I’m hoping someone here will be able to help me set up my new router. Just before Christmas, I bought a RouterBOARD 3011UiAS-RM and two TP-Link EAP225 wireless access points to replace my struggling Airport-based setup. Since then, I’ve been looking through the many examples of how to set up a guest network using a VLAN. I’ve failed to find enough consistency between some of the examples to feel confident about how to go about this, though I have learnt a few things along the way.
My setup and requirements are fairly simple:
- I have a Virgin cable router running in ‘dumb’ modem mode, which will connect to the RouterBoard’s ether1. External IP address comes from DHCP.
- My Home (wired) network will all connect via a 3rd party switch plugged into any of ether6-10 using the 192.168.111.0 network.
- Guest (wired) ethernet will connect to ether2 using the 192.168.222.0 network (this is VLAN ID 99).
- Access points will both connect (via a separate 3rd party PoE switch) to ether3. The access points have two SSIDs (one for Home, one for Guest). The Guest SSID is assigned to VLAN ID 99.
I realise I’m a bit weird, but I’m using 192.168.xxx.2 for the gateway.
Amongst many other threads, I read through this one: http://forum.mikrotik.com/t/sofware-vlan-bridge-on-ruteros-explained/122534/1 which was somewhat mind-blowing for a beginner such as myself! It seems there has recently been a software change that means my guest vlan requirement can be satisfied within a single bridge. If I understand correctly, this is simpler but not necessarily better in all cases due to hardware limitations. However, as far as I can tell my router has hardware that is capable of handling ‘bridge VLAN filtering’ (QCA8337). If so, I would like to take this approach. I suspect one of the reasons I have found some inconsistency between examples is because some take the single bridge approach but many others show the older multi-bridge approach. Another factor I’ve struggled with is that most examples utilise on-board radio, which is not this case for me.
I have worked out some of the simple bits:
add name=default-dhcp ranges=192.168.111.120-192.168.111.179
add name=Guest-dhcp ranges=192.168.222.10-192.168.222.254
add address=192.168.111.0/24 comment=Home dns-server=194.168.4.100,194.168.8.100 gateway=192.168.111.2 netmask=24
add address=192.168.222.0/24 comment=Guest dns-server=194.168.4.100,194.168.8.100 gateway=192.168.222.2 netmask=24
/ip route rule
add src-address=192.168.222.0/24 dst-address=192.168.111.0/24 action=drop
I don’t think I can fill in the interface field here until the bridge/vlan/interfaces have been defined:
add address=192.168.111.2/24 comment="Home gateway" interface=[PLEASE HELP] network=192.168.111.0
add address=192.168.222.2/24 comment="Guest gateway" interface=[PLEASE HELP] network=192.168.222.0
I’m pretty sure I accepted the default setup when I first setup the router, so I’m left with things like this which may need changing?:
add bridge=bridge comment=defconf interface=ether2-master
add bridge=bridge comment=defconf interface=ether6-master
add bridge=bridge comment=defconf hw=no interface=sfp1
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
add bridge=bridge interface=ether7
add bridge=bridge interface=ether8
add bridge=bridge interface=ether9
add bridge=bridge interface=ether10
Any help would be gratefully received!
Thank you.
