Hello all, it’s ben a good while since I’ve been on here!
Way-back-when I had a RB2011UiAS-2HnD-IN which I used as my main home router. This was connected to a pair of VDSL services via the two providers supplied ‘broadband routers’, with me using the RB2011 to load balance between the two among other things. At that time I was using some old Cisco LAN switches and APs that I’d managed to collect during my time working in the networking industry for far too many years.
Then I discovered UniFi and liked the glossy look of it and firstly changed to their APs then I got one of their LAN switches then finally (the biggest mistake) was to swap the RB2011 out for their USG (router). I think I was influenced by their nice app and interface and how it was all joined up in one place, which it is. However during the time that I’ve had the UniFi setup it’s not been the most reliable thing, I’ve had a number of random issues and the frustrating thing is that often their shiny application doesn’t show that anything is wrong, when there plainly is. The other issue is the functionality is limited via their interface and seems to be developing in features very slowly. Lastly the load-balancing has never worked properly for me. Yes you can do stuff under the hood (in their difficult to understand CLI) but you have to mess about to stop the controller (which is part of their solution) overwriting the under-the-hood changes that you have done. So I think it’s time to come back to Mikrotik where you can configure pretty much whatever you want and with a proper CLI!
So (finally) to my question(s).
I currently have 3 x AP-AC-LR APs an 8-port US-8-60W PoE switch (still using an old Cisco PoE switch too), the USG router and their controller (running on W10). This solution is for my home (including home office) and I will be connecting to my 2 x VDSL services as before (both with <20Mbps download).
My thoughts are as follows:
RB4011iGS+RM
3 x cAP ac
2 x hEX PoE (to provide PoE to the APs and also some CCTV) - then possibly still using my old Cisco switch too
Or do I collapse the routing and switching into just a CRS328-24P-4S+RM (I assume this has a fan, I would like fanless)
Or maybe the CRS112-8P-4S-IN & CSS326-24G-2S+RM
What I don’t know is what’s the key differences between the RB4011iGS+RM, CRS328-24P-4S+RM & CRS112-8P-4S-IN in relation to their routing capability. I can see that the RB4011 seems to be a lot more powerful. I will be wanting to use the router for CAPsMAN too.
One thing I noticed is that the these newer routers (compared to the RB2011) don’t have USB ports (I seem to recall the recommendation with the RB2011 to use a USB memory stick to avoid wearing out the internal storage, is this not an issue anymore?)
Any comments/thoughts appreciated.
