What's new in 6.31 (2015-Aug-14 15:42): *) chr - added support for virtio disks
I tried to install RouterOS 6.31 on a VPS with:
But not run. Not detect the disk. Tested with RC6.32 and same result.
Please, ensure the driver is correct.
Thanks.
It works fine for me in QEMU / KVM. The supplied image is in .img format, I see you’re using .qcow2. Did you convert it?
I’m getting this error on a RunAbove OpenStack service. They don’t provide me any option to upload a img. I need to run my own ISO. When they create the VPS, is created with virtio/qcow2 format, I can’t edit this.
Only CHR supports it. Did you use the provided CHR image? It will not work from the regular ISO download. http://forum.mikrotik.com/t/cloud-hosted-router/89979/1
