Mikrotikish<->English conversion table/dictionary
This is a reference table/dictionary I put together for my personal use, maybe it is useful to someone else :slightly_smiling_face:.
It is obviously half-jokingly written, and more than a little tongue-in-cheek, don't take it too seriously.
.. still ...
:wink:
Mikrotikish Meaning in Mikrotik world Meaning in real world English
beta beta, an experimental version very near to become next rc. something that has been pushed out to users as a first attempt to something new, with a few added features and many new or regression bugs. pre-alpha or early-early alpha
bug a minor issue that can happen and that will be solved, but no ETA at the moment something that can break the otherwise normally working of tens, hundreds, or thousands of devices. usually introduced with a new version of software severe bug
CCR Cloud Core Router a good router, the Cloud in the name has been added by the marketing department, the Core is meaningless, but was added to have a three letter acronym. router
critical bug see bug something that will break the otherwise normally working of tens, hundreds, or thousands of devices. usually introduced with a new version of software extremely critical bug
CRS Cloud Router Switch a good switch with marginal router capabilities, the Cloud and Router in the name have been added by the marketing department. switch, like the CSS, only better
CSS Cloud Smart Switch a switch with low resources, using SwOS or SwOS lite instead of RouterOS, the Cloud and Smart in the name have been added by the marketing department. low cost switch for the masses
current see stable see stable see stable
developer a good, competent engineer that writes software a good, competent engineer that writes software, in good faith but often losing the overall view on what he/she is writing. developer (unmanaged)
gracefully an adverb that the good Mikrotik guys simply don't know, it can only be used in sarcastic statements, example: "Today Mikrotik gracefully released an important security update" a mess of contrasting and self-contradicting statements, to which you add versions and release channel confusion, often coupled with dead or incorrect links and more generally with severe lack of proper communication tawdry
improved something that is better than before, as an example, "improved stability" means that it is more stable than an earlier version something that is - at the moment - exactly as or worse than before, in Italian the proverb is "La toppa è peggio del buco" that translates literally to "The patch is worse than the hole", more generally it means "We are working on it, but no ETA" . changed, and subject to future changes
long term a version that should be used by anyone that has not the guts to use any of beta, rc or stable. something that has been released without proper testing as long term but usually short lived, anyway usually better than other versions. rc, release candidate
marketing department the good guys that make brochures and write copy for the videos used to help selling devices the good guys that add lots of hype to anything, often going way over the thin line between optimism and tall stories, particularly when it comes to capabilities and performance of devices.And yes, they will be the first against the wall when revolution comes. liers
nightly build an attempt to release each day (actually night) for the experimenters a work-in-progress build same as Mikrotik, but performed more rarely, like once a week or so, IF there is a suitable moon phase or the developers feel like it II (If Inclined) build|
Normisal not defined used informally for something that is not normal but that Normis attempts to sell as such. queer
proofreading the procedures implemented to make sure that documents, site, brochures, etc. bear no mistakes something that is never done unheard of
quality control not defined, a missing department a team or department that checks that the stupid things developers do are not passed on to the customers nobody
rc, release candidate an almost finished version that will become next release. something that has been pushed out to users as a nth attempt to something new, with a few added features and many new or regression bugs, but with some of the bugs introduced in the various previouis betas fixed. . early beta
regression bug see bug something that has already broken the otherwise normally working of tens, hundreds, or thousands of devices. and will break it AGAIN terrible regression bug
software architect not defined, as the figure does not exist, or if it actually exists, does nothing someone that coordinates the efforts of the developers, giving them a direction and path for future development nobody
software documentation the reference for commands and settings of the software the reference to a small fraction of commands and settings of the software, often missing examples or with wrong or incomplete ones some commands partially explained, not all of them, in spots.
stable something you can rely on. something that has been pushed to users as the final attempt to something new, usually unreliable, and becoming actually stable at the third or fourth revision, usually it takes 4 weeks or 28 days since official release to actually starting considering it somewhat stable. highly experimental, unstable, after having matured for 4 weeks at least it becomes experimental and you may start thinking to use it in production.
telegraphic pertaining the use of telegraph the style used by the good Mikrotik guys that write documentation and help pages, or when they post on the forum, it is clear from the result that when they write they pay a fee per word laconic, incomplete
As always, suggestions for corrections and additions are welcome.
work in progress (wip) → somewhere between next week and 1200 days.
:thinking: Have you now taken to writing in Mikrotikish?
No mention of "could not reproduce the issue on our end" ? sad.
@jaclaz should compose new song for RATM (Rage Against the Mikrotik) - “Producing Bugs in the Name” :slight_smile:
I made one with an AI tool, with a few manual refinements is not that bad.
(Mikrotik) Bugs are in the air
Verse 1
I set up my router on a Tuesday night
Thought I had it configured right
Three AM, the whole thing froze
Lost my connection, lost my mind
Updated the firmware, crossed the line
Now my bandwidth's barely there at all
Pre-Chorus
Every patch just breaks it more
Rolling back, I've done this before
Chorus
These MikroTik bugs drive me crazy
One step forward, ten steps lazy
I reboot it, pray it stays alive
Just trying to keep my network alive
These MikroTik bugs, they don't care
Bugs are in the air
Verse 2
Spent a hundred hours on the forum thread
Reading about devices half-dead
Someone said it's the VLAN settings wrong
I checked it twice, I checked it thrice
One more restart might just do the price
But the queue keeps dropping packets still
Pre-Chorus
Every fix just spawns a new one
This is not my idea of fun
Chorus
Bugs are in the air
Bridge
Downgrade, upgrade, pray
Reset it all again today
I know the pain won't go away
But I'll be back here anyway
Final Chorus
These MikroTik bugs, yeah they own me
But I'll never leave you, you're my only
Now we need a catchy tune and @Amm0 to convert it so that it can be played on devices with beeper ...
Here’s a pop version, fun and catchy:
https://suno.com/s/rdiDAV74otwuOSZ4
Here’s a folk/country version that more accurately captures the frustration and raw emotion:
https://suno.com/s/mNnn2UygsgfTDUp6
I concur, the "folk/country" version is better at expressing the love/hate relationship, perfect!
and it is still catchy enough, good work!
:+1:
Amazing!
I kindly request to add Mikrotish "improved stability". Or more generally "improved".
You havn't try edgerouter devices fews years ago.... LOL
It's in party true, but mikrotik is not the worst on the market ; at this price, it's incredible to have the support over the years on soft and hard.
Not sure products like ExtremNetworks/Fortinet/Stormshield/Aruba/Cisco do the same, at the same price...
Sure it is not. :slightly_smiling_face: But that doesn't mean that it could not be better.
Yep, but the price seems like an independent variable from support.
For an entry level device, under 100 Euro, it is fantastic, when you start buying devices in the 500-1000 Euro range it becomes not so good.
For me (as a a hobbyist, not professional) it is fine, but for people that actually need to sell these devices (and services) to customers, there are (IMHO) still so many corners that need to be rounded ...
@jaclaz Great job coming up with the lyrics. I liked the reference to VLANS, and the "spent a hundred hours on the forum thread".
Which AI assistant did you use?
Even without bugs/regressions, a whole song could be written about someone coming from a consumer router to MikroTik after someone recommended it because you could make the network more secure with VLANS. And the steep learning curve involved.
It could describe the "journey", including initial login problems with unreadable password, discovering quickset should never be used after making any changes outside of quickset, finding documentation, getting locked out when trying to configure VLANS, having to use netinstall, or and dealing with device mode, etc.
Recent example: Unable to access new RB5009UPr+S+IN router
This one (the first I could find that did not want my e-mail):
https://www.freshbots.org/
I love the pop version. It perfectly combines the lightheartedness of pop songs with the seriousness of the lyrics.
You really should add some explanation about the Unicorn versions…
Eleanor V8 deserves some attention.
If only I could understand what (the heck) are you talking about ... :woozy_face:
Gone in 60 seconds doesn't trigger any connection with Mikrotikish ... :astonished_face:
Yes, I can help with that. “Eleanore V8” is something repeatedly mentioned by the user @fischerdouglas. It appears to be a reference to the film Gone in 60 Seconds with Nicolas Cage. The exact joke or meaning behind it is unclear.
In MikroTik terms: “RouterOS 8.”
In English: “RouterOS 8.”
Seriously?
The unicorn?!? The promised and unattainable being?!? Haven't you seen the movie?
How many of us have had more than 3 tickets (even before Jira) closed with the answer "This will be resolved in RouterOS version 7!"
We see reports on the forum of promises for v7 Unicorn that have not been fulfilled to this day.
Some weren't even addressed.
V8, the myth is now different!
If today's RouterOS unicorn is Version 8, how can we not think of puns and jokes about it?!?
And for those who haven't watched Gone in 60 Seconds(1974 version or 2000 version) . And don’t know that the unicorn of Menpphis is a Mustang Shelby GT500 with an insane V8 , please watch it!
I can almost imagine the MikroTik team gathered in the crisis room and @normis saying:
P.S.: The jokes and memes are just a way of showing love. Don't be sad! As soon as we're at an in-person event together, I'll give you a hug.
