Feature request: HSGMII for SFP >1Gbps synchronization.
As it says in the changelog, it is only available from the CLI at the moment, not Winbox.
@Florian:
Thanks for replying !
In many instances, I’ve HSGMII and 2.5Gb/s being used as if they meant exactly the same !
Any news on HSGMII support on device without switch chip, like some tilera CCR ?
Having a ZYXEL PMG3000-D20B that support 2,5G via SGMII. Is this not the same with HSGMII?
If selecting 2.5-Base-X no link will come up. Also SFP Supported does not show other than 1G Base-X.
rOS v7.18.2
Found https://github.com/Anime4000/RTL960x/blob/main/Docs/2.5Gb.md that says that the router is capable to do that. But why can i not set the speed?
