IPv6 Mangle routing-mark?
Hi, I just found IPv6 routing-mark seems to be supported from v7beta1 (https://help.mikrotik.com/docs/display/ROS/v7+Routing+Protocol+Status)
So I download chr-7.1beta2 to try, the “mark routing” didn’t appear in the winbox mangle action.
I switch to CLI. I’ve already use “routing/table/add”, a table named “rtab-1” available in print,
also ipv4 mark routing choice,
but not available in ipv6.
Is that a wrong syntax or I need to add something special in rtab for ipv6?
I hope they release v7 soon with all the improvements and IPv6 policy routing. I can’t set up recursive routing failover on IPv6 on v6 and it’s a pain in the ass.
Works as expected, note that routing table should be able to add routes in FIB:
[admin@MikroTik] /routing/table> add name=test fib
[admin@MikroTik] /routing/table> /ipv6/firewall/mangle
[admin@MikroTik] /ipv6/firewall/mangle> add action=mark-routing new-routing-mark=test
chain: input
[admin@MikroTik] /ipv6/firewall/mangle> print
Flags: X - disabled, I - invalid; D - dynamic
 0    chain=input action=mark-routing new-routing-mark=test
Also recursive routing is working if you set up scopes and target scopes correctly.
can you please check my post http://forum.mikrotik.com/t/routing-table-parameter-for-ipv6-routes-not-in-effect-v7-5/161488/1
