I’m trying to upgrade a RB850Gx2 from 6.49.6 to 7.4.1 and I get:
routeros-powerpc-7.4.1.npk missing
using either winbox or CLI
What have I done wrong??
if you are using free software, it would probably be STABLE when it is EOL!
lol.
MT guys usually fix bugs after months
routeros is not cisco/juniper router software as we all already are aware.
zerotier-7.4.1-arm.npk can not be installed.
Memory issue?
Cisco are not at all bug free at all and we have experienced nearly 1 year to fix a critical problem.
Upgraded from 7.4 to 7.4.1 on D53G-5HacD2HnD
if only we have an answer in 24-48h…
updated the CRS504-4XQ-IN and ow freebsd noses are not able to discover their neighbors(IPV6) even after a reboot.
yeah, mikrotik is not cisco/juniper…
thx God for that
Upgraded a 750GL fro 6.49.6 to 7.4.1.
The upgrade went ok, and the device functions fine.
I have an issue with webfig to the upgraded device. The OSPF pages do not reflect the config of the device.
Examining the OSPF config from the command line, all is as I expect, a faithful translation of the devices original configuration, its joined the local OSPF network fine and getting the routes I expect.
The OSPF pages via webfig appear unconfigured.
Tellingly the home page of the router does not offer the webfig icon.
I did test upgrades on an out of service router. That path was from 6.49.6 to 7.1 to 7.4.0, that worked fine, and showed ip and ipv6 tabs, and correct OSPF pages.
I’m guessing that the upgrade has not updated the webfig code on the box.
Suggestions? I’ve not seen advice not to upgrade directly from latest v6 to latest v7, but I may gave missed it.
Harry
Update. Using Firefox mint-001 - 1.0 103.0.2 64 bit on Linux Mint 20.3. HTTPS is enabled.
any clues maybe on how one can get cake not to reboot(kernel panic) a ccr1009? lowered mem usage(1mb) and seems to be stable with few queues enabled(20) but anything more and it keeps restarting.
you update from v6.x on various step to v7.x???
if yes, netinstall the last 7.4.1 without using the .backup but importing the .rsc section by section.
Hmm no die upgrade from 6.47/8… do i get the rsc file with export function?
Yes, rsc is result of command
/export show-sensitive file=anynameyouwish
Sorry, what’s mean “no die upgrade”? I’m not english, thanks.
Ok did the netinstall loading things manually… will install in morning and check
Upgrade 7.1 to 7.4.1 on AC2, OSPF2 stopped redistributing connected routes. Worked around this by setting up passive interfaces but still.
Still this history undo bug in this release. I need to file a support ticket.
I wanted to test Xvlan between 2 routers, I set up the first one and it was fine, while setting up the second one, the router went offline, and would just keep on rebooting, i disabled the IP it was connecting to and the router stabilised, logged in and disabled the XVLAN, and it was back online, looks like a bug.
I have installed it on 2x hAP AC2 (one 256MB, one 128MB), RB4011 and RB2011. Most of them are running good, except the “smaller” AC2 (with only 128MB Ram) - which keeps on rebooting with “Kernel failure, out of Memory” between 1h and 2 days of uptime. This Issue (Wifi stops working) was already there on many older v7 versions but until now i had no chance to track it down. It looks like Capsman has something to do with it, because it also loses connection every now and then, saying “CAP sent max keepalives without response”, but the ethernet-link and vlan are still up. The same time, the Device stops responding to all Traffic from LAN and doesnt forward anything from WLAN into (V)LAN. I didnt check yet, if the Switch keeps on forwarding Data on the other VLANs.
NTP is disabled (as suggested in older posts on the out of Memory thing), without change.
