=8.8.4.4/32 gateway="2) Verizon ISP"
routing-table=main scope=10 target-scope=10
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=
8.8.8.8 routing-table=main scope=11 target-scope=11
add check-gateway=ping disabled=no distance=2 dst-address=0.0.0.0/0 gateway=
8.8.4.4 routing-table=main scope=11 target-scope=11
add disabled=no dst-address=208.67.222.222/32 gateway="1) Starlink ISP"
add disabled=no distance=2 dst-address=208.67.220.220/32 gateway=
"2) Verizon ISP" routing-table=main scope=10
208.67.222.222 routing-table=main scope=11 target-scope=11
208.67.220.220 routing-table=main scope=11 target-scope=11
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface="1) Starlink ISP" type=external
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=
33434-33534 protocol=udp
"defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=
udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500
protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=
ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=
ipsec-esp
"defconf: drop everything else not coming from LAN" in-interface-list=
!LAN
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1"
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=
icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=
500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=
ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=
ipsec-esp
!LAN
/ipv6 nd
set [ find default=yes ] advertise-dns=yes
/system clock
set time-zone-autodetect=no time-zone-name=America/Chicago
/system identity
set name=RB5009UG
/system ntp server
set multicast=yes use-local-clock=yes
/tool mac-server
/tool mac-server mac-winbox
Scope 11 and target scope 11?
Check this:
I went a head and made the changes you suggested but they made no difference. None of the recursive connections work. And is still using both ISPs not in failover mode.
2026-03-14 19:11:03 by RouterOS 7.22
model = RB5009UG+S+
serial number =
add admin-mac=########## auto-mac=no comment=defconf name=bridge
/interface vlan
defconf
/caps-man manager
path-cost=10
path-cost=10
10
set udp-timeout=10s
add auth=sha1,md5 mac-address=FE:53:DE:71:83:02 name=ovpn-server1
192.168.101.0
/ip arp
/ip dhcp-client
add address=192.168.101.71 client-id=########## mac-address=
add address=192.168.101.240 client-id=########## comment=Backend
mac-address=D0:50:99:74:FE:B9 server=defconf
add address=192.168.101.7 client-id=########## comment="FireCube 3rd"
mac-address=########## server=defconf
add address=10.0.10.5 mac-address=########## server=dhcp1
add address=10.0.10.6 client-id=1:########## mac-address=
add address=10.0.10.4 mac-address=########## server=dhcp1
add address=10.0.0.6 mac-address=########## server=dhcp2
add address=10.0.0.7 client-id=1:########## mac-address=
add address=10.0.0.9 mac-address=########## server=dhcp2
add address=192.168.101.46 client-id=########## mac-address=
add address=10.0.10.2 mac-address=########## server=dhcp1
add address=10.0.10.7 client-id=########## mac-address=
add address=192.168.101.23 client-id=########## mac-address=
add address=192.168.101.11 client-id=########## mac-address=
add address=192.168.101.18 client-id=########## mac-address=
add address=192.168.101.5 client-id=########## comment=
"FireCube 2nd" mac-address=########## server=defconf
add address=192.168.101.8 client-id=########## comment=
"FireStick 3rd" mac-address=########## server=defconf
invalid
1194
"1) Starlink ISP"
"2) Verizon ISP"
/ip ipsec profile
add comment="Narrow Route" disabled=no distance=1 dst-address=8.8.8.8/32
gateway="1) Starlink ISP" routing-table=main scope=11 target-scope=10
add comment="Narrow Route" disabled=no distance=2 dst-address=8.8.4.4/32
gateway="2) Verizon ISP" routing-table=main scope=11 target-scope=10
add check-gateway=ping comment="Wide Route" disabled=no distance=1
dst-address=0.0.0.0/0 gateway=8.8.8.8 routing-table=main scope=30
target-scope=11
add check-gateway=ping comment="Wide Route" disabled=no distance=2
dst-address=0.0.0.0/0 gateway=8.8.4.4 routing-table=main scope=30
target-scope=11
dst-address=0.0.0.0/0 gateway=208.67.222.222 routing-table=main scope=30
target-scope=11
dst-address=0.0.0.0/0 gateway=208.67.220.220 routing-table=main scope=30
target-scope=11
/ip upnp
set enabled=yes
/ip upnp interfaces
invalid
icmpv6
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
ipsec-ah
ipsec-esp
!LAN
/ipv6 nd
/system clock
/system identity
set name=RB5009UG
/system ntp server
/tool mac-server
  • First, edit your two DHCP client instances, and set Default Route Distance on them to 100 and 101 instead of 1.
  • Next, you have to correct the gateway field of the 4 "narrow" routes:
    You cannot use the interface name as gateway for those routes. You can only specify the interface as gateway for connected routes (like those you see with DAC in the flags, C is for connected) or when the connection is a point-to-point connection (for example PPPoE). For the 4 "narrow" static routes (those currently with the AS flag) you manually added, you have to use the IP addresses of the gateways.
    For the routes with the blue gateway crossed out in the screenshot, use the address pointed at by the blue arrow as gateway. Do similarly with purple.
  • With those 4 routes, there is no need to put different distances (1 and 2) as seen in the screenshot, you can keep distance=1 for the 4 routes. You only need to specify different distances on the "wide" routes.
  • Also, it's recommended to click on the menu pointed at by the green arrows, and make the following in columns visible:
    • Check Gateway
    • Immediate Gateway
    • Scope
    • Target Scope
    when you experiment with recursive routes, because it would be easier to see the relationship between scope/target-scope as well as whether the correct immediate gateway has been picked up for the route.
Thank you for the help but it does raise some issues.
Firstly, I can’t change the DHCP clients default distance as these two are created by router and don’t allow me to edit them.
Secondly, the Starlink ISP is dynamic generated by Starlink equipment running in bypass mode so there is no guarantee the IP address for the gateway will stay the same.
I went ahead and made the changes you suggested (at least the ones I could) and although the Wide routes are now active, the setup is still running in load balance not failover.
2026-03-15 10:15:48 by RouterOS 7.22
model = RB5009UG+S+
serial number =
add admin-mac=############ auto-mac=no comment=defconf name=bridge
/interface vlan
defconf
/caps-man manager
path-cost=10
path-cost=10
10
set udp-timeout=10s
add auth=sha1,md5 mac-address=############ name=ovpn-server1
192.168.101.0
add address=10.0.10.1/24 interface="AX3 2G Wifi" network=10.0.10.00:09
/ip arp
/ip dhcp-client
add address=192.168.101.71 client-id=############ mac-address=
add address=192.168.101.240 client-id=############ comment=Backend
mac-address=############ server=defconf
add address=192.168.101.7 client-id=############ comment="FireCube 3rd"
add address=10.0.10.5 mac-address=############ server=dhcp1
add address=10.0.10.6 client-id=############ mac-address=
add address=10.0.10.4 mac-address=############ server=dhcp1
add address=10.0.0.6 mac-address=############ server=dhcp2
add address=10.0.0.7 client-id=############ mac-address=
add address=10.0.0.9 mac-address=############ server=dhcp2
add address=192.168.101.46 client-id=############ mac-address=
add address=10.0.10.2 mac-address=############ server=dhcp1
add address=10.0.10.7 client-id=############ mac-address=
add address=192.168.101.23 client-id=############ mac-address=
add address=192.168.101.11 client-id=############ mac-address=
add address=192.168.101.18 client-id=############ mac-address=
add address=192.168.101.5 client-id=############ comment=
"FireCube 2nd" mac-address=############ server=defconf
add address=192.168.101.8 client-id=############ comment=
"FireStick 3rd" mac-address=############ server=defconf
invalid
1194
"1) Starlink ISP"
"2) Verizon ISP"
/ip ipsec profile
gateway=100.64.0.1 routing-table=main scope=11 target-scope=10
add comment="Narrow Route" disabled=no distance=1 dst-address=8.8.4.4/32
gateway=192.168.1.1 routing-table=main scope=11 target-scope=10
target-scope=11
target-scope=11
add disabled=no distance=1 dst-address=208.67.222.222/32 gateway=100.64.0.1
add disabled=no distance=1 dst-address=208.67.220.220/32 gateway=192.168.1.1
target-scope=11
target-scope=11
/ip upnp
set enabled=yes
/ip upnp interfaces
invalid
icmpv6
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
ipsec-ah
ipsec-esp
!LAN
/ipv6 nd
/system clock
/system identity
set name=RB5009UG
/system ntp server
/tool mac-server
Yes, you have the two DAD routes (actually DAD+ as they become PCC ECMP).
And as you can see, now that the "Wide" routes are AS, they are also AS+ as they become PCC ECMP)
Increase the distance of those routes on the DHCP client on Mikrotik:
/ip dhcp-client
add comment=defconf interface="1) Starlink ISP" name=ether1 default-route-distance=100
add comment=defconf interface="2) Verizon ISP" name=ether2 default-route-distance=101
This will make the two top rules "out of the way".
Then, you have only two ISP's, so you need recursive and gateway check on only one of them, there is no difference between
  1. check if main is down, if it is use secondary, as soon as primary resumes go back to primary
  2. check if secondary is down, if it is do nothing, as soon as it resumes, do nothing
And:
  2. do nothing
So, IF your "main" is Verizon and secondary is Starlink you can still use recursive.
Otherwise, you can use Netwatch, simplest approach here:
Hello Jaclaz,
As I already stated, I cannot edit the two DHCP-clients as there are automatically created by the RB5009UG and it will not allow me to change them in any way. I have tried deleting them and creating ones manually but the router just creates it’s own again and they become the default. Is there a way to stop the router from creating the automatically? Also is this even possible with dynamic ISP addresses?
Andrew
Just a guess, but you did figure out how to add starlink and verizon to those two dhcp clients.
So did you try
IP -> DHCP CLIENT -> WHATEVER -> ADVANCED -> ROUTE DISTANCE
It's not possible AFAIK.
You have two DHCP clients in your configuration, they are configuration lines like any other.
Try disabling one of them.
Or try removing one of them.
Is It re-enabled or re-added automagically?
If yes, something is recreating them, but It Is not the normal behaviour.
Detect-internet may do that, but It doesn't seem to be enabled in your configuration.
Or maybe It doesn't show on your export?
Anyway explicitly settings detect-internet to interface list none costs nothing.
Try also disabling the two separate Nat rules and re-enable the single defconf out-interface-list=WAN one, but I doubt that those Nat rules have anything to do with the automatic recreating of DHCP clients.
I originally had the single NAT rule and they were created then too.
I only remove them, there is no disable option as it’s greyed out.
I’ve looked in the settings and detect-internet settings are set to none. I’ve seen a reference for older router software where you could add a line to manually disable this but don’t know if that is still a viable option?
You don't change the distance for those route in the IP -> Routes table, but change it by modifying the Default Route Distance property of the DHCP clients:
(this is what I wrote in the 1st bullet point of my previous post).
As for this issue, you'll need to do some scripting in the DHCP client (notice that in the screenshot above, there is a Script field where you can input the script content). Here is the documentation with the available variables:
script (script; Default: ) Execute script when DHCP client obtains a new lease or loses an existing one, received gateway address or DNS server list is changed.
Variables that are accessible for the event script:
  • bound - 1 - lease is added/changed; 0 - lease is removed
  • server-address - server address
  • lease-address - lease address provided by a server
  • interface - name of the interface on which the client is configured
  • gateway-address - gateway address provided by a server
  • vendor-specific - stores value of option 43 received from DHCP server
  • lease-options - an array of received options
And below that you have the Lease script example that shows you exactly how to modify the gateway address of an existing IP -> Routes entry with the new gateway address provided by DHCP.
You can use that script or use this simplified version adapted to your configuration (this content is to be put inside the Script textbox of the Starlink DHCP client):
:if ($bound=1) do={
    /ip route set [find dst-address=8.8.8.8/32] gateway=$"gateway-address";
    /ip route set [find dst-address=208.67.222.222/32] gateway=$"gateway-address";
This simplified version assumes that you've already have the two routes in the table (no need for the script part that tries to create them new).
Ahh, now I see :slightly_smiling_face:, we were referring to the DHCP clients, but OP attempted to change the routes generated by the DHCP clients (which being Dynamically created cannot be edited).
Hopefully:
“We are now cruising at a level of two to the power of twenty-five thousand to one against and falling, and we will be restoring normality just as soon as we are sure what is normal anyway.”
Actually, there is also a situation where RouterOS dynamically creates DHCP clients that you cannot change and for which only some parameters can be overridden at a difficult to find place.
But that is not for ethernet ports, that is for LTE interfaces. So not what he is facing here.
CGGXANNX
Okay I found the correct location and made the change to the default DHCP distance for Verizon ISP but unfortunately this failover does not work when Starlink ISP goes down. I can ping the 8.8.4.4 from the RB5009UG terminal but PCs connected the router are not getting routed through to the Verizon ISP link even if I reset the router.
As for the other issue I just went ahead and turned off bypass mode for the Starlink router (what a pain that was for the older 2nd gen Starlink). But this way it always gives the 192.168.1.1 address. Of course then had to change my Verizon ISP to 192.168.10.1 instead.
The Starlink DHCP client is still with distance 1, and it creates the top DAD+ route, you need to put its distance to 101 (or 99, whatever) so that only the narrow and wide routes get into play (and without the +).
Setting the Starlink DHCP client to 99 did the trick. Failover works perfectly now and recovers correctly too.
Thank you everyone for all the help.
Regards
Andrew
Good, now you might want to re-think about the futility of checking connectivity on the secondary (to be used as failover) route.
I will repeat how, given n connections, you only need to check the first n-1 ones as nothing changes whether the last one Is working or not with this "plain" recursive approach.
Makes sense, no need for the extra ping traffic bouncing around if it can’t actually cause any change. So I can get rid of both the 8.8.4.4 and 208.67.220.220 ping checking associated with the Verizon ISP failover Wide routes?
Thanks again,
Andrew
Yep, as a matter of fact, you can (should) re-join the narrow and wide routes for Verizon into a single one, i.e. from:
add comment="Narrow Route" disabled=no distance=1 dst-address=8.8.4.4/32 gateway=192.168.10.1 routing-table=main scope=11 target-scope=10
add check-gateway=ping comment="Wide Route" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=8.8.4.4 routing-table=main scope=30 target-scope=11
to:
add comment="Single Route" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=192.168.10.1 routing-table=main scope=30 target-scope=10
I tried this setup and the new route showed up as just S and not AS. In addition the failover was not as seamless as previous setup. It took several minutes before the Verizon ISP route became available for PCs connected to the router.
