Would be great to be able to have the builtin OpenVPN with both TCP and UDP enabled. Currently it is just limited to one protocol and port while theorically RouterOS can allow both being enabled on different ports.
It is usefull for The Internet Enemy countries VPN access and also Road Warrior VPN access from different unknown environments each with its own limitations.
Would appreciate it if you clould kindly consider adding the feature.
I have a mikrotik router with N IP addresses. Why shouldnt I be able to assign one OVPN server instance to each IP address?!
Same applies to SSTP server configuration…
Yeah, with MikroTik there is the problem that in one router you can run only one OpenVPN server. You would need a second router or some solution using container.
+1 for multiple servers ( whatever UDP/TCP but of course different ports ) for me,
On my opnsense installs, I often create mutliple servers with different sets of allowed inside network ( sysadmin vpn with full access, user server with restricted, guest server with even more restricted)
