I’ve tried to estabilish a VPN between a Sophos firewall and a 3011 with 7 beta but the only auth allowed is SHA256…
Is planned to add more auth and ciphers options?
Hi we use Sophos UTM as ovpn server and mikrotik as clients, There is no problem configured like this:
Compression needs to be disabled on sophos side.
Enc AES-256-CBC and auth SHA1 on Sophos side.
Cipher aes 256 and Auth sha1, certificate from sophos in mikrotik file system and username from sophos (REF_******** ) and mode ip and correct port.
Working ok.
Yep, I’m sure it works.
But I cannot change config on sophos side… That’s why I’m asking for more cypher options!
