IPSEC VPN only works one way
Hi, I have an IPSEC VPN setup and working and link established. This uses Hap lite over MTN LTE. The scenario is as follows;
Lan 1 is as follows, PC to HAP port 2, HAP port 1 to router
PC1 IP 192.168.31.2
Hap1 IP 192.168.31.1 / 192.168.8.100
Router1 192.168.8.1
Lan 2 is as follows. PC2(Server) port 2 to Hap Port 2, HAP Port 2 to Switch(LAN), Router Port 1 to Switch(LAN)
PC2 Lan Port 1 IP 192.168.6.250
PC2 Lan port 2 IP 192.168.32.2
Hap2 IP 192.168.32.1 / 192.168.33.3
Router2 192.168.33.1
I have NAT setup on both Mikrotiks as follows
HAP1 - srcnat - src ip 192.168.31.0/24 Dest ip 192.168.32.0/24
HAP2 - srcnat - src ip 192.168.32.0/24 Dest ip 192.168.31.0/24
I can ping from PC1 to 192.168.32.1 and looking at my ipsec active peers it shows the data going through the tunnel. However if I ping from any winbox terminal to any IP or from any PC to any other IP, beside local IPS, I get a timeout. Firewalls on PC and server is switched off. What would cause this issue. (I suspect this could be a bridge issue, but this is the default config that I have setup, just changed IP addresses.)
Can you please draw a diagram? Others might understand this network without a diagram, but I’m not confused.
Check if any of these helps:
