MikroTik hAP ax S CAPsMAN: 5 GHz client downlink often stuck at 54 Mbps while another client on same AP is fast
Hi all,
I am troubleshooting a MikroTik WiFi/CAPsMAN issue and would like input from people with real RouterOS WiFi experience.
The summary below is summarised by an LLM but it is really me looking for answers. Hope somebody can help me find this culprit...
Setup
• ⁠hEX S as router and WiFi CAPsMAN controller
• ⁠ hAP ax S as CAPs
• ⁠Local forwarding, traffic processing on CAP
• ⁠FT enabled
• ⁠FT-over-DS enabled
• ⁠GHz fixed channel layout per AP
• ⁠AX enabled
• ⁠Steering enabled with RRM/WNM
• ⁠CAPs are version aligned
Problem
Some 5 GHz clients randomly get very low throughput, often around 10 to 15 Mbps, even with good signal and even when standing close to the AP.
The best example I have:
Same AP, same SSID, same channel, same time:
Fast Mac:
AP: AP-1 / cap-wifi1
Channel: 5200 MHz / 40 MHz
RSSI around -64 dBm
802.11ax
MCS 8
NSS 2
Client shows TX rate around 412 Mbps
MikroTik registration table shows tx-rate around 300 to 413 Mbps
Slow phone:
AP: same AP-1 / cap-wifi1
Same 5 GHz SSID
Similar signal, around -58 to -64 dBm
802.11ax
auth-type=ft-wpa2-psk
MikroTik registration table shows:
tx-rate=54.0Mbps
rx-rate=325.0Mbps to 458.8Mbps
Real throughput around 10 to 15 Mbps
So the symptom seems to be: CAP-to-client downlink rate gets stuck at 54 Mbps, while client-to-CAP rate remains high.
This is not only one phone. I have seen the low-throughput behavior on multiple devices. The phone is just the cleanest current example.
Before this setup I used TP-Link Deco consumer APs in the same house and did not have this issue.
What has already been tested or confirmed
• ⁠hEX S routing is not the bottleneck
• ⁠CPU is low during the issue
• ⁠Wired speed is fine
• ⁠A Mac on the same AP can be fast while another device is slow
• ⁠GHz is not the issue
• ⁠GHz channel plan was adjusted to reduce overlap
• ⁠FT must remain enabled because roaming is worse without it
• ⁠FT-over-DS is currently enabled and should remain enabled unless there is a specific known reason not to use it
• ⁠Steering was softened
• ⁠tx-power reduction was tested and did not fix it
• ⁠All CAPs are now version aligned
• ⁠Issue can happen even when close to the AP, so it is not just sticky-client distance behavior
• ⁠Same AP and channel can serve one client fast and another client slowly at the same time
Current 5 GHz layout
AP-1: 5180,5200
AP-2: 5180,5200
AP-3: 5540,5560
AP-4: 5500,5520
AP-5: 5220,5240
The intentional channel reuse is between APs that are physically separated.
Current 5 GHz settings summary
band=5ghz-ax
width=20/40mhz
WPA2-PSK
ft=yes
ft-over-ds=yes
connect-priority=0/1
rrm=yes
wnm=yes
transition-threshold=-70
transition-threshold-time=10s
transition-request-period=20s
transition-request-count=2
transition-time=30s
multicast-enhance=enabled
local forwarding / traffic processing on CAP
Sanitized MikroTik evidence
RouterOS=7.22.2
controller=hEX S
CAPs=5x hAP ax S
CPU during issue=low, around 3 to 5 percent in captured profile
wireless CPU around 0.5 percent in captured profile
CAP summary:
CAP-1 state=Ok version=7.22.2
CAP-2 state=Ok version=7.22.2
CAP-3 state=Ok version=7.22.2
CAP-4 state=Ok version=7.22.2
CAP-5 state=Ok version=7.22.2
5 GHz AP config summary:
AP-1 if=cap-wifi1 ssid=SSID-5G band=5ghz-ax width=20/40mhz freq=5180,5200 auth=wpa2-psk ft=yes ft-over-ds=yes connect-priority=0/1 multicast-enhance=enabled rrm=yes wnm=yes threshold=-70
AP-2 if=cap-wifi4 ssid=SSID-5G band=5ghz-ax width=20/40mhz freq=5180,5200 auth=wpa2-psk ft=yes ft-over-ds=yes connect-priority=0/1 multicast-enhance=enabled rrm=yes wnm=yes threshold=-70
AP-3 if=cap-wifi6 ssid=SSID-5G band=5ghz-ax width=20/40mhz freq=5540,5560 auth=wpa2-psk ft=yes ft-over-ds=yes connect-priority=0/1 multicast-enhance=enabled rrm=yes wnm=yes threshold=-70
AP-4 if=cap-wifi8 ssid=SSID-5G band=5ghz-ax width=20/40mhz freq=5500,5520 auth=wpa2-psk ft=yes ft-over-ds=yes connect-priority=0/1 multicast-enhance=enabled rrm=yes wnm=yes threshold=-70
AP-5 if=cap-wifi10 ssid=SSID-5G band=5ghz-ax width=20/40mhz freq=5220,5240 auth=wpa2-psk ft=yes ft-over-ds=yes connect-priority=0/1 multicast-enhance=enabled rrm=yes wnm=yes threshold=-70
Fast client example:
CLIENT-FAST if=cap-wifi1 signal=-65 auth=ft-wpa2-psk band=5ghz-ax tx-rate=309.7Mbps to 413.0Mbps rx-rate=390.0Mbps to 413.0Mbps
Slow client example:
CLIENT-SLOW if=cap-wifi1 signal=-58 to -64 auth=ft-wpa2-psk band=5ghz-ax tx-rate=54.0Mbps rx-rate=325.0Mbps to 458.8Mbps
Other observed slow-style row:
CLIENT-OTHER if=cap-wifi6 signal=-49 auth=ft-wpa2-psk band=5ghz-ac tx-rate=54.0Mbps rx-rate=400.0Mbps
Interpretation:
Same AP, same SSID, same channel, similar signal.
One station is fast.
Another station is stuck at CAP-to-client tx-rate=54Mbps.
Question
Which MikroTik WiFi/CAPsMAN setting or known RouterOS WiFi behavior can cause a per-station CAP-to-client TX rate to stick at 54 Mbps, while another client on the same AP/channel is fast?
I can't find my old message...
I had a similar problem and solved it by disabling FT over DS.
I don't know why, but iPads and iPhones slowed down significantly as soon as they roamed.
With FT over Air the speed remained stable even after roaming.
I also reported this to support, since I only have it when I set up hAP ax S (Mediatek), but no response...
Thx will try it. Did it influence client switching between ap’s?
No, roaming works perfectly for me.
Clients switch from one hAP ax S to another very quickly and seamlessly.
i switch it of and initialy that increased speed, but now after another roam the speed dropped again, it is like changing a setting in capsman can initially refresh the connectio to get high speeds again but then after a roam it drops again. I had the same thing when I enabled multicast enhancement, thought that was the fix, but it dropped after the next roam again.
Seems changing a setting in Capsman creates a fresh session with high speeds but upon roam it somehow goes to this low speed state untill the next refresh.
I think the problem here is hap ax s. I read so much trouble stories - they all begin with "I have hap ax s". Try 7.23rc.
thx, I bought 6 ;-).
Not sure if I want to run the beta, bit then again could try it on one device.
You're using an effectively beta device ... so you could run beta ROS as well :wink:
Completely serious.
Do you still have ft-over-ds=yes or ft-over-ds=no in your setup?
Mine is very simple...
auth=wpa2-psk,wpa3-psk connect-priority=0/1 disable-pmkid=yes disabled=no ft=yes management-protection=allowed wps=disable
Anyway they are the same problems I had...
Fair point.
I removed the setting complete with the minus in the setting window. Should I set it to 0 explicitly?
I prefer using unset (somthing like unset value-name=[property name])
Saw similar issues with iOS devices.
My setup is
1x 5009 (inet router) running CAPsMAN
2x hAP S ax
After upgrading everything to 7.22.2 and then re-provisioning the APs, 5g was solid.
I then decided to switch the router to Long-Term channel (cos production) and “downgraded” to 7.21.4 and the problem returned. Have now reverted to “Stable” (7.22.3) and problem has gone away again. From this it would appear that it is an issue with the way CAPsMAN is provisioning the hAP S ax that was fixed by, at least 7.22.2
Thanx for all the advice. Seems to be stable here now.
I did a few things
Disabled FT over DS
Updated all devices to 7.23 and reprovisoned.
Also did some per AP channel management.
So I can not be 100% sure which one did the trick but am stable now and will leave it like this now.
Thx all!
I'm 99% sure that vast majority of improvement came from ROS version[*] and small minority from channel setup optimization. FT in most cases works fine, in some cases it doesn't work (so stations still attach and communicate fine, just mobility is slow as if there was no FT). I seem to remember only very rare discussions where disabling FT actually made things work (ehile they didn't work with FT enabled).
[*] The very same thing happened with all new radio hardware generations since I started to use RB devices: ac device stability was iffy and performance sucked big time (with wireless driver) and things somehow improved (specially in stability corner) with time. With introduction of wifiwave2 drivers (which later evolved into wifi) there was some instability as well. Then it took a few montgs to stabilize wifi on AX devices (hAP ax2 was particularly painful). And things repeat with Mediatek radios ... these device are fairly new in MT roster, I'd expect to see them stable in ROS 7.26 or there about. And we're yet to see how things will go with BE hardware.
Thx. I did not completely disable FT only FT over DS.
but still maybe it was mostly ROS version. It is just that some users in this topic were so specific about FT over DS solving their similar issue
