Friends, help calculate the track and its reliability.
Going to do PTMP.
As the base I want to use Wap
The first client at a distance of 160 m. LHG
The second and third on the same building at a distance of 490 m. LHG
How much such a link will be reliable, whether there will be frequent problems with it. What signal do I expect from distant links?
I am reporting some weird findings. The device is connected on an HP A5500 48port PoE+ switch worth 7,000+ euros. There are 3 other LHG60 on the same switch all working properly/normally. There are 35 VoIP phones on the same switch all working properly.
Even when switching off the PoE power from the switch port the antenna stays on! Or at least its LEDs are on.
It will only go off when disconnecting the ground cable!
The weird findings continue. When disconnecting the ground cable the problematic antenna comes back to life and the link works. When connecting back the ground cable it goes crazy again.
The same ground is used for all the other 4 LHG60s on that roof and the rest behave/work normally.
Should I use the ground or not? Is it better to use the Ubiquiti surge arrestors instead of the ground? Should I use both?
I had people check the earthing itself and it is fine.
Why?
UBNT will deliver such product, and there would be an AP as well, so why ask them here thinks that they know from the beginning of there
60 GHz Productlinie.
Again, Mikrotik Wireless is dead end, they are sleeping!
LHG60 is great and available (for a while now). It runs ROS which is way better than AirOS. So wrong thread to blame them sleeping. This new gear looks very small. So I guess gain is between WAP 60G and LHG60G. If you need 5GHz Backup use SXT or combine LHG60G with af5xhd using a powerbox pro.
On 60GHz WAP radio PCB, there is place for 5GHz radio chips, but it was never used. Mikrotik appears to be just sleeping, while competition is creeping closer and closer and may beat them at their own 60GHz game…
Hopefully this will be a wakeup call and we will see some new 60GHz gear soon. They must have known about Ubiquity releasing their 60GHz solution for some time.
Next months will tell us more.
if we see new 60GHz radios with real new features and improvements, there is still hope MIkrotik R&D have been actually doing something for past months. Question is how long it will take to get new devices certified and released to the market
if no new devices are announced or they just release minor updated version (let’s make a dish metal and call it a day…) it’s probably not very good sign. At that point all that Mikrotik can do is they can start lowering the prices of existing 60GHz gear when Ubiquity releases their 60GHz hardware, but that would mean they have nothing new and all they can do is to lower prices to stay in the game… not good.
The range will depend on the used antennas. PTP links will be part of the mesh. I hope different Vendors will be compatible as Radwin and Cambium has announced terragraph, too.
Hej guys, I have 750m PTP link to do and three small 230V wires by the road between these two points. Is it ok to use LHG60 kit ? I don’t need 1Gbps throughput, 300Mbps will be ok. What about rain and snow, I want to sleep well
I understand however this is just the roof of the building without any RF tower on it. All the cables going up to the roof are 35-40m Ubiquiti Touch cable. 4 LHG60s doing PTP links. All connected to the same ground. All working fine except this one
