The SoC is running ARMv5 arch under RouterOS. But:
# ubus call system board
"kernel": "6.18.41",
"hostname": "hAP-ax-S",
"system": "ARMv7 Processor rev 4 (v7l)",
"model": "MikroTik E62iUGS-2axD5axT (hAP ax S)",
"board_name": "mikrotik,e62iugs-2axd5axt",
"rootfs_type": "squashfs",
"release": {
"distribution": "OpenWrt",
"version": "SNAPSHOT",
"firmware_url": "https://downloads.openwrt.org/",
"revision": "r35779-95ba5128b6",
"target": "airoha/en7523",
"description": "OpenWrt SNAPSHOT r35779-95ba5128b6",
"builddate": "1787723702"
Wireless on this unit can be configured at max 80 MHz width on the 5 GHz band under RouterOS. Then again:
# iw list
Wiphy phy1
wiphy index: 1
max # scan SSIDs: 4
max scan IEs length: 2190 bytes
max # sched scan SSIDs: 0
max # match sets: 0
Retry short limit: 7
Retry long limit: 4
Coverage class: 2 (up to 900m)
Device supports AP-side u-APSD.
Device supports T-DLS.
Available Antennas: TX 0x3 RX 0x3
Configured Antennas: TX 0xc RX 0xc
Supported interface modes:
* IBSS
* managed
* AP
* AP/VLAN
* monitor
* mesh point
* P2P-client
* P2P-GO
Band 2:
Capabilities: 0x9ff
RX LDPC
HT20/HT40
SM Power Save disabled
RX Greenfield
RX HT20 SGI
RX HT40 SGI
TX STBC
RX STBC 1-stream
Max AMSDU length: 7935 bytes
No DSSS/CCK HT40
Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
Minimum RX AMPDU time spacing: 2 usec (0x04)
HT TX/RX MCS rate indexes supported: 0-15
VHT Capabilities (0x339939f6):
Max MPDU length: 11454
Supported Channel Width: 160 MHz
RX LDPC
short GI (80 MHz)
short GI (160/80+80 MHz)
TX STBC
SU Beamformer
SU Beamformee
MU Beamformer
MU Beamformee
RX antenna pattern consistency
TX antenna pattern consistency
VHT RX MCS set:
1 streams: MCS 0-9
2 streams: MCS 0-9
3 streams: not supported
4 streams: not supported
5 streams: not supported
6 streams: not supported
7 streams: not supported
8 streams: not supported
VHT RX highest supported: 0 Mbps
VHT TX MCS set:
1 streams: MCS 0-9
2 streams: MCS 0-9
VHT TX highest supported: 0 Mbps
VHT extended NSS: supported
HE Iftypes: managed
HE MAC Capabilities (0x08011a000040):
+HTC HE Supported
Trigger Frame MAC Padding Duration: 2
OM Control
Maximum A-MPDU Length Exponent: 3
A-MSDU in A-MPDU
HE PHY Capabilities: (0x4c704e926d09f30e4e3f00):
HE40/HE80/5GHz
HE160/5GHz
242 tone RUs/5GHz
Device Class: 1
LDPC Coding in Payload
HE SU PPDU with 1x HE-LTF and 0.8us GI
NDP with 4x HE-LTF and 3.2us GI
STBC Tx <= 80MHz
STBC Rx <= 80MHz
Full Bandwidth UL MU-MIMO
DCM Max Constellation: 2
DCM Max Constellation Rx: 2
SU Beamformer
SU Beamformee
Beamformee STS <= 80MHz: 3
Beamformee STS > 80MHz: 3
Sounding Dimensions <= 80MHz: 1
Sounding Dimensions > 80MHz: 1
Codebook Size SU Feedback
Codebook Size MU Feedback
Triggered CQI Feedback
Partial Bandwidth Extended Range
Partial Bandwidth DL MU-MIMO
PPE Threshold Present
Power Boost Factor ar
HE SU PPDU & HE PPDU 4x HE-LTF 0.8us GI
Max NC: 1
20MHz in 40MHz HE PPDU 2.4GHz
20MHz in 160/80+80MHz HE PPDU
80MHz in 160/80+80MHz HE PPDU
DCM Max BW: 1
Longer Than 16HE SIG-B OFDM Symbols
Non-Triggered CQI Feedback
TX 1024-QAM
RX 1024-QAM
RX Full BW SU Using HE MU PPDU with Compression SIGB
RX Full BW SU Using HE MU PPDU with Non-Compression SIGB
HE RX MCS and NSS set <= 80 MHz
1 streams: MCS 0-11
2 streams: MCS 0-11
HE TX MCS and NSS set <= 80 MHz
1 streams: MCS 0-11
2 streams: MCS 0-11
HE RX MCS and NSS set 160 MHz
1 streams: MCS 0-11
2 streams: MCS 0-11
HE TX MCS and NSS set 160 MHz
1 streams: MCS 0-11
2 streams: MCS 0-11
PPE Threshold 0x79 0x1c 0xc7 0x71 0x1c 0xc7 0x71
HE Iftypes: AP
HE MAC Capabilities (0x00051a081044):
+HTC HE Supported
TWT Responder
BSR
OM Control
BQR
A-MSDU in A-MPDU
OM Control UL MU Data Disable RX
HE PHY Capabilities: (0x0c204e926f09afc8000c00):
HE40/HE80/5GHz
HE160/5GHz
STBC Tx <= 80MHz
STBC Rx <= 80MHz
SU Beamformer
SU Beamformee
MU Beamformer
Triggered SU Beamforming Feedback
Triggered MU Beamforming Feedback
Max NC: 1
STBC Tx > 80MHz
STBC Rx > 80MHz
TX 1024-QAM
RX 1024-QAM
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
HE Iftypes: mesh point
HE MAC Capabilities (0x00011a000040):
+HTC HE Supported
OM Control
A-MSDU in A-MPDU
HE PHY Capabilities: (0x0c200c0000000000008000):
HE40/HE80/5GHz
HE160/5GHz
STBC Tx <= 80MHz
STBC Rx <= 80MHz
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
Frequencies:
* 5180.0 MHz [36] (23.0 dBm)
* 5200.0 MHz [40] (23.0 dBm)
* 5220.0 MHz [44] (23.0 dBm)
* 5240.0 MHz [48] (23.0 dBm)
* 5260.0 MHz [52] (23.0 dBm) (radar detection)
* 5280.0 MHz [56] (23.0 dBm) (radar detection)
* 5300.0 MHz [60] (23.0 dBm) (radar detection)
* 5320.0 MHz [64] (23.0 dBm) (radar detection)
* 5500.0 MHz [100] (24.0 dBm) (radar detection)
* 5520.0 MHz [104] (24.0 dBm) (radar detection)
* 5540.0 MHz [108] (24.0 dBm) (radar detection)
* 5560.0 MHz [112] (24.0 dBm) (radar detection)
* 5580.0 MHz [116] (24.0 dBm) (radar detection)
* 5600.0 MHz [120] (24.0 dBm) (radar detection)
* 5620.0 MHz [124] (24.0 dBm) (radar detection)
* 5640.0 MHz [128] (24.0 dBm) (radar detection)
* 5660.0 MHz [132] (24.0 dBm) (radar detection)
* 5680.0 MHz [136] (24.0 dBm) (radar detection)
* 5700.0 MHz [140] (24.0 dBm) (radar detection)
* 5720.0 MHz [144] (24.0 dBm) (radar detection)
* 5745.0 MHz [149] (24.0 dBm)
* 5765.0 MHz [153] (24.0 dBm)
* 5785.0 MHz [157] (24.0 dBm)
* 5805.0 MHz [161] (24.0 dBm)
* 5825.0 MHz [165] (24.0 dBm)
* 5845.0 MHz [169] (disabled)
* 5865.0 MHz [173] (disabled)
* 5885.0 MHz [177] (disabled)
valid interface combinations:
* #{ IBSS } <= 1, #{ AP, mesh point } <= 16, #{ managed } <= 19,
total <= 19, #channels <= 1, STA/AP BI must match, radar detect widths: { 20 MHz (no HT), 20 MHz, 40 MHz, 80 MHz, 160 MHz }
HT Capability overrides:
* MCS: ff ff ff ff ff ff ff ff ff ff
* maximum A-MSDU length
* supported channel width
* short GI for 40 MHz
* max A-MPDU length exponent
* min MPDU start spacing
max # scan plans: 1
max scan plan interval: -1
max scan plan iterations: 0
Supported extended features:
* [ VHT_IBSS ]: VHT-IBSS
* [ RRM ]: RRM
* [ BEACON_RATE_LEGACY ]: legacy beacon rate setting
* [ BEACON_RATE_HT ]: HT beacon rate setting
* [ BEACON_RATE_VHT ]: VHT beacon rate setting
* [ FILS_STA ]: STA FILS (Fast Initial Link Setup)
* [ CQM_RSSI_LIST ]: multiple CQM_RSSI_THOLD records
* [ CONTROL_PORT_OVER_NL80211 ]: control port over nl80211
* [ ACK_SIGNAL_SUPPORT ]: ack signal level support
* [ TXQS ]: FQ-CoDel-enabled intermediate TXQs
* [ SCAN_RANDOM_SN ]: use random sequence numbers in scans
* [ SCAN_MIN_PREQ_CONTENT ]: use probe request with only rate IEs in scans
* [ CAN_REPLACE_PTK0 ]: can safely replace PTK 0 when rekeying
* [ AIRTIME_FAIRNESS ]: airtime fairness scheduling
* [ STA_TX_PWR ]: TX power control per station
* [ AQL ]: Airtime Queue Limits (AQL)
* [ CONTROL_PORT_NO_PREAUTH ]: disable pre-auth over nl80211 control port support
* [ DEL_IBSS_STA ]: deletion of IBSS station support
* [ SCAN_FREQ_KHZ ]: scan on kHz frequency support
* [ CONTROL_PORT_OVER_NL80211_TX_STATUS ]: tx status for nl80211 control port support
* [ FILS_DISCOVERY ]: FILS discovery frame transmission support
* [ UNSOL_BCAST_PROBE_RESP ]: unsolicated broadcast probe response transmission support
* [ BEACON_RATE_HE ]: HE beacon rate support (AP/mesh)
* [ BSS_COLOR ]: BSS coloring support
* [ POWERED_ADDR_CHANGE ]: can change MAC address while up
iperf3 test via 5 GHz/ 160 MHz doing gigabit wifi-AX:
$ iperf3 -P2 -c 192.168.2.1
Connecting to host 192.168.2.1, port 5201
[ 5] local 192.168.2.245 port 36574 connected to 192.168.2.1 port 5201
[ 7] local 192.168.2.245 port 36586 connected to 192.168.2.1 port 5201
[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 70.4 MBytes 589 Mbits/sec 0 4.73 MBytes
[ 7] 0.00-1.00 sec 71.2 MBytes 597 Mbits/sec 0 4.67 MBytes
[SUM] 0.00-1.00 sec 142 MBytes 1.19 Gbits/sec 0
[ 5] 1.00-2.00 sec 64.2 MBytes 539 Mbits/sec 0 4.73 MBytes
[ 7] 1.00-2.00 sec 66.9 MBytes 561 Mbits/sec 0 4.67 MBytes
[SUM] 1.00-2.00 sec 131 MBytes 1.10 Gbits/sec 0
[ 5] 2.00-3.00 sec 70.5 MBytes 592 Mbits/sec 0 4.73 MBytes
[ 7] 2.00-3.00 sec 65.6 MBytes 551 Mbits/sec 0 4.67 MBytes
[SUM] 2.00-3.00 sec 136 MBytes 1.14 Gbits/sec 0
[ 5] 3.00-4.00 sec 68.2 MBytes 572 Mbits/sec 0 4.73 MBytes
[ 7] 3.00-4.00 sec 67.5 MBytes 566 Mbits/sec 0 4.67 MBytes
[SUM] 3.00-4.00 sec 136 MBytes 1.14 Gbits/sec 0
[ 5] 4.00-5.00 sec 65.9 MBytes 553 Mbits/sec 0 4.73 MBytes
[ 7] 4.00-5.00 sec 66.8 MBytes 560 Mbits/sec 0 4.67 MBytes
[SUM] 4.00-5.00 sec 133 MBytes 1.11 Gbits/sec 0
[ 5] 5.00-6.00 sec 67.9 MBytes 569 Mbits/sec 0 4.73 MBytes
[ 7] 5.00-6.00 sec 65.8 MBytes 551 Mbits/sec 0 4.67 MBytes
[SUM] 5.00-6.00 sec 134 MBytes 1.12 Gbits/sec 0
[ 5] 6.00-7.00 sec 68.8 MBytes 577 Mbits/sec 0 4.73 MBytes
[ 7] 6.00-7.00 sec 67.8 MBytes 569 Mbits/sec 0 4.67 MBytes
[SUM] 6.00-7.00 sec 136 MBytes 1.15 Gbits/sec 0
[ 5] 7.00-8.00 sec 64.0 MBytes 537 Mbits/sec 0 4.73 MBytes
[ 7] 7.00-8.00 sec 61.9 MBytes 519 Mbits/sec 0 4.67 MBytes
[SUM] 7.00-8.00 sec 126 MBytes 1.06 Gbits/sec 0
[ 5] 8.00-9.00 sec 66.9 MBytes 560 Mbits/sec 0 4.73 MBytes
[ 7] 8.00-9.00 sec 66.0 MBytes 553 Mbits/sec 0 4.67 MBytes
[SUM] 8.00-9.00 sec 133 MBytes 1.11 Gbits/sec 0
[ 5] 9.00-10.00 sec 69.8 MBytes 586 Mbits/sec 0 4.73 MBytes
[ 7] 9.00-10.00 sec 66.5 MBytes 558 Mbits/sec 0 4.67 MBytes
[SUM] 9.00-10.00 sec 136 MBytes 1.14 Gbits/sec 0
[ 5] 0.00-10.00 sec 676 MBytes 567 Mbits/sec 0 sender
[ 5] 0.00-10.04 sec 671 MBytes 561 Mbits/sec receiver
[ 7] 0.00-10.00 sec 669 MBytes 561 Mbits/sec 0 sender
[ 7] 0.00-10.04 sec 666 MBytes 557 Mbits/sec receiver
[SUM] 0.00-10.00 sec 1.31 GBytes 1.13 Gbits/sec 0 sender
[SUM] 0.00-10.04 sec 1.31 GBytes 1.12 Gbits/sec receiver
iperf Done.
iperf3 test via localhost:
# iperf3 -P2 -c 127.0.0.1
Connecting to host 127.0.0.1, port 5201
[ 5] local 127.0.0.1 port 52704 connected to 127.0.0.1 port 5201
[ 7] local 127.0.0.1 port 52718 connected to 127.0.0.1 port 5201
[ 5] 0.00-1.00 sec 138 MBytes 1.16 Gbits/sec 0 2.31 MBytes
[ 7] 0.00-1.00 sec 152 MBytes 1.27 Gbits/sec 1 2.62 MBytes
[SUM] 0.00-1.00 sec 291 MBytes 2.44 Gbits/sec 1
[ 5] 1.00-2.00 sec 142 MBytes 1.19 Gbits/sec 0 2.31 MBytes
[ 7] 1.00-2.00 sec 142 MBytes 1.19 Gbits/sec 0 2.75 MBytes
[SUM] 1.00-2.00 sec 284 MBytes 2.38 Gbits/sec 0
[ 5] 2.00-3.00 sec 144 MBytes 1.20 Gbits/sec 0 2.31 MBytes
[ 7] 2.00-3.00 sec 143 MBytes 1.20 Gbits/sec 0 2.87 MBytes
[SUM] 2.00-3.00 sec 286 MBytes 2.40 Gbits/sec 0
[ 5] 3.00-4.00 sec 142 MBytes 1.19 Gbits/sec 0 2.31 MBytes
[ 7] 3.00-4.00 sec 142 MBytes 1.19 Gbits/sec 0 3.06 MBytes
[SUM] 3.00-4.00 sec 284 MBytes 2.38 Gbits/sec 0
[ 5] 4.00-5.01 sec 143 MBytes 1.20 Gbits/sec 0 2.31 MBytes
[ 7] 4.00-5.01 sec 144 MBytes 1.20 Gbits/sec 0 3.06 MBytes
[SUM] 4.00-5.01 sec 287 MBytes 2.40 Gbits/sec 0
[ 5] 5.01-6.00 sec 142 MBytes 1.20 Gbits/sec 0 2.31 MBytes
[ 7] 5.01-6.00 sec 142 MBytes 1.20 Gbits/sec 0 3.06 MBytes
[SUM] 5.01-6.00 sec 284 MBytes 2.40 Gbits/sec 0
[ 5] 6.00-7.00 sec 143 MBytes 1.20 Gbits/sec 0 2.31 MBytes
[ 7] 6.00-7.01 sec 144 MBytes 1.20 Gbits/sec 0 3.50 MBytes
[SUM] 6.00-7.00 sec 287 MBytes 2.40 Gbits/sec 0
[ 5] 7.00-8.00 sec 142 MBytes 1.20 Gbits/sec 0 3.50 MBytes
[ 7] 7.01-8.00 sec 142 MBytes 1.20 Gbits/sec 0 3.50 MBytes
[SUM] 7.00-8.00 sec 284 MBytes 2.40 Gbits/sec 0
[ 5] 8.00-9.00 sec 144 MBytes 1.20 Gbits/sec 0 3.50 MBytes
[ 7] 8.00-9.00 sec 144 MBytes 1.20 Gbits/sec 0 3.50 MBytes
[SUM] 8.00-9.00 sec 287 MBytes 2.41 Gbits/sec 0
[ 5] 9.00-10.00 sec 143 MBytes 1.20 Gbits/sec 0 3.50 MBytes
[ 7] 9.00-10.00 sec 144 MBytes 1.20 Gbits/sec 0 3.50 MBytes
[SUM] 9.00-10.00 sec 286 MBytes 2.40 Gbits/sec 0
[ 5] 0.00-10.00 sec 1.39 GBytes 1.19 Gbits/sec 0 sender
[ 5] 0.00-10.00 sec 1.39 GBytes 1.19 Gbits/sec receiver
[ 7] 0.00-10.00 sec 1.40 GBytes 1.21 Gbits/sec 1 sender
[ 7] 0.00-10.00 sec 1.40 GBytes 1.21 Gbits/sec receiver
[SUM] 0.00-10.00 sec 2.80 GBytes 2.40 Gbits/sec 1 sender
[SUM] 0.00-10.00 sec 2.80 GBytes 2.40 Gbits/sec receiver
iperf3 Done.
Prometheus unbound!
Interested in what you see above? Head over to https://forum.openwrt.org/t/call-for-testers-openwrt-support-for-mikrotik-hap-ax-s-e62iugs-2axd5axt/253024 and have fun. ![]()
