Station Wireless Configuration
/interface wireless export
# jan/02/1970 02:27:07 by RouterOS 5.2
# software id = Y5QH-TJ1Q
set default authentication-types="" eap-methods=passthrough group-ciphers="" \
group-key-update=5m interim-update=0s management-protection=disabled \
management-protection-key="" mode=none name=default radius-eap-accounting=\
no radius-mac-accounting=no radius-mac-authentication=no \
radius-mac-caching=disabled radius-mac-format=XX:XX:XX:XX:XX:XX \
radius-mac-mode=as-username static-algo-0=none static-algo-1=none \
static-algo-2=none static-algo-3=none static-key-0="" static-key-1="" \
static-key-2="" static-key-3="" static-sta-private-algo=none \
static-sta-private-key="" static-transmit-key=key-0 supplicant-identity=\
MikroTik tls-certificate=none tls-mode=no-certificates unicast-ciphers="" \
wpa-pre-shared-key="" wpa2-pre-shared-key=""
/interface wireless
set 0 adaptive-noise-immunity=none allow-sharedkey=no antenna-gain=0 area="" \
arp=enabled band=5ghz-a/n basic-rates-a/g=6Mbps bridge-mode=enabled \
channel-width=20mhz compression=no country=no_country_set \
default-ap-tx-limit=0 default-authentication=yes default-client-tx-limit=0 \
default-forwarding=yes dfs-mode=none disable-running-check=no disabled=no \
disconnect-timeout=3s distance=dynamic frame-lifetime=0 frequency=5180 \
frequency-mode=manual-txpower frequency-offset=0 hide-ssid=no \
ht-ampdu-priorities=0 ht-amsdu-limit=8192 ht-amsdu-threshold=8192 \
ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 \
ht-extension-channel=disabled ht-guard-interval=any ht-rxchains=0 \
ht-supported-mcs="mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-\
9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-\
20,mcs-21,mcs-22,mcs-23" ht-txchains=0 hw-fragmentation-threshold=disabled \
hw-protection-mode=none hw-protection-threshold=0 hw-retries=7 l2mtu=2290 \
mac-address=00:0C:42:96:B5:24 max-station-count=2007 mode=station mtu=1500 \
name=wlan1 noise-floor-threshold=default nv2-cell-radius=30 \
nv2-noise-floor-offset=default nv2-preshared-key="" nv2-qos=default \
nv2-queue-count=2 nv2-security=disabled on-fail-retry-time=100ms \
periodic-calibration=default periodic-calibration-interval=60 \
preamble-mode=both proprietary-extensions=post-2.9.25 radio-name=\
000C4296B524 rate-set=default scan-list=default security-profile=default \
ssid=MPLS station-bridge-clone-mac=00:00:00:00:00:00 supported-rates-a/g=\
6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps tdma-period-size=2 \
tx-power-mode=default update-stats-interval=disabled wds-cost-range=50-150 \
wds-default-bridge=none wds-default-cost=100 wds-ignore-ssid=no wds-mode=\
disabled wireless-protocol=nv2 wmm-support=disabled
/interface wireless manual-tx-power-table
set wlan1 manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbp\
s:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:17,H\
T20-1:17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20-7:17,HT40-0:\
17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:17,HT40-7:17"
/interface wireless nstreme
set wlan1 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=\
3200 framer-policy=none
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=\
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 \
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 \
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=no \
streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
[admin@MikroTik] >
