Guys,
could you, please, move your discussion regarding IPv6 SLAAC into another thread? This is one big RouterOS topic dominated now by something not strictly related…
Guys,
+1 minimum 3 characters
dup post about netwatch not available in CLI. removed. note to myself: read first, then post.
also something strange. I wanted to beef up the 4019’s single-chain wifi with ww2 package on a cube60 pro ac, so i installed ww2 on it - and i lost access to w60 interfaces.
presumably this is expected so, as installing/enabling ww2 disables the ‘default’ wireless package, which also has the drivers for the WiGig part… hopefully this will be a bit enhanced.
Reading the description of cube60 pro ac, the 5GHz part is used as automatic backup, so they are somewhat tied to one another, I doubt that your request has any standing point.
Well, having the possibility for wireless and wireless2 to co-exist would be welcome on my 4011 too!
Wifiwave2:
Using 802.11.r on a pair of 2G and 5G interface with same SSID on audience (set security.ft=yes),
I know see huge amount of “interface flapping” of clients being at the edge of good 5G and better 2G connection.
Before they worked well and did roam from time to time from 5G to 2.4G and back, but really not often and it would not be noticed.
Now its like 4-5 times per minutes and constant reconnects of high layer apps making it impossible to work with them.
Removing 11r, (security.ft=non) and things get stable again…
Anyhow experiencing something like this?
Or the option to replace the old 11n 2.4G PCIe card which is in RB4011 by a wifiwave2 compatible one.
I just checked yesterday MIkrotik web page. there is none.
Really a pitty as without that for me, the RB4011 with Wifi is a piece of useless HW ready for the bin…
You can always use it without WiFi.
What I do not understand is why the addition of a new WiFi driver (which even has a new configuration command tree) means that the old driver has to be disabled.
I think RouterOS should at boot first enable wifiwave2 and have it probe for its supported hardware, and after that is finished it should enable the old wireless driver and have it find the remainder of the hardware that wifiwave2 has not picked up.
So at least I can have wifi wave2 on 5 GHz while having legacy wifi on 2 GHz (which I use only for some esp8266 gadgets so performance is not important).
Thank you for confirming that the current ww2 package does not contain w60 drivers.
Container comments don’t get saved.
Are you trying to avoid saying the “C” word? Is this CGMP by another name?
I have used:
0 key="TZ" name="pihole_envs" value="Europe/Riga"
1 key="WEBPASSWORD" name="pihole_envs" value="mysecurepassword"
2 key="DNSMASQ_USER" name="pihole_envs" value="root"
Yes, but it doesn’t work, container ignores envlist.
LE: wrong, see my previous edited comment about this.
*) wifiwave2 - fixed WPA3-PSK authentication incompatibility with certain vendor and model devices;
This fix is not included in the latest beta, as my Samsung A52s 5G doesn’t connect anymore on the network after upgrade. It only works with 7.3.1
No improvement on BGP that already reported? Amazing
Container support is broken for me on arm64 after upgrade from beta4 to beta5. Mount configuration disappeared, as well as maximum ram. Cannot set maximum ram anymore, the value is not displayed in the config. Container fails to start with no error message. It was working fine in beta4.
Read previous comments.
I am not using envs. It must be broken in multiple ways
