Hi Guys,
I want to try the idea to make a quite big network subnet to make remote site in the same network with the office/main location.
So when I need to add new mikrotik on 1 or more new remote site, it would be easy since they are on the same subnet.
There will be some office laptop for mobile purpose with zerotier client installed with the assigned IP is 172.22.0.251~172.22.0.254, and those laptops would be able to access all the network at the main and remote sites.
I read some good example <http://forum.mikrotik.com/t/zerotier-on-mikrotik-a-rosetta-stone-v7-1-1/155978/1 but the case was to connect laptop to 1 mikrotik.
From LAPTOP MOBILE#1, I can connect to hub and remote1. But the winbox kept closing after I connect for some time.
From LAPTOP MOBILE#1, I can’t connect to the devices behind hub or remote1, even though it is using same subnet size /21.
Same thing happen on the laptop from network hub to remote1, vice versa.
Weird thing I observe on the on the remote1 traffic on zerotier1 interface, it is showing Tx 25Mbps or sometimes 40Mbps even though there are no download/upload between hub and remote1.
Is there any configuration that I might missed?
The IP address allocation will be such:
Zerotier managed route: 172.22.0.0/21 via 172.22.0.1
Zerotier auto IP : 172.22.0.251~172.22.0.254
hub/main: 172.22.0.1 with DHCP client 172.22.0.101~172.22.0.250
remote1: 172.22.1.1 with DHCP client 172.22.1.101~172.22.1.250
this is configuration from hub/main:
# 2024-10-31 14:42:44 by RouterOS 7.15.3
# software id = FB3Z-1N2N
# model = RB450Gx4
# serial number = HD4082KJSKS
add add-dhcp-option82=yes admin-mac=18:FD:74:A4:46:52 auto-mac=no comment=\
defconf dhcp-snooping=yes name=bridge
set [ find default-name=ether1 ] name=eth1
set [ find default-name=ether2 ] name=eth2
set [ find default-name=ether3 ] name=eth3
set [ find default-name=ether4 ] name=eth4
set [ find default-name=ether5 ] name=eth5 poe-out=off
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=default-dhcp ranges=172.22.0.101-172.22.0.250
add address-pool=default-dhcp interface=bridge name=defconf
/port
set 0 name=serial0
/queue type
add cake-diffserv=besteffort cake-flowmode=dual-srchost cake-nat=yes kind=\
cake name=Cake-Tx-Down
add cake-diffserv=besteffort cake-flowmode=dual-dsthost cake-nat=yes kind=\
cake name=Cake-Rx-Up
add kind=fq-codel name=fq-codel
add fq-codel-ecn=no kind=fq-codel name=fq-codel-ethernet-default
/queue interface
set eth1 queue=fq-codel
set eth2 queue=fq-codel-ethernet-default
set eth3 queue=fq-codel-ethernet-default
set eth4 queue=fq-codel-ethernet-default
set eth5 queue=fq-codel-ethernet-default
/zerotier
set zt1 comment="ZeroTier Central controller - https://my.zerotier.com/" \
name=zt1 port=9993
/zerotier interface
add allow-default=yes allow-global=yes allow-managed=no disabled=no instance=\
zt1 name=zerotier1 network=<zt-network>
/queue interface
set zerotier1 queue=fq-codel
/tool traffic-generator port
add interface=zerotier1 name=port1
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=eth2
add bridge=bridge comment=defconf interface=eth3
add bridge=bridge comment=defconf interface=eth4
add bridge=bridge comment=defconf interface=eth5
add bridge=bridge interface=zerotier1
/interface bridge settings
set use-ip-firewall-for-pppoe=yes use-ip-firewall-for-vlan=yes
/interface detect-internet
set detect-interface-list=WAN
add comment=defconf interface=eth1 list=WAN
add address=172.22.0.1/21 comment="don't delete!!!" interface=bridge \
network=172.22.0.0
/ip dhcp-client
add address=172.22.0.0/21 comment=defconf dns-server=172.22.0.1 domain=local \
gateway=172.22.0.1
set allow-remote-requests=yes
/ip dns static
add address=172.22.0.1 name=hub.local
add address=172.22.1.1 name=remote1.local
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip firewall service-port
set rtsp disabled=no
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Australia/Brisbane
/system identity
set name=hub/main
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
And this is the configuration from remote1:
# 2024-10-31 14:43:55 by RouterOS 7.15.3
# software id = GLA4-S9GI
# model = wAPGR-5HacD2HnD
# serial number = HG909YAEWXT
add admin-mac=D4:01:C3:59:FF:C6 auto-mac=no comment=defconf dhcp-snooping=yes \
name=bridge
/interface lte
set [ find default-name=lte1 ] allow-roaming=no band="" disabled=yes \
sms-read=no
add authentication-types=wpa2-psk mode=dynamic-keys name=local-profile \
supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
disabled=no frequency=auto mode=ap-bridge name=wifi1 security-profile=\
local-profile ssid=MikroTik
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-XXXX disabled=no frequency=auto mode=ap-bridge name=wifi2 \
security-profile=local-profile ssid=MikroTik
add name=default-dhcp ranges=172.22.1.101-172.22.1.250
add address-pool=default-dhcp comment="default" interface=bridge \
name=defconf
/queue type
add kind=fq-codel name=fq-codel-ethernet-default
/queue interface
set eth1 queue=fq-codel-ethernet-default
set wifi1 queue=fq-codel-ethernet-default
set wifi2 queue=fq-codel-ethernet-default
/zerotier
name=zt1 port=9993
/zerotier interface
/queue interface
add bridge=bridge comment="defconf: used for WAN connection." \
disabled=yes interface=eth1 trusted=yes
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add comment=defconf interface=lte1 list=WAN
add interface=eth1 list=WAN
/interface wireless access-list
add interface=wifi1 signal-range=-60..120 vlan-mode=no-tag
add interface=wifi2 signal-range=-60..120 vlan-mode=no-tag
add address=172.22.1.1/21 comment="don't delete!!!" interface=bridge \
network=172.22.0.0
add address=172.22.0.0/21 comment=defconf dns-server=172.22.1.1 domain=local \
gateway=172.22.1.1
set allow-remote-requests=yes cache-size=1024KiB
/ip dns static
add forward-to=172.22.0.1 match-subdomain=yes name=local type=FWD
invalid
ipsec-policy=out,none out-interface-list=all
/ip hotspot profile
invalid
icmpv6
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
ipsec-ah
ipsec-esp
!LAN
/system clock
/system identity
set name=remote1
/system logging
add topics=wireless,info
add topics=dhcp,info
/system note
/tool mac-server
