Firewall configuration for Wiregurd
Hi all,
I have been playing around with configuring Wireguard and while seems everything works if I delete all firewall rules, something is blocking communication if I apply my firewall rules.
Seems I need to add something, but don’t know what.
Can anybody assist please?
I have configured 2 interface lists:
public (lte1 and wireguard interface)
local (LAN bridge)
Configuration can be seen below:
→ with this I see some traffic on wireguard interface - probably keepalive?
add name=LAN
/interface wireguard
add listen-port=23292 mtu=1420 name=wireguard1
add comment=“public network” name=public
add comment=“local network” name=local
add comment=“guest network” name=guest
/interface lte apn
add apn=internet default-route-distance=1 use-network-apn=no
/interface lte
set [ find ] allow-roaming=no apn-profiles=internet name=lte1
add authentication-types=wpa2-psk eap-methods=“” mode=dynamic-keys name=WLANsec
supplicant-identity=MikroTik
/interface wireless
/ip hotspot profile
add name=dhcp_pool0 ranges=192.168.88.2-192.168.88.254
add address-pool=dhcp_pool0 disabled=no interface=LAN name=dhcp1
/ip vrf
add list=all name=main
add bridge=LAN interface=ether2
add bridge=LAN interface=wlan1
add bridge=LAN interface=wlan2
add interface=lte1 list=public
add interface=LAN list=local
add interface=wireguard1 list=public
/interface wireguard peers
add allowed-address=0.0.0.0/0 endpoint=10.22.22.22:23292 interface=
wireguard1 public-key=“yyyyy”
add address=192.168.88.1/24 interface=LAN network=192.168.88.0
add address=172.16.1.1/24 interface=wireguard1 network=172.16.1.0
/ip cloud
set ddns-enabled=yes update-time=no
add address=192.168.88.0/24 dns-server=1.1.1.1 gateway=192.168.88.1
set servers=1.1.1.1,8.8.8.8
add action=fasttrack-connection chain=forward comment=
“Enable FastTrack for all zones” connection-state=established,related
add action=jump chain=input comment=“PUBLIC —> ROUTER” in-interface-list=
public jump-target=PUBLIC-TO-ROUTER
add action=accept chain=PUBLIC-TO-ROUTER comment=Wireguard dst-port=23292
protocol=udp
add action=return chain=PUBLIC-TO-ROUTER
add action=jump chain=output comment=“PUBLIC <— ROUTER” jump-target=
ROUTER-TO-PUBLIC out-interface-list=public
add action=return chain=ROUTER-TO-PUBLIC
add action=jump chain=input comment=“LOCAL —> ROUTER” in-interface-list=local
jump-target=LOCAL-TO-ROUTER
add action=accept chain=LOCAL-TO-ROUTER
add action=jump chain=output comment=“LOCAL <— ROUTER” jump-target=
ROUTER-TO-LOCAL out-interface-list=local
add action=accept chain=ROUTER-TO-LOCAL
add action=jump chain=forward comment=“PUBLIC —> LOCAL” in-interface-list=
public jump-target=PUBLIC-TO-LOCAL out-interface-list=local
add action=accept chain=PUBLIC-TO-LOCAL connection-state=
established,related,untracked
add action=drop chain=PUBLIC-TO-LOCAL connection-state=invalid
add action=drop chain=PUBLIC-TO-LOCAL connection-nat-state=!dstnat
connection-state=new
add action=jump chain=forward comment=“PUBLIC <— LOCAL” in-interface-list=
local jump-target=LOCAL-TO-PUBLIC out-interface-list=public
add action=accept chain=LOCAL-TO-PUBLIC
add action=accept chain=input comment=“[Default policy] INPUT”
add action=drop chain=input connection-state=invalid
add action=accept chain=forward comment=“[Default policy] FORWARD”
add action=drop chain=forward connection-nat-state=!dstnat connection-state=new
in-interface-list=public
add action=reject chain=forward comment=“Forbid connections between networks”
disabled=yes reject-with=icmp-net-prohibited
add action=accept chain=output comment=“[Default policy] OUTPUT”
add action=masquerade chain=srcnat out-interface=lte1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh address=192.168.88.0/24 port=2222
set api disabled=yes
set winbox address=192.168.88.0/24
set api-ssl address=192.168.88.0/24
Cheers,
GreenSparrow
Solved by removing wireguard interface from list of public interfaces.
http://forum.mikrotik.com/t/firewall-configuration-for-wireguard-vpn/142869/1
