I'm quite surprise and smile at the same time while I wrote this, I never imagine due to crazy world we live this edge computing is now a thing with our organization we are in need a mikrotik router that is twice as fast as RB5009 8g/16g of RAM with 4 bay of NVME storage bay
I don't know maybe with enough interest from other people MT might consider it or someone will chime and make another different ideas who knows, why is it that everything is a big deal for you REX or whoever you are if you don't like the post then ignore it didn't harms you in anyway
If you think the post doesn't pass your litmus test then leave it as it is thanks anyway
Said it before but if there was an RDS that fit into a 10" rack I'd pre-order. I swore I would never preorder after what happened with CyberPunk 2077 so this is big. Or little. Look, I have money.
You’ve misunderstood, did you actually read what I wrote?
The MikroTik staff will likely never see this.
If you want to write to MikroTik, you need to send an email to support@mikrotik.com
Sending it to them will not gather attention but if the people share their ideas who know's mikrotik will consider making the actual product specially if the ideas turn out palatable to them
In case, I would like it with sockets that accept thicker drives, it seems like the 7 mm ones for the RDS2216 are discontinued and the alternatives are far from being affordable :
