I'm trying to simulate a multi-wan network as part of a ROS upgrade from 6 to 7; I finally managed to make policy routing work, but when I'm trying to test out the IPSec configuration, the ROS client in the simulator (which is supposed to reflect the Windows clients connecting via IPSec) does not receive the split include (I see it in the client logs, but it's nowhere under /routing/route/print). Is it possible to manually add the split tunnel? If yes, what would be the gateway?
Server config
/ip ipsec mode-config add address-pool=vpnpool address-prefix-length=32 name=ikev2modeconfig split-dns=192.168.0.1 split-include=192.168.0.0/24 system-dns=no
/ip ipsec policy group add name=vpngroup
/ip ipsec profile set [ find default=yes ] dh-group=ecp256,ecp384,ecp521,modp8192,modp6144,modp4096,modp3072,modp2048 enc-algorithm=aes-256,aes-128 hash-algorithm=sha256
/ip ipsec profile add dh-group=ecp256,ecp384,ecp521,modp8192,modp6144,modp4096,modp3072,modp2048 enc-algorithm=aes-256,aes-128 hash-algorithm=sha256 name=ike2
/ip ipsec peer add exchange-mode=ike2 name=ike2 passive=yes profile=ike2
/ip ipsec identity add auth-method=digital-signature certificate=server1 generate-policy=port-strict match-by=certificate mode-config=ikev2modeconfig peer=ike2 policy-template-group=vpngroup remote-certificate=rw-client1
/ip ipsec proposal set [ find default=yes ] auth-algorithms=sha256,sha1 enc-algorithms=aes-256-cbc,aes-256-ctr,aes-256-gcm,aes-192-cbc,aes-128-cbc,aes-128-ctr,aes-128-gcm pfs-group=none
/ip ipsec proposal add auth-algorithms=sha512,sha256 enc-algorithms=chacha20poly1305,aes-256-cbc,aes-256-ctr,aes-256-gcm,aes-128-cbc,aes-128-ctr,aes-128-gcm name=ikev2proposal pfs-group=none
/ip ipsec policy add dst-address=10.10.10.0/26 group=vpngroup proposal=ikev2proposal src-address=0.0.0.0/0 template=yes
Client config
/ip ipsec mode-config add name=ike2-rw responder=no
/ip ipsec policy group add name=ike2-rw
/ip ipsec profile add dh-group=ecp256,ecp384,ecp521,modp8192,modp6144,modp4096,modp3072,modp2048 enc-algorithm=aes-256,aes-128 hash-algorithm=sha256 name=ike2-rw
/ip ipsec peer add address=REDACTED/32 exchange-mode=ike2 name=ike2-rw-client profile=ike2-rw
/ip ipsec proposal set [ find default=yes ] pfs-group=none
/ip ipsec proposal add auth-algorithms=sha512,sha256 enc-algorithms=aes-256-cbc,aes-256-ctr,aes-256-gcm,aes-128-cbc,aes-128-ctr,aes-128-gcm name=ike2-rw pfs-group=none
/ip ipsec identity add auth-method=digital-signature certificate=cert_export_rw-client1.p12_0 generate-policy=port-strict mode-config=ike2-rw peer=ike2-rw-client policy-template-group=ike2-rw
/ip ipsec policy add group=ike2-rw proposal=ike2-rw template=yes
Log from the client
2026-11-04 21:03:38 ipsec updating my selectors
2026-11-04 21:03:38 ipsec using selectors: 10.10.10.63 <=> 192.168.0.0/24
2026-11-04 21:03:38 ipsec searching for policy for selector: 10.10.10.63 <=> 192.168.0.0/24
2026-11-04 21:03:38 ipsec using policy group: ike2-rw
2026-11-04 21:03:38 ipsec generating policy
2026-11-04 21:03:38 ipsec IPsec-SA established: REDACTED[4500]->1.1.1.2[4500] spi=0xfced69
2026-11-04 21:03:38 ipsec IPsec-SA established: 1.1.1.2[4500]->REDACTED[4500] spi=0x8e6b2ef6
2026-11-04 21:03:38 ipsec processing payload: CONFIG
2026-11-04 21:03:38 ipsec attribute: internal IPv4 address size: 4
2026-11-04 21:03:38 ipsec attribute: internal IPv4 netmask size: 4
2026-11-04 21:03:38 ipsec attribute: internal IPv6 subnet size: 8
2026-11-04 21:03:38 ipsec got address 10.10.10.63
2026-11-04 21:03:38 ipsec got netmask 255.255.255.255
2026-11-04 21:03:38 ipsec got subnet 192.168.0.0/24
2026-11-04 21:03:38 ipsec using strict match: 10.10.10.63 <=> 192.168.0.0/24
Routing/route/print from the client
[admin@remote_workforce] /ip/ipsec> /routing/route/print
Flags: U - UNREACHABLE, A - ACTIVE; c - CONNECT, s - STATIC
Columns: DST-ADDRESS, GATEWAY, AFI, ROUTING-TABLE, DISTANCE, SCOPE,
TARGET-SCOPE, IMMEDIATE-GW
DST-ADDRESS GATEWAY AFI ROUT DISTANCE SCOPE TA IMMEDIATE-GW
As 0.0.0.0/0 1.1.1.1 ip main 1 30 10 1.1.1.1%ether9
Ac 1.1.1.0/24 ether9 ip main 0 10 5 ether9
Ac 10.10.10.63/32 ether9 ip main 0 10 5 ether9
Ac ::1/128 lo ipv6 main 0 10 5 lo
Ac fe80::%ether9/64 ether9 ipv6 main 0 10 5 ether9
Uc fe80::%ether16/64 ether16 ipv6 main 0 10 5
A lo link main 0
A ether9 link main 0
