I just purchased a brand new hAP lite, and it’s awesome, I love it except I am not able to reset the router’s config via reset button (I am able to reset it via System->Reset Configuration in the GUI though)
Here are the steps when I try with reset button
unplug power
hold RES button
plug power
wait until ACT flashes for 4 or 5 times(around 5 seconds) and release RES button
The ACT will soon stop flashing, and later on the router reboots
But the configuration remains the same, not being reset
i config in a bad way and i cant access to any control panel for update or anything else … ,
i cant update, the reset button not work
how can i reset factory it ?
I have the routerboard 941-2nd
I have taken this out of storage as i’ve not had need of it since i first messed with it and i am trying to config it but i have forgotten the details i have used to “set it up” the first time.
Needless to say i can’t get this to reset using the listed methods nor can i get it to update (because i can’t log in)
it is currently running 6.36.3.
I have tried pressing and holding the reset button then powering up but the LED just stays on - I’ve been holding it for 5 mins before and it still stays on until i let go.
I have tried powering up and then pressing and holding the reset button - still not resetting to defaults.
Before plugging into power, press and hold the reset button. Plug in the power. Count to eight seconds, then release the reset button. Wait for device to reboot. Then, via the ethernet cable plugged into ether 2, run Winbox and open the Neighbors tab. It will show up if things went well.
i have similar problem with same device, the reset is not working, i tried netinstall still not working, followed all instructions on all the threads concerning this issue still not working, is this hap ac lite a well tested routerboard, cause so many people hv complain on the rest button,
no user manager on my device packages i download the exact extra packages version of my router drag and drop on file click reboot and, that was the end of my device coming on and i just got it today, should i return this device? or is there a possible chance that it will work…
I have same problem i cannot do reset button. Sometimes work but all the time it cant do reset
i have successfully installed fresh routeros 6.46.8 haplite tc.. after installed it works and I have doubt if i unplug this it will not work again..and i am right after unplug issue again. Haplite tc notnworkin again
