I got a Linux server in my LAN that runs MRTG and i monitor all Linux boxes for ethernet traffic, cpu, ram. I would like to add my Mikrotik Router in the MRTG and monitor traffic for each port, CPU, RAM.
I got confused how to write the mrtt.cfg for each element eg from a Remote Linux machine:
Target[CPU]: .1.3.6.1.4.1.2021.10.1.5.1&.1.3.6.1.4.1.2021.10.1.5.2:public@192.168.1.15:::::2
MaxBytes[CPU]: 100
Unscaled[CPU]: dwmy
Options[CPU]: gauge, growright, nopercent
YLegend[CPU]: Load Average
ShortLegend[CPU]: (%)
LegendI[CPU]: Load Average 1 min
LegendO[CPU]: Load Average 5 min
Legend1[CPU]: Load Average 1 min
Legend2[CPU]: Load Average 5 min
Title[CPU]: CPU Load Average
PageTop[CPU]: <h1>CPU Load Average of machine .15</h1>
You need to enable SNMP, and inside the MRTG config file you need to specify the “credentials” (e.g. SNMP version and community in most cases) in the target line.
Also, I presume you have reasons for using MRTG on a remote linux box. But Mikrotik internally uses MRTG in /tool/graphing so you can pretty easily get same charts from the Mikrotik itself (but they don’t show the MRTG config they use, so not so easy to just “copy”). Also their Dude offers an even richer monitoring than MRTG and support monitoring Linux, so could do this the other way around too.
thanks for the reply.
i am aware of the internal feature of mikrotik, but i am already using for my LAN a Linux box to monitor everything. The Linux box is inside my LAN. Everything is monitored within my LAN region.
I got the snmp enabled and i am getting from Mikrotik router the CPU % usage. My confusion is how to get the info for each interface separately and RAM usage. I have printed the OIDs from each each interface, but i am unaware which ones to use for the config in comparison to the link you posted.
Any ideas, please?
I am all but certain that Mikrotik uses the standard MIB-II iftable OIDs. Firstly because I’ve never seen a decent router that doesn’t, and secondly because I use the standard PRTG “SNMP Traffic” sensor without the need for any Mikrotik specific customisation. So although that doesn’t in itself help with the detail of your MRTG configuration file, it suggests that examples of how to monitor interfaces on other brands would probably work for Mikrotik.
I don’t know if this reference helps, when I’ve configured stuff in a more manual way I’ve used ifInOctets and ifOutOctets to get traffic stats. Obviously with the appropriate interface number as the suffix. These are counters so your traffic rate is the delta between readings .. http://www.net-snmp.org/docs/mibs/interfaces.html
It may help to use an interactive MIB browser so you can see in real time what each variable returns.
The interface data be exposed in standard MIB-2 MIB file as well. The “print oid” command likely gives you a Mikrotik-specific OID, not the standard onesexposed by the standard MIB-2 or HOST-RESOURCES MIBs. The though is that some MRTG tool might be able to autogenerated the MRTG config files based on those.
MRTG seems to have have a “cfgmaker” tool: https://linux.die.net/man/1/cfgmaker
That seem like it generate the file in the right format, similar to the _P_RTG wizard but at the command line.
I haven’t used MRTG in 20 years, so don’t recall the specifics. But I seems the key is to get the “Target” line right in the file. You’ll note it stores the community name and IP address there, so those have to match your router.
If the traffic is between two ports, members of bridge, then you won’t see that traffic in bridge counters. Bridge in RouterOS has a few personatlities and one of them is bridge interface which is a connection between RouterOS (the software part) and bridge (the switch-like entity). The counters you’re observing are counters for this personality and count only traffic directly handled by ROS (e.g. the management traffic).
If the traffic you’re mentioning (skype call), is being routed by ROS, then it should show in SNMP output, because traffic does traverse bridge interface on the way to/from routing engine (the LAN leg of it … assuming bridge is used to connect LAN ports together). Beware that some communication apps (e.g. skype, viber, …) use direct connections between call parties and if both parties are local, bulk of traffic never leaves local network.
