I’m having trouble with a seemingly very simple two-area topology. Not sure if I’m misunderstanding how to configure OSPF in RouterOS v7 or what. I am running 7.2rc5 but I had the same problem in 7.1.
Three routers (R1, R2, R3) and two OSPF areas (backbone, area 99). R1 and R2 both have their loopback interfaces in the backbone area. R3 has its loopback in area99. Diagram:
R1 and R2 seem fine - they both have a route to all three loopback addresses in their routing tables. I would expect to see the same on R3, but R3 has no OSPF routes appearing at all. Am I missing something obvious? I had no issues with this kind of topology in ROS v6.
R1 configuration:
add name=loopback protocol-mode=none
/routing ospf instance
add disabled=no name=ospf-instance router-id=10.0.0.1
/routing ospf area
add disabled=no instance=ospf-instance name=backbone
add address=10.1.1.1/24 interface=ether1 network=10.1.1.0
add address=10.0.0.1 interface=loopback network=10.0.0.1
/routing ospf interface-template
add area=backbone cost=10 disabled=no interfaces=ether1
add area=backbone cost=10 disabled=no interfaces=loopback passive
R2 configuration:
add disabled=no name=ospf-instance router-id=10.0.0.2
/routing ospf area
add area-id=0.0.0.99 disabled=no instance=ospf-instance name=area99
add address=10.1.1.2/24 interface=ether1 network=10.1.1.0
add address=10.2.2.2/24 interface=ether2 network=10.2.2.0
add address=10.0.0.2 interface=loopback network=10.0.0.2
add area=backbone cost=10 disabled=no interfaces=ether1 priority=64
add area=area99 cost=10 disabled=no interfaces=ether2
R3 configuration:
add disabled=no name=ospf-instance router-id=10.0.0.3
/routing ospf area
add address=10.2.2.3/24 interface=ether2 network=10.2.2.0
add address=10.0.0.3 interface=loopback network=10.0.0.3
add area=area99 cost=10 disabled=no interfaces=ether2 priority=64
add area=area99 cost=10 disabled=no interfaces=loopback passive
R1’s routing table, OSPF interfaces, and neighbors:
[admin@R1] /ip/route> print
Flags: D - DYNAMIC; A - ACTIVE; c, o, y - COPY
Columns: DST-ADDRESS, GATEWAY, DISTANCE
DST-ADDRESS GATEWAY DISTANCE
DAc 10.0.0.1/32 loopback 0
DAo 10.0.0.2/32 10.1.1.2%ether1 110
DAo 10.0.0.3/32 10.1.1.2%ether1 110
DAc 10.1.1.0/24 ether1 0
DAo 10.2.2.0/24 10.1.1.2%ether1 110
[admin@R1] > /routing/ospf/interface/print
Flags: D - dynamic
0 D address=10.1.1.1%ether1 area=backbone state=dr network-type=broadcast bdr=10.1.1.2 cost=10
priority=128 retransmit-interval=5s transmit-delay=1s hello-interval=10s dead-interval=40s
1 D address=10.0.0.1%loopback area=backbone state=passive network-type=broadcast cost=10
[admin@R1] > /routing/ospf/neighbor/print
Flags: V - virtual; D - dynamic
0 D instance=ospf-instance area=backbone address=10.1.1.2 priority=64 router-id=10.0.0.2
dr=10.1.1.1 bdr=10.1.1.2 state="Full" state-changes=12 adjacency=53m13s timeout=39s
R2’s routing table, OSPF interfaces, and neighbors:
[admin@R2] /ip/route> print
DAo 10.0.0.1/32 10.1.1.1%ether1 110
DAc 10.0.0.2/32 loopback 0
DAo 10.0.0.3/32 10.2.2.3%ether2 110
DAc 10.2.2.0/24 ether2 0
[admin@R2] > /routing/ospf/interface/print
Flags: D - dynamic
0 D address=10.1.1.2%ether1 area=backbone state=bdr network-type=broadcast dr=10.1.1.1 cost=10
priority=64 retransmit-interval=5s transmit-delay=1s hello-interval=10s dead-interval=40s
1 D address=10.2.2.2%ether2 area=area99 state=bdr network-type=broadcast dr=10.2.2.3 cost=10
2 D address=10.0.0.2%loopback area=backbone state=passive network-type=broadcast cost=10
[admin@R2] > /routing/ospf/neighbor/print
0 D instance=ospf-instance area=backbone address=10.1.1.1 priority=128 router-id=10.0.0.1
dr=10.1.1.1 bdr=10.1.1.2 state="Full" state-changes=6 adjacency=52m30s timeout=33s
1 D instance=ospf-instance area=area99 address=10.2.2.3 priority=64 router-id=10.0.0.3
dr=10.2.2.3 bdr=10.2.2.2 state="Full" state-changes=6 adjacency=52m30s timeout=33s
R3’s routing table, OSPF interfaces, and neighbors. I expect to see OSPF routes to 10.0.0.1 and 10.0.0.2 listed here. But they are missing:
[admin@R3] /ip/route> print
Flags: D - DYNAMIC; A - ACTIVE; c, y - COPY
DAc 10.0.0.3/32 loopback 0
[admin@R3] > /routing/ospf/interface/print
Flags: D - dynamic
0 D address=10.2.2.3%ether2 area=area99 state=dr network-type=broadcast bdr=10.2.2.2 cost=10
1 D address=10.0.0.3%loopback area=area99 state=passive network-type=broadcast cost=10
[admin@R3] > /routing/ospf/neighbor/print
0 D instance=ospf-instance area=area99 address=10.2.2.2 priority=128 router-id=10.0.0.2
dr=10.2.2.3 bdr=10.2.2.2 state="Full" state-changes=12 adjacency=49m35s timeout=37s
R3 does appear to be receiving inter-area LSAs - so why are no routes calculated and added to the routing table?:
[admin@R3] /routing/ospf/lsa> print without-paging
Flags: S - self-originated, F - flushing, W - wraparound; D - dynamic
0 D instance=ospf-instance area=area99 type="router" originator=10.0.0.2 id=10.0.0.2
sequence=0x80000004 age=653 checksum=0xB359 body=
bits=B
type=network id=10.2.2.3 data=10.2.2.2 metric=10
1 SD instance=ospf-instance area=area99 type="router" originator=10.0.0.3 id=10.0.0.3
sequence=0x80000007 age=634 checksum=0x4996 body=
bits=B
type=network id=10.2.2.3 data=10.2.2.3 metric=10
type=stub id=10.0.0.3 data=255.255.255.255 metric=10
2 D instance=ospf-instance area=area99 type="router" originator=10.2.2.2 id=10.2.2.2
sequence=0x8000000A age=2449 checksum=0x4EB2 body=
bits=
type=network id=10.2.2.2 data=10.2.2.2 metric=10
3 SD instance=ospf-instance area=area99 type="network" originator=10.0.0.3 id=10.2.2.3
sequence=0x80000002 age=573 checksum=0x37EA body=
netmask=255.255.255.0
router-id=10.0.0.2
router-id=10.0.0.3
4 D instance=ospf-instance area=area99 type="inter-area-prefix" originator=10.0.0.2 id=10.0.0.1
sequence=0x80000002 age=653 checksum=0x3FF1 body=
netmask=255.255.255.255
metric=20
5 D instance=ospf-instance area=area99 type="inter-area-prefix" originator=10.0.0.2 id=10.0.0.2
sequence=0x80000002 age=655 checksum=0xD069 body=
metric=10
6 D instance=ospf-instance area=area99 type="inter-area-prefix" originator=10.0.0.2 id=10.1.1.0
sequence=0x80000002 age=640 checksum=0xCD6C body=
metric=10
7 SD instance=ospf-instance area=backbone type="router" originator=10.0.0.3 id=10.0.0.3
sequence=0x80000002 age=706 checksum=0x73D3 body=bits=B
8 SD instance=ospf-instance area=backbone type="inter-area-prefix" originator=10.0.0.3 id=10.0.0.3
sequence=0x80000002 age=706 checksum=0xC077 body=
metric=10
9 SD instance=ospf-instance area=backbone type="inter-area-prefix" originator=10.0.0.3 id=10.2.2.0
sequence=0x80000002 age=662 checksum=0xB086 body=
metric=10
Any and all help is appreciated.
