[LoRa] Support for Meshtastic?
Hello!
Would it be possible for the LoRa devices to support Meshtastic in addition to The Things Network?
https://meshtastic.org/
I have an RBwAPR-2nD and would like to use it as a Meshtastic repeater or as a client-mute to be able to route chats via MQTT.
No, you just have access to the LoRaWAN protocol, which does not have a peer-to-peer scheme. Meshtastic is custom firmware that use custom modulation scheme. And Meshtastic does not need any gateway, which is it's raison d'être, and so it more for Andrino-like devices than on say a wAP devices with no display.
Now, if you want a DIY solution for Chat, and willing to give up the mesh-abilities (and thus need the wAP LoRa gateway).... You can use a container with the "backend" of LoRaWAN locally to avoid the cloud. For example, https://www.chirpstack.io. And the backend let you route MQTT as desired.
I know MikroTik has made running OpenWRT slight easier in recent routerboot firmware... so perhaps with a lot of work/research, you might be able to repurpose the wAP for Meshtastic. But it be tough hill to climb for that. And still not sure possible.
Of course Meshtastic is already being followed up by MeshCore, so when implementing such protocols the work never ends…
True. And in the Meshtastic (or MeshCore) scheme, a "repeater" can still be a Aurdino-like device, just with "bigger" antennas and better placement.
And if one wanted MikroTik scripting to interact with Meshtastic it be cheaper and easier to just use /tool/fetch to the Meshtastic API on the cheaper Aurdino-like device with Meshtastic/MeshCore firmware all setup.
While perhaps /container might (but unlikely) allow the LoRa radio to be wired to a container that could run some Mestastic/MeshCore code to do this, but even then no LoRa devices ARM-based, so no containers. So $20-40 for small board with LoRa radio running Meshtastic seems WAY WAY easier and less risk.
I did play with LoRaWAN a bit for fun, see Experiments with [:convert] for bits&bytes +CSV from /iot/.... I didn't write it up, but I did have some LoRa Aurdino's (that I had previously played with Meshtastic on, but using the LoRaWAN firmware get them to display messages from LoRaWAN with MQTT to the broker/lorawan-server described in the post – all running on MikroTik locally. So I know this is possible if you have some specific need – but to build a general "chat" app that be harder using "pure" LoRaWAN.
And we actually do use LoRaWAN+KNOTs at some site for Victron solar/power reporting to their VRM console (since Victron has LoRaWAN module but need gateway like KNOT) – which all works extremely well.
