Migration process from our old phpBB instance to Discourse is now done
Since the move to Discourse I've encountered many more cases of new user accounts posting some AI generated generic answer in a thread, then coming backs days or weeks later to edit the post and insert a spam link. Here is a recent example where the edit is made after over two weeks:
Discourse is probably more friendly to bots than the archaic phpBB and there are more tools for automation. Can you somehow restrict this? Maybe accounts younger than 6 months can only edit their posts within a couple of hours max after the posts' creation time?
That thread is also a spam fest, with the three posts at the bottom all posing spam links. And even the first answer somehow inserted a link into the quote🤣
All cleaned up.
You can use flag to report such posts so it gets attention faster.
New users nowadays need to be approved before they can post and quite a bit are already stopped there.
But what happens afterwards, that's another thing.
Not a bad suggestion...
At least on Invision boards there was a setting that prevented users with less than n posts to edit their posts for x days.
The "sweet spot" to be not too inconvenient for legitimate users was, if I recall correctly, n=3, x=5.
@MatiasMK88 what's your problem? Putting dislikes for 2-month old posts that are already solved? Are you ok?
Again...
global-balancer-d.mikrotik.com [159.148.147.244]
global-balancer-d.mikrotik.com [2a02:610:7501:3000::244]
Either I'm blessed or You are cursed: after migrating for this new forum this is one annoyance that got behind. At least for me.
As I said: either I'm blessed or You are cursed.
Sorry, couldn't resist. :smiley:
This do 500 for me, for you?
https://forum.mikrotik.com/u/rextended/summary.json
This work
https://forum.mikrotik.com/u/paternot/summary.json
This not:
https://forum.mikrotik.com/u/holvoetn/summary.json
What are these jsons? I have 500 for all of them
Are the user summary,
like:
https://forum.mikrotik.com/u/rextended/summary (error 500)
https://forum.mikrotik.com/u/teslasystems/summary (not exist in your case)
https://forum.mikrotik.com/u/holvoetn/summary (error 500)
https://forum.mikrotik.com/u/paternot/summary (work)
Understood. I can't open any of these profiles (except mine), 500 for all. Though, user cards are opened normally.
All three of them worked for me.
Using Brave 1.81.131 and OpenSuse 15.6
Yeah, now they do work for me either.
Well, earlier I had quite a few 500's on normal forum pages:
Too bad that when the 500's happened, the site's feedback category gave - guess what? - an identical Oops error ... :roll_eyes:
Saw a couple of those as well today...
Isn't that just the same as it was with PHPbb? Overload of the back-and servers due to DoS?
Actually (now) is fixed
I don't come here often, so I've only now noticed the change. I must thus post my extremely constructive criticism:
doctor-who-redecorated
On a more serious note, though, I like markdown, I like the layout for post replies, and I like how post reply drafts are now saved automatically if you leave the page. I also like the general direction chosen. For the longest time, it felt like MT was stuck in the late 2000s with software and hardware design and functionality. I'm glad that's changing, and I'm glad it's happening without the modern ens**ttification culture making it anywhere near the decision-making process.
However, the new forum UI also does suffer from the modern plague of "let's give the UI elements more breathing space". Mobile UI needs more breathing space, yes, because you'll be tapping with your fingers. Desktop UI, however, needs more density, because you'll be clicking your mouse, which is a precise input method. Having a switch which essentially manipulates page scaling doesn't help, because the devil is in the margins and margin-to-content ratio, not in overall UI element scale.
The new forum UI is also quite unoptimized when it comes to long topics with many posts. I've scrolled down through all of this topic's posts, and I've had to reload the page just to write this post, because the UI was lagging so bad I couldn't even write anything. The delay between me pressing a button on the keyboard and the letter appearing was 1-3 seconds. I'm not an expert, but I think if your UI performance is measured in seconds per frame, then something has gone terribly wrong. And it's not like I have an underpowered system, either. I've 32 GB of RAM and a 2080 Ti. There's a good chance I'll have a better framerate in fully raytraced Cyberpunk 2077 than in the forum UI with a fully loaded topic, lol.
So all in all, plsfix.
Nice that you brought all the obvious points forward for the umpteenth time, but you obviously missed the fact tha tyou can configure these things to your own liking.
You also obviously missed the scrollbar in the top right where you can scroll the entire article quickly to any position.
Imo, it's worth reiterating both the positive and the negative points even if everything has already been said, as it's just more feedback for MT forum admins. With the negative points, more feedback increases the chances of things getting fixed, and with the positive ones, they're just worth reiterating regardless, since the Internet in general is overwhelmingly negative. Idk about you, but I tend to work best when I have something positive to look forward to, as opposed to something negative that I have to fix.
No, I didn't. Yes, using the scrollbar would indeed bypass loading the whole topic and thus get rid of the lag in most circumstances. However, I still think the UI lag is a legitimate issue that should be addressed. Reasons being, (1) there are cases when you might want to look through the whole topic and (2) UI performance in general should not depend on the time you spent on the page, and it's bad if you have to reload the page after 100 posts just to get adequate UI performance again. If it drops to 0.5 FPS after 600 posts on a powerful system, that probably means it'll drop to something like 20 FPS after 50 posts on a relatively normal one. Which is, idk... Bad?
P.S. I also like how the forum doesn't automatically quote the whole message when you click 'Reply' now. Finally, an end to the endless quoting!
Again error..
Aws::S3::Errors::Http501Error
When I try to upload the error image, and on some post, I do not see at all images, all with wrong domain DOESN'T EXIST:
Reported errors:
https://data-discourse.cdn.mikrotik.com wrong domain DOESN'T EXIST
data-discourse.cdn.mikrotik.com -> s3.cdn.mikrotik.com [159.148.147.244] [2a02:610:7501:3000::244]
forum.mikrotik.com -> global-balancer-d.mikrotik.com [159.148.147.244] [2a02:610:7501:3000::244]
Another with no image:
