NP16 v7rc2 reboot
NP16, rc2, BGP and hardware routing enabled. I had a random reboot this morning. no apparent cause or symptoms before the reboot. This is bone stock except added BGP, enabled romon, set some IP addresses. No queues, no vlans, only the most basic firewall rules on input chain, no NAT.
I just enabled error and critical logs to write to disk, anything else I should collect to identify what happened?
You can report the issue to our support. Also, check if RouterOS has generated autosupout.rif (via /file/print).
