Please MikroTik, If possibleconsider implementing DCO for OpenVPN-SSTP-L2TP version 2-3-IKEV2 etc. if it is not too difficult. This will significantly improve the performance of OpenVPN-SSTP-L2TP version 2-3-IKEV2 etc. (3-4 times or even more), reduce latency and CPU load, even when using low-power devices as access servers.
Please implement in RouterOS for routers and RouterOS for virtual servers (CHR).Implement on all CPU architectures.
I request MikroTik administrators and programmers OpenVPN-SSTP-L2TP version 2-3-IKEV2 etc. Add DCO (Data Channel Override)
I said if it is possible
I searched the internet and saw that it is for OpenVPN.
This feature should be added to be compatible with other (SSTP-L2TP version 2-3-IKEV2 etc).
Please explain me if you expect that decryption/encryption wouldn't be done by CPU just because it was moved from user space to kernel? What processes kernel code?
I assume that you suggest that switching back&forth user space/kernel is waste of time.
I think that ROS i mostly kernel thing. I could be wrong. Anyone knows?
I hardly doubt the whole openvpn daemon has been re-implemented in kernel space - that'd be a massive and very risky effort.
Same goes for other networking daemons.
What DCO brings to the table is data path in kernel space: all traffic is fully processed in kernel from reception on the NIC, until it gets delivered to the related interface.
A quick test to prove its potential benefit is to take a MikroTik board that also runs on Linux/OpenWrt and compare speed with ROS.
