Hi everyone,
I finally came up with my first VLAN setup even though in a virtual environment like GNS3.
I followed the pcunite guide to set the bridge VLAN method on my virtual Mk device.
My goal would be to come up with such a setup:
Meanwhile I set this one in GNS3 just to give it a go:
Unfortunately, PC1 doesn’t get an IP from the router’s DHCP service as if there was no connection between them.
I didn’t expect that everything would work perfectly at the first attempt of course, but I didn’t understand what I got wrong.
Could you help me please? Thanks
This is my setup:
[admin@RouterSwitchAP] > export
# oct/13/2022 15:47:07 by RouterOS 7.5
# software id =
add name=BR1 protocol-mode=none vlan-filtering=yes
/interface vlan
add interface=BR1 name=BASE_VLAN vlan-id=99
add interface=BR1 name=Blue_VLAN vlan-id=30
add interface=BR1 name=Green_VLAN vlan-id=10
add interface=BR1 name=Red_VLAN vlan-id=20
/disk
set sata1 disabled=no
add name=WAN
add name=VLAN
add name=BASE
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
add name=Green_POOL ranges=10.0.10.2-10.0.10.254
add name=Red_POOL ranges=10.0.20.2-10.0.20.254
add name=Blue_POOL ranges=10.0.30.2-10.0.30.254
add address-pool=Green_POOL interface=Green_VLAN name=Green_DHCP
add address-pool=Red_POOL interface=Red_VLAN name=Red_DHCP
add address-pool=Blue_POOL interface=Blue_VLAN name=Blue_DHCP
/port
set 0 name=serial0
add bridge=BR1 frame-types=admit-only-untagged-and-priority-tagged interface=ether3 pvid=10
add bridge=BR1 frame-types=admit-only-untagged-and-priority-tagged interface=ether4 pvid=10
add bridge=BR1 frame-types=admit-only-untagged-and-priority-tagged interface=ether2 pvid=30
add bridge=BR1 interface=ether1
/interface bridge vlan
add bridge=BR1 tagged=BR1,ether1 vlan-ids=99
add bridge=BR1 tagged=ether1 untagged=ether2 vlan-ids=30
add bridge=BR1 tagged=ether1 untagged=ether3,ether4 vlan-ids=10
add bridge=BR1 tagged=ether1 vlan-ids=20
add interface=ether5 list=WAN
add interface=BASE_VLAN list=VLAN
add interface=Blue_VLAN list=VLAN
add interface=Green_VLAN list=VLAN
add interface=Red_VLAN list=VLAN
add interface=BASE_VLAN list=BASE
add address=10.0.10.1/24 interface=Green_VLAN network=10.0.10.0
add address=10.0.20.1/24 interface=Red_VLAN network=10.0.20.0
add address=10.0.30.1/24 interface=Blue_VLAN network=10.0.30.0
/ip dhcp-client
add interface=ether5 use-peer-dns=no
add address=10.0.10.0/24 dns-server=192.168.99.1 gateway=10.0.10.1
add address=10.0.20.0/24 dns-server=192.168.99.1 gateway=10.0.20.1
add address=10.0.30.0/24 dns-server=192.168.99.1 gateway=10.0.30.1
set allow-remote-requests=yes servers=1.1.1.1
add action=accept chain=input comment="Allow Estab & Related" connection-state=established,related
add action=accept chain=input comment="Allow VLAN" in-interface-list=VLAN
add action=accept chain=input comment="Allow Base_Vlan Full Access" in-interface=BASE_VLAN
add action=accept chain=forward comment="Allow Estab & Related" connection-state=established,related
add action=accept chain=forward comment="VLAN Internet Access only" connection-state=new in-interface-list=VLAN out-interface-list=WAN
add action=drop chain=forward comment=Drop
add action=masquerade chain=srcnat log=yes out-interface-list=WAN
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
/system identity
set name=RouterSwitchAP
/tool mac-server
set allowed-interface-list=BASE
/tool mac-server mac-winbox
/tool romon
set enabled=yes
