rpra
1
Trying to set up lab on 7.1.beta5
I simply want to redistribute loopback addresses into ospf, but by default it does not work.
Started to set up filters, but they do not work as said in https://help.mikrotik.com/docs/display/ROS/ROSv7+Basic+Routing+Examples
[admin@R1] > routing/filter/rule/add chain=ospf_out
failure: empty rule specified
[admin@R1] > routing/filter/rule/add chain=ospf_out rule="dst<subsumes>10.0.0.0/8"
failure: invalid action at dst
Maybe someone knows?
The syntax for routing filters has changed:
Details here:
http://forum.mikrotik.com/t/v7-1beta5-development-is-released/147722/1
I’d expect something like:
/routing/filter/rule/add chain=ospf-redist rule={if [protocol connected] then={action do=accept}}
rpra
3
Thanks, but I still can’t understand how to use that “chains” or “select chains”
Can you please show full config for “redistribute static/connected with some filtering” scenario?
mrz
4
Just need to specify chain in instance and add one rule.
/routing ospf instance set <xxx> out-filter-chain=myChain
/routing filter rule add chain=myChain rule={ if ([protocol connected]) then={num-value ospf-ext-metric<assign>10; ospf-ext-type type1; action accept}}
rpra
5
Ok, it looks working now.
What for are select-chain and select-rule?
And please help to figure out how to filter by prefix and prefix length?
How would make equivalent of this?
- redistribute default route - never
- redistribute connected routes - as type 1
- redistribute static routes - as type 1
Can it be like this?:
0 chain=final rule=if ([protocol connected] || [protocol static]) then={action do=accept; ospf-ext-type type1}
1 chain=final rule=if ([prfx-value is=dst0.0.0.0/0] || [protocol static]) then={action do=reject}
mrz
7
Firsts reject default route and then accept static,connected
or you can write in one rule
if ([prfx-value is=!dst<equal>0.0.0.0/0] || [protocol static] || [protocol connected]) { ospf-ext-type type1; action accept}
mrz
9
How can I set ospf cost? Before it was just "routing ospf area set default-cost=
I just cannot find it enywhere.
