hi! bit of a networking/mikrotik newbie here, so this might be a dumb question
i recently got a hAP ax3 with the intention of using as a wireless access point/wifi repeater with my existing router so that i can get better speeds locally over wifi to my NAS and not disrupt the rest of the households connection to the internet by ripping out the whole existing router setup, is there a configuration that allows you to do that with the hAP ax3?
also something i wanna note here is that my router is in another part of the house and i dont have a direct ethernet connection to it from where id be setting up the hAP ax3
In theory it is much better if you can use one of the radios for the link to the router and the other one for the AP clients, but of course it depends on your requirements.
