Ethernet Interface print detail
I’m not entirely certain why I developed this, I thought it would be easyish (it was not) and a fun challenge (painful more like).
Anyhow, this script prints bits of interface ethernet and formats it in to a fairly neat table.
Is it good code? probably not, but it seems to do what I say it does. It only seems to have a hard time formatting where the original interface name is much longer or shorter then the rest.
:put "Name\tModified name\t\t\t\tOrig-mac\t\tCurrent-mac\t\tMTU\tL2MTU"
:foreach IF in=[find] do={
:local var2 [get $IF default-name]
:local var3 [get $IF name]
:local var4 [get $IF orig-mac-address]
:local var5 [get $IF mac-address]
:local var6 [get $IF mtu]
:local var7 [get $IF l2mtu]
:local var20
:if ([:len $var3] > 0) do={:set $var20 " \t\t\t "}
:if ([:len $var3] > 8) do={:set $var20 " \t\t "}
:if ([:len $var3] > 16) do={:set $var20 " \t "}
:if ([:len $var3] > 22) do={:set $var20 " "}
:put "$var2\t$var3\t$var20\t$var4\t$var5\t$var6\t$var7"
Name    Modified name                           Orig-mac                Current-mac             MTU     L2MTU
ether1  ether1 -- External                      74:4D:28:64:D7:90       74:4D:28:64:D7:90       1500    1592
ether2  ether2 -- 192.168.1.7                   74:4D:28:64:D7:91       74:4D:28:64:D7:91       1500    1592
ether3  ether3 -- 192.168.1.8                   74:4D:28:64:D7:92       74:4D:28:64:D7:92       1500    1592
ether4  ether4 -- 192.168.1.9                   74:4D:28:64:D7:93       74:4D:28:64:D7:93       1500    1592
ether5  ether5 -- 192.168.1.12                  74:4D:28:64:D7:94       74:4D:28:64:D7:94       1500    1592
ether6  ether6                                  74:4D:28:64:D7:95       74:4D:28:64:D7:95       1500    1592
ether7  ether7 - Somewhere---- Switch           74:4D:28:64:D7:96       74:4D:28:64:D7:96       1500    1592
ether8  ether8                                  74:4D:28:64:D7:97       74:4D:28:64:D7:97       1500    1592
ether9  ether9                                  74:4D:28:64:D7:98       74:4D:28:64:D7:98       1500    1592
ether10 ether10 - 192.168.1.3                   74:4D:28:64:D7:99       74:4D:28:64:D7:99       1500    1592
sfp-sfpplus1    sfp-sfpplus1                            74:4D:28:64:D7:9A       74:4D:28:64:D7:9A       1500    1600
Feel free to modify, plagiarise or provide feedback if you think it could be improved.
When you copy something, at least copy it well...
The (good ol') trick we used in DOS batches was to APPEND to the variable value a number of characters (spaces or underscores) and then TRIM it to a given length (in practice transforming the table records from delimited to fixed length).
BUT in Ros we have this nice feature discovered by Amm0:
in practice you place the beginning of each string (variable value) at a given column by "going back" to column 0 and moving forward for the desired number of characters/tabs.
If there are not too many entries (not thousands or more), you can use print as-value to fetch all data as array, to reduce the number of [get] commands to be executed, combined with the \r trick from @Amm0:
:put "Name\t\t\t\t\tModified name\t\t\t\tOrig-mac\t\tCurrent-mac\t\tMTU\tL2MTU"
:foreach d in=[/interface ethernet print as-value proplist=default-name,name,orig-mac-address,mac-address,mtu,l2mtu] do={
    :put "$($d->"default-name")\
        \r\t\t\t\t\t$($d->"name")\
        \r\t\t\t\t\t\t\t\t\t\t$($d->"orig-mac-address")\
        \t$($d->"mac-address")\
        \t$($d->"mtu")\
        \t$($d->"l2mtu")"
If you are lazy and don't care about efficiency then proplist=default-name,name,orig-mac-address,mac-address,mtu,l2mtu can also be replaced with detail. But it will consume more CPU and RAM.
:foreach d in=[/interface ethernet print as-value detail] do={
        \t$($d->"mtu")\
        \t$($d->"l2mtu")"
At the most those could be 61 lines on the:
CRS354-48G-4S+2Q+RM
49 ethernet+4 sfpplus+2 (please read as 8) qsfpplus=61
The \r trick, when combined with going one character before and putting a <space>, avoids creating stuck strings, but at most only truncated ones... :wink:
