How to upgrade from 6.49.2 to 7.1
I have MikroTik RB4011iGS+RM router.
7.1 does not show when I check for updates in PACKAGE LIST in WinBox.
How do I upgrade from 6.49.2 to 7.1?
Any update is working when you download package, upload to ruter and restart. I guess 7.1 will do same, but I don’t know how license will work, you should specify which hardware and which initial version was for someone who may help then
First I would check if version is ok on system:
] > system/check-installation
  status: installation is ok
and routerboard:
 system/routerboard/print
       routerboard: yes
             model: XXXX
          revision: YYY
     serial-number: BBBBBB
     firmware-type: CCCCCC
  factory-firmware: 6.47.10
  current-firmware: 6.49.2
  upgrade-firmware: 6.49.2
Current firmware and upgrade firmware should be in the same version and also the same version of your routeros
Then you have to say that you want to change from 6 channel to 7:
 > system package update set channel=upgrade
and usuall upgrade:
 >] > system package update check-for-updates
            channel: upgrade
  installed-version: 6.49.2
     latest-version: 7.1.1
             status: New version is available
] > system package update download
] > system reboot
and after reboot check again the installation and upgrade the firmware.
Best Regards,
Diego
Choose channel to “upgrade” to switch from 6.xx tree to 7.xx and after that you’ll see new long-term, stable, testing trees. Choose stable or long-term and go. Don’t forget to create binary backup before any upgrade to be able to fully recover if anything would go wrong.
Thanks!
That worked!
It’s must be the version 6.49.2?
Starting version was 6.49.2 cause is the OP request.
If you have lower version I would first do upgrades following near releases First long-term channel if needed, then stable and then upgrade from 6 to 7.
In all upgrade steps check upgrade status and firmware upgrade.
Best Regards,
Diego
