As for the config.
(1) This is new in that have not seen this set before…???
/ip firewall connection tracking set enabled=yes
(2) Missing dns-server for IOT vlan ???
add address=10.10.1.0/24 comment=VPN gateway=192.168.73.1 netmask=24
add address=10.10.50.0/24 comment=“VLAN500 IoT Network” gateway=10.10.50.1 \ Dns???
netmask=24
add address=192.168.73.0/24 comment=defconf dns-server=192.168.73.226
(3) Purpose of all these being allowed to router?? Why are they all admin IT folks??
/ip firewall address-list
add address=192.168.73.2-192.168.73.254 list=allowed_to_router
add address=10.10.50.2-10.10.50.254 list=allowed_to_router
add address=10.10.1.1-10.10.1.10 list=allowed_to_router
(4) Input chain rules can be simplified, so many block rules, JUST use as last rule a drop all else rule!
As to the above (3), the allowed list SHOULD ONLY BE FOR ADMIN ACCESS.
you will still need the LAN users to access DNS services of the router.
Adjusted the order…
ip firewall filter
add action=accept chain=input comment=
“defconf: accept established,related,untracked” connection-state=
add action=drop chain=input comment=“defconf: drop invalid” connection-state=
invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
“address-list for IP addresses, that are allowed to access router;”
src-address-list=allowed_to_router
add action=accept chain=input comment=VPN dst-port=1194 protocol=tcp ???******
add action=accept chain=input comment=“Allow LAN DNS queries - TCP”
connection-state=new dst-port=53 in-interface-list=LAN protocol=tcp
add action=accept chain=input comment=“Allow LAN DNS queries-UDP”
connection-state=new dst-port=53 in-interface-list=LAN protocol=udp
add action=drop chain=input comment=“drop all else”
What is the purpose of the VPN rule, just asking as its a non-standard ipsec port…
(5) Forward chain rules… Moved Forward chain vlan rule mixed in with input chain rules further down, The Vlan500 rule is not required as you have it covered with the drop all rule at the end of the forward chain. Destination NAT rule is also not required in a drop format as you have the drop rule at the end covering that. So I modified it to allow DST NAT in the accept format.
add action=accept chain=forward comment=“defconf: accept in ipsec policy”
ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy”
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
“defconf: accept established,related, untracked” connection-state=
add action=drop chain=forward comment=“defconf: drop invalid”
connection-state=invalid
add action=accept chain=forward comment=“Forward VPN to LAN” dst-address=
192.168.73.0/24 src-address=10.10.1.0/24
add action=accept chain=forward comment=“allow port forwarding”
connection-nat-state=dstnat connection-state=new in-interface-list=WAN
“Drop any input packets that get this far”
