Hi all i got a quetion how can i open a port on winbox im able to do it on the Mikrotik OS Terminal
but i just cant find it in the winbox any one got an idea or any PDF File that explains the use of winbox ?
which port do you want to open ?
by default most ports are open.
lets say 666 or any port i want not the random ports 21,80,23, etc etc
i just want to know how to open a port in winbox terminal
clarify what you mean by “open port”? ![]()
ports are open by default. but maybe you mean - “forward port” ?
ohh that is what i wanted to know :H sorry for my bad engish im from Kosovo
so how can i forward a port using the winbox interface ?
go into the Firewall menu, choose NAT tab, make a new rule. The rule should be placed in DST-NAT chain.
As for the rest of the rule settings, read them manual:
http://www.mikrotik.com/testdocs/ros/3.0/qos/nat_content.php#.3.3
hi use winbox to login and check in the tab ip>services and check the port for web(www)
