I’m trying to setup a guest Wifi network
Router is Mikrotik 4011, Switch is an old Netgear GS724TP, APs are Unifi U6-Lite
I’ve created the network and SSID in Unifi for my APs
I’ve created the VLAN on my managed switch and assigned it to every port as tagged
I’ve then setup everything in the Mikrotik according to what I could find in the documentation and various forum posts in the hope of creating a new VLAN Interface on bridge with a new DHCP server issuing leases from a separate “guest” pool.
When I connect a device to that network (I’ve tried many after seeing DHCP issues with Apple products), I see a lease with state offered before getting a log entry that it was offered without success. I’ve tried setting IP manually inside the new network and I’m unable to ping the router.
I’m guessing something must be working if I’m getting a lease offered from the correct DHCP server, but I’m guessing something L2 is configured incorrectly.
# may/05/2021 13:43:22 by RouterOS 6.48.2
# software id = Y7QR-K6J3
# model = RB4011iGS+
add admin-mac=00:BB:01:32:00:00 auto-mac=no comment=defconf name=bridge \
vlan-filtering=yes
set [ find default-name=ether1 ] l2mtu=1526 mtu=1508
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 max-mru=1500 max-mtu=\
1500 name=pppoe-out1 use-peer-dns=yes user=*
/interface vlan
add interface=bridge mtu=1504 name="Guest Wifi" vlan-id=93
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip kid-control
add name=Lily
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=guest ranges=192.168.93.2-192.168.93.254
add address-pool=guest bootp-support=none disabled=no interface="Guest Wifi" \
name=dhcp1
/queue simple
add limit-at=512k/512k max-limit=512k/512k name=ICMP packet-marks=icmp-pkt \
priority=6/6 target=""
add dst=pppoe-out1 max-limit=100M/0 name=queue1 target=""
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,passw\
ord,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add bridge=bridge interface=ether2
/interface bridge vlan
add bridge=bridge untagged=bridge,ether2,ether4,ether5,ether6,ether7 vlan-ids=1
add bridge=bridge tagged=bridge,ether2 vlan-ids=93
add interface=ether3 list=WAN
add interface="Guest Wifi" list=LAN
add address=192.168.88.1/24 comment=defconf interface=ether2 network=\
192.168.88.0
add address=192.168.93.1/24 comment="Guest Network" interface="Guest Wifi" \
network=192.168.93.0
/ip dhcp-client
add add-default-route=no !dhcp-options disabled=no interface=ether3
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 domain=lan \
gateway=192.168.88.1
add address=192.168.93.0/24 dns-server=192.168.93.1 gateway=192.168.93.1 \
netmask=24
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=established,related disabled=yes
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip firewall mangle
add action=mark-connection chain=prerouting new-connection-mark=icmp-con \
passthrough=yes protocol=icmp
add action=mark-connection chain=postrouting new-connection-mark=icmp-con \
add action=mark-packet chain=prerouting connection-mark=icmp-con \
new-packet-mark=icmp-pkt passthrough=yes protocol=icmp
add action=mark-packet chain=postrouting connection-mark=icmp-con \
add action=mark-connection chain=prerouting comment=\
"Mark all management traffic to this router as priority 1" \
dst-address-type=local dst-port=21,22,23,80,443,8291,8728,8729 \
new-connection-mark=p1 protocol=tcp
add action=mark-connection chain=prerouting comment="VOIP to our VOIP gateways" \
connection-mark=no-mark new-connection-mark=p1 src-address-list=\
VOIP_Gateways
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
out,none out-interface-list=WAN
add check-gateway=ping distance=1 gateway=8.8.8.8
add check-gateway=ping distance=2 gateway=8.8.4.4
add distance=1 dst-address=8.8.4.4/32 gateway=192.168.8.1 scope=10
add distance=1 dst-address=8.8.8.8/32 gateway=51.148.72.22 scope=10
/system clock
set time-zone-name=Europe/London
/tool graphing interface
add interface=pppoe-out1
/tool graphing queue
add
/tool mac-server
/tool mac-server mac-winbox
