But low reception at 50 meters is definitely not normal, the mantbox Ax 15 s is (should be) capable of km links.
Indeed, but probably I am doing something wrong.
My friend is using an Android phone. He wasn’t able to see the WIFI network from that point. The Antenna is at 3 meters high under a vertical angle of 10 degrees below.
I left the tx-power and antenna-gain unset, because according to the documentation it should be sending max allowed.
Do you know where I can find out what the values antenna-gain and min_antenna_gain(is blank in CAPSMAN) are currently set to, so I can verify it is set correctly?
It looks like he is using Capsman v1 which will not work on AX access points right?
My friends setup is working fine, but need some tweaking. I just want to verify the antenna_gain and min_antenna_gain is set correctly, but don’t know where to find it. Also /interface wifi print detail won’t show me.
I echo these statements. Deployed mANTBox 15 ax to replace an existing “AC” Wifi5 Access point that took a lightning hit. The mANTBOx 15 AX is poor replacement.
Same issue here, 3 mantbox ax on a mast. Around the mast there is no ssid seen on devices. Only at longer distance (like 100m) you can see the ssid.
The mantboxes are managed by capsman. Annoying too is that you can’t even use channels without DFS, like 5180, it’s not accepted.
Compared to the old mantboxes, it’s a major disapointment…
Did anyone get it to work for like in a field on a campsite, or a citysquare. In other words, not only used with long distance routeros client devices?
Still issues here as well. Open ticket with MIkroTik. I have a SUP and they finally responded with some bullshit reply. There is an issue and they refuse to take it seriously.
per your config export, I do not use 20/40Mhz channel configuration on my setups. Only 20Mhz for 2Ghz frequency, and I'm not manually setting tx power.
With you manually setting Tx power, have you had better success with the mantbox ax acting as an access point?
Good to see you post @gotsprings. We've been slowly joining you and transitioning to "greener" [less trouble] pastures over to the 'Bium' side.
Interesting that you're manually specifying channel frequencies at the provisioned CAP interface from the CAPsMAN server level. Are you noticing the frequencies are NOT being applied from the provisioning profiles?
I have these frequencies defined for the customers provisioning profiles. We have CAPsMAN deployed for a few customers, but chomping at the opportunities to migrate away....
This mANTBox AX that replaced a failed AC from a lightning hit - and the performance & range has been poor. I will mess with setting manual frequencies. Although, this customer [campground] we're working on project to replace all the 'Tiks for another vendor.
I set the channels that it could pick. I don't go in and set the specific channels anymore. Those 2 profiles let the APs pick USEABLE channels and I have not seen them overlap in the last few weeks.
In reality, this integrated antenna or sector model is designed for multipoints, but with CPE client equipment, not for end devices. I see more benefits and advantages in using it for CP multipoints. A clear example is that your friend is below the sector and has a poor signal, and that is a response to the technology you have implemented.
